Using external Spamassassin
I have spamassassin set up om a win 2003 server and is working well on my primary mail server. I want to use it on my secondary server as well (both are running hmail) but when I tell Hmail to use spamassassin and I point it to the server that has it running (at spamd is running ) it always tells me it can't connect. What part am I not running (using the standard port)
Re: Using external Spamassassin
by default spam assassin will only allow local connections (127.0.0.1)
I tried reading through the SA doc's
Isn't there a way to allow it and where do I change it
Thanks Doom
Thanks Doom
as horndog shows. it is a command line switch. Read the SA docs.
I read the Docs, I installed the program suggest and it works just fine. But it will still not connect. I have been SA for 3 years uding it with Ewall with no issues and was happy with it. I stopped the ewall filters and even tried to connect on the local machine with no luck. Just says it cannot connect to server. So not only will remote hmail servers not connect to SA but the hmail server on the same machine will not connect to it as well. Ewall runs fine with it. But agina I need to add the remote systems
Any other suggestions please
http://spamassassin.apache.org/full/3.0 ... spamd.html
-A host,..., --allowed-ips=..,.. Limit ip addresses which can connect
Yeah Horndog that was part of my district. I worked out of Crystal Lake, Bloomingdale then up to Brookfield where I was in charge of the stores up here as well as the upper Illinois area. The District Manager worked out of Vernon Hills but he spent his time down in the city. (he lived there) while he made me do all the driving
Doom will try that as well
That is what i told you to do last time although you assured us you had read the docs...bescher wrote:Doom will try that as well
^DooM^ wrote:by default spam assassin will only allow local connections (127.0.0.1)
^DooM^ wrote:it is a command line switch. Read the SA docs.
bescher wrote:I read the Docs, I installed the program suggest and it works just fine. But it will still not connect. ~~~~ Any other suggestions please
