mssql ce
westdam
mssql ce
Post by westdam » 2009-11-17 17:31
is it possible to update the mssql ce bundled with hmail v5?
need to use microsoft update?
Caspar
Re: mssql ce
Post by Caspar » 2009-11-17 18:11
If I am correct the full explanation why MySQL CE is not with the Hmailserver you can find here
http://www.hmailserver.com/forum/viewto ... f=8&t=9736
Ill try to search what post and post it here when i found it.
[Edit]
Found it:
1st page:
http://www.hmailserver.com/forum/viewto ... 149#p54149
westdam
Re: mssql ce
Post by westdam » 2009-11-18 01:55
uhm.. maybe you misunderstood me..
i just want to update mssql .. for example sp1..
just want to know if it's possible or not..
Re: mssql ce
Post by mattg » 2009-11-18 07:21
NOT TESTED, but I believe that SQL 2008 versions have a user friendly upgrade GUI that starts when you run the installer...
I believe that you can for instance upgrade from the CE version to the 2008 Express version....
Matt
westdam
Re: mssql ce
Post by westdam » 2009-11-18 09:49
mmm ok.. becouse i've seen the sp1 of mssql ce. i just wanna know if latest hms build has this sp and how to apply to old hms build..
Caspar
Re: mssql ce
Post by Caspar » 2009-11-18 11:14
:oops: I read it wrong. I tought you meant MySQL sorry for the misunderstanding.
Re: mssql ce
Post by martin » 2009-11-18 19:44
Use the SQL CE version which comes with hMailServer. hMailServer will include SQL CE 3.5 Service Pack 2 when that's released (currently in beta).
westdam
Re: mssql ce
Post by westdam » 2009-11-20 10:00
thanks for the reply martin.
