hMs Built in back up
Slug
Post by Slug » 2009-09-27 14:25
Hi Martin
I know there is a limitation on the internal back up function of approx 1.5 gig. But I would like to know what particularly is the limitation from ? Is it a limitation of the zip function or something else.
The reason I'm asking is my mail server is now hitting this limit on a almost daily basis (depending on how many emails I have deleted). and I would like to know what my options are.
Re: hMs Built in back up
Post by martin » 2009-09-27 14:33
Actually, the user interface says 1GB, not 1.5GB. :) The limitation lies in the zip functionality, and in the fact that the backup procedure/code is too slow to work efficiently with larger installations. It will take a long time to restore more data, which is why other alternatives is recommended.
If your installation is larger, just do a mysqldump and backup the data directory using robocopy/xcopy.
Post by ^DooM^ » 2009-09-27 14:40
Write a batch file to dump the database on a scheduled task, then use cobian backup to zip up the data dir (can be all or just changed files since last backup) and the SQL dump then copy/move/ftp it elsewhere.
Slug
Post by Slug » 2009-09-27 14:46
martin wrote:Actually, the user interface says 1GB, not 1.5GB. :)
So it does, but not in the log :P :P :P Says 1.5...
I will start looking at alternatives.
Slug
Post by Slug » 2009-09-27 14:47
^DooM^ wrote:Write a batch file to dump the database on a scheduled task, then use cobian backup to zip up the data dir (can be all or just changed files since last backup) and the SQL dump then copy/move/ftp it elsewhere.
I remember seeing a thread you posted a while back on this, I will go dig it up.
Post by ^DooM^ » 2009-09-27 14:49
The file i posted was a linux bash script, won't work on windows.
Slug
Post by Slug » 2009-09-27 14:49
Ahh could be a sight issue then .. :lol: :lol: :lol:
Post by mattg » 2009-09-27 15:20
here's mine, I modified Doom's to a windows batch file, I run it as a scheduled task
rem
rem Backup hMailserver data directory and database
rem
erase /Q C:\Backuptemp\*.mysql
net stop hmailsever
robocopy "c:\Program Files\hMailserver\Data" c:\BackupTemp /mir
copy "c:\Program Files\hMailserver\bin\hmailserver.ini" c:\BackupTemp /Y
cd C:\Program Files\MySQL\MySQL Server 5.0\bin
mysqldump -u"root" -p"XXXXXXXX" -q -A -l --add-drop-table -P3307 >"C:\backupTemp\MYSQLDump %date:~10,4%-%date:~7,2%-%date:~4,2% %time:~0,2%%time:~3,2%.mysql"
net start hmailserver
cd C:\Program Files\7-Zip
7z a -tzip "C:\Backups\hMailserver %date:~10,4%-%date:~7,2%-%date:~4,2%" C:\BackupTemp\*
It uses robocopy and then 7-Zip for the compression
It has a dummy directory at C:\BackupTemp\ and writes the zipped file to C:\Backups\ and has the date in the final zipped file name
Oh, and been meaning to test that I can restore, just haven't got to that yet, so don't rely on it without testing please
Slug
Post by Slug » 2009-09-27 15:22
Thanks .. I give it a shot tomorrow.
Slug
Post by Slug » 2009-09-27 15:23
1 more thing Matt, I guessing from that you are using the internal DB ?
Nope, ignore that .....
Whats the p3307 for ?
Post by ^DooM^ » 2009-09-27 15:29
That is port.
Slug
Post by Slug » 2009-09-27 15:31
^DooM^ wrote:That is port.
Ok that was my guess... hence the first question.
DeanoX
Post by DeanoX » 2009-09-28 17:25
I use the mysql administrator's included scheduled backup service, to create the mysql backups. Then I use cobian backup, to manage the backups locally, and also send backups offsite, using an out of band FTP backup server.
Works rather nicely.
Slug
Post by Slug » 2009-09-29 14:50
DeanoX wrote:I use the mysql administrator's included scheduled backup service, to create the mysql backups.
Which one ? mine does not have a scheduled backup
Michael
westdam
Post by westdam » 2009-10-06 16:40
a newbie question to this argument :
what about to use the 7zip algorythm in the integrated backup?should this solve the zip limitations?
except the restoring speed of course... still slow on large system.
sheffters
Post by sheffters » 2009-10-06 16:51
zip files arent limited in size anyway ... I've got loads of them several GB for vmware shells and the like.
S.
Slug
Post by Slug » 2009-10-06 17:03
Not 100% true
http://winzip.com/wzdic.htm (old format / 4Gb/65535 files)
Also (and I don't know here) if hMs backup is using the "internal zip" in windows there maybe some limitations as well.
Michael
Post by ^DooM^ » 2009-10-06 17:03
Pretty sure it has to do with the size of the XML file that is generated when you save with messages.
Slug
Post by Slug » 2009-10-06 17:08
^DooM^ wrote:Pretty sure it has to do with the size of the XML file that is generated when you save with messages.
This could be true, because it wont backup even if I un-tick the option to zip the backup.
westdam
Post by westdam » 2009-10-06 21:39
mmm ok..
what about speed instead? 7zip is open and free format isn't it? and it's fast..could be used right?
Post by ^DooM^ » 2009-10-06 21:49
Probably not not hMail is closed source. I haven't found 7zip to be that much faster than winzip or winrar's zip function in my years using them.
westdam
Post by westdam » 2009-10-12 15:52
well, theorically should be faster and better as compression quality.
but i think we're speaking of ms or kbyte
