Torrent question
black zero
Torrent question
Post by black zero » 2009-08-20 10:56
Does anyone know why my upload speed is always higher than my download speed on the torrent status?
Not that I grudge that, just curious. :lol:
Re: Torrent question
Post by ^DooM^ » 2009-08-20 11:35
Have you forward default torrent ports to your pc? Also some ISP's throttle P2P transfers. I know talktalk do in the UK.
Slug
Post by Slug » 2009-08-20 12:09
talktalk .... do they have a stuttering problem :wink:
dzekas
Post by dzekas » 2009-08-20 15:53
black zero wrote:Does anyone know why my upload speed is always higher than my download speed on the torrent status?
You don't control your upload and download speeds. Uploads overload your link.
Post by ^DooM^ » 2009-08-20 17:29
Indeed, in UTorrent options you can limit your speed. I limit at about 15k/sec when downloading then max when seeding.
black zero
Post by black zero » 2009-08-21 02:31
Yep. I've forwarded the required port for uTorrent already.
And I used to think port - forwarding is only needed if you want to do a better upload not download?
Post by ^DooM^ » 2009-08-21 13:52
My speeds are crap unless i forward default ports however I am no expert on what torrent uses those ports for. Definitely try limiting upload speeds and see if that helps.
