PHPBB3
PHPBB3
Post by martin » 2008-02-29 22:24
Anyone tried it? Thinking about upgrading... =)
plobby
Post by plobby » 2008-02-29 23:26
http://www.squirrelmailforum.com
I didn't like the default theme at all, so I loaded the alternative. I have yet to get around to playing with the looks of that much, but I have yet to have any issues with it and it seems to work very well. I haven't used phpbb2 in a while (as an admin) so I really cant state the differences.
Post by martin » 2008-02-29 23:56
Put up a copy of it here (don't post anything important in it, it will be lost..)
http://www.hmailserver.com/newforum/
Agree, the default theme is to color-rich for my taste. ;)
plobby
Post by plobby » 2008-03-01 00:15
Are you thinking about moving over to it soon?
Post by ^DooM^ » 2008-03-01 03:29
Not a huge fan of that theme at all. tis all arse backwards and hard to read in my opinion :D
Post by martin » 2008-03-01 13:34
i'm not planning a switch before i've updated the theme..
Post by ^DooM^ » 2008-03-01 14:18
Aside the theme I like the new PHPBB :)
Post by katip » 2008-03-01 16:47
Don't keep default 100% width. 90-80% is always better view/readable (to me at least ;))
Post by martin » 2008-03-01 23:44
Yupp, like it to. Specially the syntax highlighting.. Example:
http://www.hmailserver.com/newforum/vie ... =14&t=2702
joe.davis
Post by joe.davis » 2008-03-02 01:06
I tried it for a while but it kept spiking the CPU on Windows 2003 Web server. I did a few searches on the phpbb support forums and found a lot people saying that the fix is to run it on Linux. If you are running a linux web server, I'd say go for it. If not, try something like Simple Machines Forum (http://www.simplemachines.org/). I was able to import all of my phpBB content and users to SMF and it isn't spiking the CPU on my web server.
-Joe
Post by ^DooM^ » 2008-03-02 04:03
I use SMF for all my forums.
Post by martin » 2008-03-09 13:38
I think that's good if I just remove all the unnecessary (?) parts from it (such as "last visit", "current time", "All times are UTC + 1", "birthdays", "newest member" and so on). I will also remove the gray area in the top...
Slug
Post by Slug » 2008-03-09 13:50
I dont mind it, will be good with a theme change.
Post by ^DooM^ » 2008-03-09 13:51
Yeah I like that one Martin.
Post by martin » 2008-03-09 16:11
Any more comments on it now?
Post by katip » 2008-03-09 16:49
martin wrote:http://www.hmailserver.com/newforum
Looks better :)
BTW SMF really rocks. Conversion from PHPBB shouldn't be an issue too. It's worth to give a try IMHO.
Post by martin » 2008-03-09 16:58
I believe you.. the thing is that I have little time and even if learning a new forum system doesn't take a lot of time it still takes some.. :) So for now I think I'll stick to PHPBB which I'm used to. If maintaining PHPBB3 is just as much work as PHPBB2 I'll probably switch sooner or later. =)
minsik
Re: PHPBB3
Post by minsik » 2008-03-23 04:09
phppb3 seems al ok to me Martin. Hust a little different but from speed it loads a topic much faster and smoother then version 2.
I like most new things and its just getting used to it.
took a while to find the "mark all posts read" but its there on the rhs top area. it had to be somewhere.
thanks for the work.
Windows XP
ASSP - front end SPam killer
