HOWTO: Using SpamAssassin with hMailServer V4
GlenC
Post by GlenC » 2005-03-29 16:33
I found a perl script that generates reports from the spamd log. I made modifications to it so it works with the cygwin install of spamassassin. It may work ok with other versions too as long as the log files are in the same format. I also added a few options for reports. The original was found here:
http://freshmeat.net/projects/sa-stats/
and you can download mine here:
http://home.comcast.net/~carrerasg/sa-stats-mod.zip
The only thing you should have to do is modify the path in the config section so it can find your spamd log. It should run ok... but, the report for the last week and the custom report might run a little slow on a big log (I really don't know much about optimization :roll: )
EDIT: Just put up another version which corrected some errors and made the tables a little easier to read. If you had problems with the original version you might try this one. Also added an email report option. It requires the ssmtp package though (cygwin).
john25uk
Post by john25uk » 2005-04-08 00:35
Hi there,
I have finally installed CygWin to run SpamD on my system, and it works like a dream.
I do have problems with WinSpamC and the CygWin built SpamC.
WinSpamC buggers up most documents I have put through it - so for those who it works fine for, what system are you on? and did you build WinSpamC for yourselves or use the one distributed?
SpamC seems to replace CRs with the little square (unix CR??) and also seems to mess up the headers of the email and makes it appear with the wrong date, no subject, and no from! - Might be because I built it with CygWin, so are trying it with my 2003 windows box to build and use.
Any ideas?
John
C:\ C:\DOS C:\DOS\RUN RUN\DOS\RUN
John 8)
GlenC
Post by GlenC » 2005-04-08 00:58
john25uk wrote:I have finally installed CygWin to run SpamD on my system, and it works like a dream. I do have problems with WinSpamC and the CygWin built SpamC.
John
Strange that you wrote this today, I've been fighting with SpamC/D all day today. As I wrote before, WinSpamC has always truncated attachments on my system. Never figured out exactly why. An now recently, the cygwin version of SpamC started acting crazy... it appears that for any message over 34k, it will not rewrite the headers or mark the subject. (although I can tell from the logs that it IS in fact being scanned, and properly).
I'd be very interested in hearing what systems others are using also.
(I'm using WinXP SP2 with the cygwin builds)
mirb
Post by mirb » 2005-04-08 01:52
i run spamassassin 3.0.2 on cygwin (i suggest 1.5.12 and not 1.5.13 that has some incompatibility...for example clamav stop run..), spamD as explained in our common source; winspamc is the distributed version and spamd as service (purplebear method); all work absolutily fine expecially after the introduction of user preferences functionality.
All under Windows 2003 IIS, PHP5, perl5.8, MySQL 4.1.10, and always the last bulid of HMServer;
well, i had had to remove and reinstall cuygwin many times to get the perfect stability; all problems you are encontering, i thing may depend on cygwin/spamd and never on winspamc;
i suggest to unistall cygwin and reinstall it (use 1.5.12 ..trust me) very carefully, install spamd service and get a rock solid system;
i experienced bud cygwin functionality after upgrading its installation with some other components, instead an all in one and no more action installation results fine.
procedures i installed:
Component during cygwin installation:
- All BASE packages
- under DATABASE, both the DEVEL and RUNTIME version of SleepyCat 3.1 Berkeley DB
- under DEVEL, the MAKE, GCC
- under INTERPRETERS, Perl
- under NET, the INETUTILS
- under Admin cygrunsrv for start spamd as service in cygwin
- under BASE cygwin 1.5.12-1
Once cygwin installed, under "CPAN":
- install DB_File
- install Time::HiRes
- install Net::DNS
- install HTML::Parser
- install DBI
- installation of mysql client (http://www.enstimac.fr/Perl/perl5.6.1/s ... ows/cygwin)
(last two are for activate user pref functionality)
try also to run spamd with -i HOST_IP -A IP_ALLOWED switches
and -d MAILSERVER_IP switches with WinSpamC; i feel them more solid...
GlenC
Post by GlenC » 2005-04-08 18:55
john25uk wrote: WinSpamC buggers up most documents I have put through it - so for those who it works fine for, what system are you on?
John
John... I don't know whether this will fix your problem or not but it fixed the problem I was having with winspamc truncations AND the problem with no markup with the cygwin version of spamc. I have a choice now!! :D
At the very bottom of this page is a patched version of spamd... just rename your old and replace with the attachment he provides. I haven't tested long enough to see if anything new has cropped up but my initial tests show everything is good. Hope this does something for you.
http://bugzilla.spamassassin.org/show_bug.cgi?id=3917
john25uk
Post by john25uk » 2005-04-08 22:10
I tried that and it seems to be working!! Blimy, what a pain in the ass spam is!
Thanks!
John
John 8)
GlenC
Post by GlenC » 2005-04-09 04:09
I'm glad that worked for you. I don't know why they didn't backport that fix to 3.0.2 as it seems like a fairly severe problem to me.
Horas
Post by Horas » 2005-04-22 17:47
@john25uk: Do you still have the vbs-Script which you used in your first solution (the one that ist called by the external Virusscanner Tab)? The Link is broken...
I don't want to install hMailServer 4.0 yet so I would like to try that solution before.
john25uk
Post by john25uk » 2005-04-22 17:58
Hello Horas,
I do, but not at the moment! i will re post it tomorrow somtime when I am work as I have it archived there!
John
John 8)
mirb
Post by mirb » 2005-04-22 18:14
Wasn't this one?
dim filename, args
set args = wscript.arguments
if args.count = 0 then wscript.quit(99)
filename = args(0)
filename = filename & " " & args(1)
dim infile, outfile
dim fso, ts
set fso = createobject("Scripting.FileSystemObject")
if not fso.fileexists(filename) then script.quit(89)
infile = fso.getabsolutepathname(filename)
testfile = infile & ".tmp"
dim cmd, sh, rc
fso.movefile infile, testfile
cmd = "cmd /c perl -S -T -w spamassassin < """ & testfile & """ > """ & infile & """"
set sh = CreateObject("WScript.Shell")
rc = sh.Run( cmd , 0 , TRUE)
fso.deletefile testfile
wscript.quit(7)
thegregor
My OnDeliverMessage script, with learning support
Post by thegregor » 2005-05-11 21:54
Here's the OnDeliverMessage script I wrote today to hook SpamAssassin into hMail v4.
This is a first run, there some changes I know I want to make, but it's working. I've also only written 2 or 3 VBScripts in my life so I don't know the language too well, if people see places for improvement, let me know.
This builds on the examples in this thread and adds support for emailing into SpamAssassin's bayesian learning script. This uses a setup with spamd running in cygwin as a service, called by WinSpamC.
You'll need to edit the learning addresses and path to WinSpamC for your application (at least).
	' set some default values
	spamAddress = "report_spam@[mydomain.com]"
	hamAddress  = "report_ham@[mydomain.com]"
	fname = oMessage.filename
	Dim infile, outfile
	Dim fso
	If Not fso.fileexists(fname) then
		result.Value = 0
		Exit Sub
	infile = fso.GetAbsolutePathname(fname)
	Dim cmd,sh,rc
	fso.MoveFile infile,testfile
	' LEARN IF NECESSARY
	Dim oRecipients
	Set oRecipients = oMessage.Recipients
	For i = 0 to oRecipients.Count - 1
		Dim sAddress
		sAddress = oRecipients.Item(i).Address
		If sAddress = spamAddress Then
			LearnSpam( testfile )
			result.Value = 1
		If sAddress = hamAddress Then
			LearnHam( testfile )
			result.Value = 1
	cmd = "cmd /c D:\WinSpamC\WinSpamC.exe -t 15 -x < """ & testfile & """ > """ & infile & """"
	Set sh = CreateObject("WScript.Shell")
	rc = sh.Run( cmd, 0, TRUE )
	'msgbox rc
	' Uncomment if you want to reject spam
	'If rc = 1 Then
	'	result.Value = 1
	'	Exit Sub
	'End If
	fso.DeleteFile testfile
	Set fso = Nothing
	result.Value = 0
Sub LearnHam( f )
	Dim lrnCom
	lrnCmd = "cmd /c perl -T -S sa-learn --ham """ & Replace( f, "\", "\\" ) & """"
	Dim lrnSh, lrnRc
	Set lrnSh = CreateObject( "WScript.Shell" )
	rc = lrnSh.Run( lrnCmd, 0, True )
Sub LearnSpam( f )
	Dim lrnCmd
	lrnCmd = "cmd /c perl -T -S sa-learn --spam """ & Replace( f, "\", "\\" ) & """"
	Dim lrnSh, lrnRc
john25uk
Post by john25uk » 2005-05-12 16:17
I thought that learning for forwarded messages is not a good idea? (Because the email address will be your own)
One way to do it would be to forward the un caught spam as a attachment, extract the attachment and then learn that one?
I have been meaning to do somthing similar for ages, but never got around to it! (usual story)
John 8)
thegregor
Post by thegregor » 2005-05-12 17:10
You want to redirect the message in your mail client, not forward it.
g.
john25uk
Post by john25uk » 2005-05-12 17:15
Where do you do that then?
I can see no "Redirect" button in Thunderbird (Maybe I am being a dumbass today!)
John 8)
thegregor
Thunderbird redirect extension
Post by thegregor » 2005-05-12 19:48
Yes, it's an odd omission in Thunderbird. Most other clients have it built-in.
You need this extension:
http://mailredirect.mozdev.org/
g.
john25uk
Post by john25uk » 2005-05-12 20:49
cool, thanks.
John 8)
mirb
attachment truncated
Post by mirb » 2005-05-27 19:13
installed spamassassin version 3.0.3 under cygwin and winspamc; attachments are truncated after passing trough spamc/spamd/spamassassin; even if i use the wspamd.bat modified... anyone?
GlenC
Re: attachment truncated
Post by GlenC » 2005-05-27 23:38
mirb wrote:installed spamassassin version 3.0.3 under cygwin and winspamc; attachments are truncated after passing trough spamc/spamd/spamassassin; even if i use the wspamd.bat modified... anyone?
I am a glutton for punishment sooo, I installed 3.0.3 :) But, I'm not having the problem with truncated attachments. I only tried a few though so I might be in for a surprise treat later. Anything in particular that the attachments might have in common that I can try?
My current setup:
Spamassassin/Spamd ver. 3.0.3
Spamc (I think I built this version from 3.0.2 but it made no difference with my previous truncation problems)
cygwin dll 1.5.17-1
EDIT: oops, I lied... kinda. It wasn't truncating the files but it wasn't actually working either. It was giving me back my original message with no mark-up.
Using SA 3.0.3 and the modified spamd (bugfix) it is now working properly. I don't know why they didn't fix the bug in 3.0.3 but apparently it will be fixed in 3.1. Anyway, copy everything from this link and paste it into your spamd file. Here's the link from bugzilla.spamassasin.org
http://bugzilla.spamassassin.org/attachment.cgi?id=2588
mirb
Post by mirb » 2005-05-28 05:49
glenc: you talked about spamc built from spamassassin source? don't you use winspanc.exe adapted version for windows (http://sourceforge.net/projects/winspamc) instead?
GlenC
Post by GlenC » 2005-05-28 14:27
mirb wrote:glenc: you talked about spamc built from spamassassin source? don't you use winspanc.exe adapted version for windows (http://sourceforge.net/projects/winspamc) instead?
When I was having troubles (like yours) about a month ago, I built spamc in an effort to fix the problem. I later found out the problem was actually with spamd. I just never changed back to winspamc. It made no real difference so I kept it.
Did you try the bugfix for spamd and did it correct your problem?
mirb
Post by mirb » 2005-05-28 14:56
i always used spamd bugfixed version, but problem is not corrected
GlenC
Post by GlenC » 2005-05-28 16:04
hmmm... I'm at a loss then. Are you getting errors in your eventlog that contain something similar to this?
The following information is part of the event: spamc : PID 4596 : failed sanity check, 41425 bytes claimed, 40401 bytes seen.
devil_dog
Re: SPAMASSASSIN for hMailServer
Post by devil_dog » 2005-06-21 18:23
john25uk wrote:Hi there, just incase anyone was wondering how to - I created a directory (which is shared to my network) on my server with two subs, one called SPAM, the other HAM (EG C:\SALEARN\SPAM). They are for users to copy examples of spam that they recieve that hasn't been marked, and also for examples of regular 'proper' mail so SA can tell the difference. Then i created a batch file on a scheduler to update the database twice a day (to save logging onto the server and doing it manually) The Batch file I use can be downloaded from HERE
i just installed the SM and its workin gr8....
i wanna use that script of yrs....
i have loads of spam to train SA on....but the problem is from outlook or outlook express i can get only .msg files....not .eml files....
will yrscript work if i use it wid msg files??
even if i rename *.eml with *.msg can spamassassin process the .msg files??
btw tx a lot for the detailed guide....
devil_dog
Post by devil_dog » 2005-06-21 18:44
E:\spam>spamlearn
E:\spam>Rem Put SET RES_NAMESERVERS here
E:\spam>REM where SET RES_NAMESERVERS=158.152.1.58
LEARNING NEW NON-SPAM
Use of uninitialized value in concatenation (.) or string at C:/Perl/lib/File/Sp
ec/Win32.pm line 291.
Learned from 0 message(s) (0 message(s) examined).
New HAM Learned
LEARNING NEW SPAM
New SPAM Learned
E:\spam>
is this normal....
i put in abt 9 MB of spams/non spams....
GlenC
Re: My OnDeliverMessage script, with learning support
Post by GlenC » 2005-06-30 04:37
thegregor wrote:Here's the OnDeliverMessage script I wrote today to hook SpamAssassin into hMail v4.
thegregor,
Thanks for this mod, I finally got around to implementing it and I like it a lot. I made a few modifications, one was to delete the tmp files in the data directory. Other things I added are just some of my own preferences.
One thing that caused me a lot of grief when trying to implement this was the recipient part. Maybe because I have a catch-all address, but until I actually added accounts in my domain for the users "report_spam" and "report_ham", the recipient was always MY account, thus the script was aborting. After adding those accounts everything worked fine. Here's my latest version of the script:
(PS If anyone sees improvements to make here, or stupid code, please let me know... I'm a copycat coder and do a lot of things I probably shouldn't) :roll:
' set addresses for Spam-Ham reporting (modify these)
spamAddress = "report_spam@yourdomain.com"
hamAddress  = "report_ham@yourdomain.com"
Dim infile, testfile
Dim fso
Set fso = createobject("Scripting.FileSystemObject")
	result.Value = 0
	Exit sub
infile = fso.getabsolutepathname(fname)
fso.CopyFile infile, testfile
'LEARN IF NECESSARY
dim oRecipients
set oRecipients = oMessage.Recipients
for i = 0 to oRecipients.Count - 1
  dim sAddress
	fso.Deletefile testfile
	Set fso = Nothing
  result.Value = 1
	Set fso = Nothing
	result.Value = 1
'DENY CHECKS FOR MAIL FROM LOCAL DOMAIN
Dim s1, ts1, SearchString
Const ForReading = 1
Set ts1 = fso.OpenTextFile(fname, ForReading)
s1 = ts1.ReadLine
ts1.Close
'SearchString = whatever your machine inserts in the msg (modify this)
SearchString ="Received: FROM [192.168.1."
If InStr(1, s1, SearchString, 1) > 0 Then
	'Comment next two lines to allow local domain spam checks
	Set fso = Nothing
	Exit Sub
'CALL SPAMASSASSIN (modify as required)
Dim cmd, cmd1, rc, rc1, sh
cmd = "cmd /c spamc -E -s 512000 < """ & testfile & """ > """ & infile & """"
cmd1 = "cmd /c perl -S -T -w spamassassin < """ & testfile & """ > """ & infile & """"
If rc = 0 Then									'Do something for HAM
	ElseIf rc = 1 Then						'Do something for SPAM
		'Uncomment next two lines to reject spam
		' result.Value = 1
		' Exit Sub
	Else  rc1 = sh.Run( cmd1 , 0 , TRUE)			'There was an error, call SpamAssassin directly
If fso.GetFile(infile).Size = 0 Then		'Failsafe: In the event an error causes a zero byte msg
	fso.CopyFile testfile, infile
End if
Set fso = Nothing
result.value = 0
Sub LearnHam( f )
   Dim lrnCmd
   lrnCmd = "cmd /c perl -T -S sa-learn --ham """ & Replace( f, "", "\" ) & """"
   Dim lrnSh, lrnRc
'   MsgBox "Learning Ham, RC=" & rc,0,"Woohoo HAM!"
Sub LearnSpam( f )
   Dim lrnCmd
   lrnCmd = "cmd /c perl -T -S sa-learn --spam """ & Replace( f, "", "\" ) & """"
   Dim lrnSh, lrnRc
'   MsgBox "Learning Spam, RC=" & rc,0,"Boohoo SPAM!"
bazporter
Post by bazporter » 2005-07-05 21:25
Great script.
One question with regard to the learn ham/spam process.
You are still picking up the message and parsing that for the learning process, so presumably you are relying on the message being forwarded inline? This will lose virtually all the original headers and may affect the efficiency of SpamAssassin.
Is there a way to be able to extract an attachment from a message and then process that, as that would allow users to forward the mails as attachments which would capture the full headers?
GlenC
Post by GlenC » 2005-07-06 02:15
I'm using the Redirect extension for Thunderbird which thegregor suggested further up in the thread. I don't think it changes the headers much. I think it adds one x-header.
I don't think you can currently extract the attachment (somebody correct me if I'm wrong)
GlenC
Post by GlenC » 2005-07-07 15:29
Didn't notice this until now, my script is not deleting tmp files for outgoing (local) msgs. These lines:
	Set fso = Nothing
	Exit Sub
Should be changed to this:
	'Comment next three lines to allow local domain spam checks
	Set fso = Nothing
	Exit Sub
FAWTS
Post by FAWTS » 2005-07-12 12:01
Well, those 2 pages are very interresting. I start with the begining, and I got lost after the creation of spam and ham folders...
Is there one of you nice enough to make a HOW TO as the one in the begining of the topic with all the upgrade you made?
Thanks a lot!!!!!!!!!!!!!!!!
FAWTS
Post by FAWTS » 2005-07-13 14:17
I found a solution to my problem : ASSP, just go to http://www.hmailserver.com/forum/viewtopic.php?t=1881 it is more complete than the how to http://www.hmailserver.com/documentatio ... o_use_assp and it works perfectly! :lol:
GlenC
Re: User Preferences instead local.cf
Post by GlenC » 2005-10-07 01:02
mirb wrote: the only one, and pretty good, i was able to run is:
http://www.aub.dk/~misak/index.php?cat=6
changing some code parts..
mirb, if you are still around, and still using phpsaadmin to set userprefs, could you let me know what code parts you had to change to make it work?
Thanks,
Glen
PeterK2003
spam assassin & clam win
Post by PeterK2003 » 2005-11-03 22:38
Is it poosible to run clamwin and spam assassin at the same time since you need to use the external scanner box for spam assassin?
GlenC
Post by GlenC » 2005-11-03 23:59
You don't need to use the external box for SA if you set it up to run in the eventhandler script. Somewhere buried in these two pages are instructions to do it that way.
TheAngryPenguin
Post by TheAngryPenguin » 2005-11-04 04:35
Sorry to chime in so late in the game -- I have only recently become interested in trying to get SA running in a Windows environment. Have any of you seen SpamAssassin for Win32 (or SpamAssassin POP3 Proxy for Win32)? I've been testing the latter with some other mail server (sorry Martin) and it seems to work rather well, albeit slow. Wouldn't something like what Eugene Pivovarov has been working on be much more easy to implement with hMS than what's been already been discussed?
GlenC
Post by GlenC » 2005-11-04 14:48
Wow, this will be nice if it really works as advertised. Sounds like the installation will be much simplified without all the perl/cygwin crap to deal with.
jnolan
Post by jnolan » 2005-11-08 17:53
Link to step 6 is dead. Does anyone know of another place to find the tutorial?
GlenC
Post by GlenC » 2005-11-09 02:43
PeterK2003
Post by PeterK2003 » 2005-11-24 19:49
i have sucessfully used SpamAssassin for Win32 with this script:
' End Sub
Dim commandln, infile, testfile, fso
Set commandln = CreateObject( "WScript.Shell" )
res = commandln.Run("cmd /c spamc < " & testfile & " > " & infile & "", 0, true)
res = commandln.Run("cmd /c ", 0, true)
fso.DeleteFile testfile, true
'Sub OnDeliverMessage(oMessage)
'End Sub
The only problem i see is that it seems to scan both outgoing and incoming mail.
I also haven't figured out how to submit spam that isn't caught so that it can learn and false positives so that it won't catch them in the future.
If any one knows that anwsers to thoe questions let me know.
GlenC
Post by GlenC » 2005-11-24 21:16
I'll post some portions of the script which I was experimenting with. Perhaps you can do something with them to work it out. I can't guarantee they work anymore as I haven't been using them for a while. To skip checks on the local domain:
s1 = ts1.ReadLine
ts1.Close
SearchString ="Received: FROM [192.168.15.1"
	Set fso = Nothing
	Exit Sub
As for training... probably the best way is using Sa-learn. There are some who redirect their messages via a "bounce" but I personally think this probably negatively affects the bayes database. If you'd like to play with that here is some more code that you can tinker with. Again, not sure if it still works or not as I don't use it anymore. This also requires SpamD (which I see that you are using) This code was borrowed from Devil_Dog above and modified somewhat:
'LEARN IF NECESSARY
spamAddress = "report_spam@example.com"
hamAddress  = "report_ham@example.com"
forgetAddress = "report_forget@example.com"
dim oRecipients
  dim sAddress
	Dim Spam_cmd, Spam_rc
	Spam_cmd = "cmd /c spamc -L spam -u username < """ & testfile & """"
	Spam_rc = sh.Run( Spam_cmd , 0 , TRUE)
	'MsgBox "Spam, RC=" & Spam_rc,0,"Learned SPAM"
	Set fso = Nothing
  result.Value = 1 'Set to 1 to delete msg
  Exit Sub
	Dim Ham_cmd, Ham_rc
	Ham_cmd = "cmd /c spamc -L ham -u username < """ & testfile & """"
	Ham_rc = sh.Run( Ham_cmd , 0 , TRUE)
	'MsgBox "Ham, RC=" & Ham_rc,0,"Learned HAM"
	Set fso = Nothing
	Exit Sub
If sAddress = forgetAddress Then
	Dim Forget_cmd, Forget_rc
	Forget_cmd = "cmd /c spamc -L forget -u username < """ & testfile & """"
	Forget_rc = sh.Run( Forget_cmd , 0 , TRUE)
	'MsgBox "Forget, RC=" & Forget_rc,0,"Msg Unlearned"
	Set fso = Nothing
	Exit Sub
I don't think I ever got the "Forget" command to work right so it might help to worry about that portion last.
GlenC
Post by GlenC » 2005-11-25 16:19
For those of you using the Cygwin version of SpamAssassin, you might like to try this ClamAV plugin http://wiki.apache.org/spamassassin/ClamAVPlugin I've been using it for about a day now and it appears to work pretty well. Here's some of the advantages I think this has over the regular way of scanning:
Mail is only passed off in one operation... potentilally saving a few cpu cycles.
Instead of deleting the mails, or attachments, it inserts a "X-Spam-Status Yes" header which you can test for. With a little script work, you should be able to move those messages to a quarantine area for observation, validation or delete them or whatever.
Personally, I only did it to see if it worked, and I kinda like it.
Couple of things about installing. You of course need to be runnning Clamd to use it. You also need to install a perl module - File::Scan::ClamAV - from cpan. However, the tests run by the installation for that module fail (because it tries to connect to ClamAV through a socket vice TCPIP). But you can just force the install and it works fine.
GlenC
Re: SpamAssassin for Win32
Post by GlenC » 2005-11-26 18:19
PeterK2003 wrote: The only problem i see is that it seems to scan both outgoing and incoming mail.
I did a little testing and due a recent change Martin made to the header structure, the "Deny Checks For Local Domain" code I posted above won't work anymore. (It was really not a good way to do that anyway) I've been testing the following code and it works well for me:
'SKIP SPAM CHECKS ON OUTGOING MAIL
Dim s1, SearchString
s1 = oMessage.HeaderValue("Received")
'SearchString = Modify this to a unique, unchanging portion of the "Received: from" header inserted by hMailserver
SearchString = "from [192.168.15.153] ([127.0.0.1]) by Yourdomain.com with hMailServer"
' Comment out the next two lines if you don't want a header created
  oMessage.HeaderValue("X-SpamCheck-Status") = "Spam checks skipped,on mail sent from local domain"
  oMessage.Save()
'  fso.Deletefile testfile 'uncomment this if you previously created "testfile"
	Set fso = Nothing
	Exit Sub
Post by martin » 2005-11-28 22:43
Are you guys trying to take a world record in writing a long thread? :)
Something tells me that I should write together a short summary.. if I just get the time to read through the entire thread... :)
GlenC
Post by GlenC » 2005-11-28 23:24
:roll:
I did post a new summary on cygwin installs. Maybe someone could do one for the installs using Activestate perl and you can trash this thread altogether.
bazporter
Post by bazporter » 2005-11-29 00:12
If you want a really long thread I could post my complete EventHandler script which also does basic auto-responder, whitelist, blacklist, spamassassin/spamc, and allows non-sa processing for local users. That might add a bit! :-)
Slug
Post by Slug » 2005-11-29 06:16
martin wrote:Are you guys trying to take a world record in writing a long thread? :)
No, it just proves that spam is a big issue, thats why these guys are trying so hard to make this work.
Michael
GlenC
Post by GlenC » 2005-11-29 22:54
Updated URLs for Step 6 of the John25uk's original post:
These are good references / tools for SA with an ActiveState Perl installation.
SpamAssassin 3.10 (Using SpamAssassin with Win32) http://64.142.36.76/howtosa310.html
SpamAssassin Configuration Tool (SaConf) http://64.142.36.76/saconf.html
vdrew
Issues Running spamd as Service with cygrunsrv
Post by vdrew » 2005-12-10 12:48
Hi!
I've been following along and have setup cygwin and spamassassin. It's all working great except I can't get it to work as a service using cygrunsrv... I'm using (as suggested by purplebear):
cygrunsrv -I Spamassassin -p /usr/bin/spamd -a "-c /etc/mail/spamassassin -s /var/log/spamd.log"
The command is sucessful and the service appears in the services admin. When I run it however, it says "Could not start the SpamAssassin service on Local Computer. Error 1053: The service did not respond to the start or control request in a timely fashion."
I should also mention that if from the cygwin shell i run:
/usr/bin/spamd -c /etc/mail/spamassassin -s /var/log/spamd.log
everything works perfectly, spamd starts, processes requests from winspamc and logs correctly.
Can anyone offer a suggestion... please.. i've been googling for hours! LOL
Thanks muchly!
Andrew
GlenC
Post by GlenC » 2005-12-10 15:28
It is probably a permission problem. With cygwin it's important when troubleshooting that you use the same user for everything. What I do is load spamd like this
cygrunsrv -I SpamD -p /usr/bin/spamd -a "-l -s /var/log/SpamD.log -u username --round-robin"
and I use MY username (cygwin username). That way when I do anything from the shell it is the same as doing it with the service. This also means that when you call spamc from the eventhandler script, you should call it with a -u username also, like so
cmd = "cmd /c spamc -E -u username < """ & testfile & """ > """ & infile & """"
(note: --round-robin is only used with SA 3.1, and only because the default method of spawning children has problems. Roundrobin is the old style and works fine, just a little less efficient)
dila125
Post by dila125 » 2006-01-03 06:14
I've read through all the posts in this thread and using the various code samples I have created the following code to run SA with no checking on outgoing emails. Thanks very much to the users (especially Glen) who posted the code originally :D .
  Dim fso
    result.Value = 0
    Exit sub
  SearchString = "FROM [81.178."
    'Comment out the next two lines if you don't want a header created
    oMessage.Save()
    Set fso = Nothing
    Exit Sub
  'cmd = "cmd /c spamc -E -s 512000 < """ & testfile & """ > """ & infile & """"
  rc = sh.Run( cmd1 , 0 , TRUE)
    ' result.Value = 1
    ' Exit Sub
    'rc1 = sh.Run( cmd1 , 0 , TRUE)         'There was an error, call SpamAssassin directly
  End if
  Set fso = Nothing
  result.value = 0
I now want to add to this script, so that if SA finds spam then it is copied to me and not the intended recipient.
Is this possible? Any advice would be much appreciated.
GlenC
Post by GlenC » 2006-01-03 16:18
I can't think of an easy way to do it. If we had this feature: http://www.hmailserver.com/forum/viewto ... ight=event (vote for it) then it would be easier, you could just set a global rule based on the headers created by SA.
You may be able to do something with the "ElseIf rc = 1 Then 'Do something for SPAM" line, but it would get pretty complicated if you had more than a few recipients.
elpresidente
Post by elpresidente » 2006-01-04 22:29
I have gone through the tutorial and upon testing, received blank emails.
hmail logs show code return of 7
"DEBUG"	2556	"2006-01-04 12:49:41.343"	"CustomVirusScanner::Scan()"
"DEBUG"	2556	"2006-01-04 12:49:41.531"	"CustomVirusScanner::Scan() - c:\windows\system32\cscript.exe //nologo c:\sa.vbs C:\Program Files\hMailServer\Data\{ACF25BD6-9DBE-45A7-94FA-091CBAEE9239}.eml - Returned 7"
"DEBUG"	2556	"2006-01-04 12:49:41.531"	"CustomVirusScanner::~Scan()"
Any suggestions would be helpful.
GlenC
Post by GlenC » 2006-01-04 22:58
Blank emails can occur if for some reason SA is not working (or getting called properly). I would suggest not using the CustomVirusScanner method and using a script in your eventhandlers.vbs to call spamassassin. The post above yours by dila125 is a good example for a script that you can modify to work for you. However, I just looked through it though and I noticed that two lines need to be uncommented in order to work properly.
and
The sa.vbs script that John25UK made was good when it was written but I think maybe some things have changed since then. (besides, eventhandlers gives you more control).
elpresidente
Post by elpresidente » 2006-01-05 18:06
GlenC wrote:Blank emails can occur if for some reason SA is not working (or getting called properly). I would suggest not using the CustomVirusScanner method and using a script in your eventhandlers.vbs to call spamassassin. The post above yours by dila125 is a good example for a script that you can modify to work for you. However, I just looked through it though and I noticed that two lines need to be uncommented in order to work properly.
and
Thanks. This seems better. I have tried it out but I also uncommented the following 2 lines(they were commented out):
    result.Value = 1
    Exit Sub
Unfortunately, now every email sent or received from outside is stopped.
"DEBUG"	8128	"2006-01-05 11:06:54.250"	"RuleApplier::~ApplyRules"
"APPLICATION"	8128	"2006-01-05 11:06:54.281"	"SMTPDeliverer - Message 7054: Message deleted. Action was taken by script subscribing to OnDeliverMessage."
dila125
Post by dila125 » 2006-01-05 18:40
I had those lines commented because when using the spamc command, the mail was delivered without being spam checked. I therefore used the direct spam assassin command.
elpresidente
Post by elpresidente » 2006-01-05 20:53
dila125 wrote:I had those lines commented because when using the spamc command, the mail was delivered without being spam checked. I therefore used the direct spam assassin command.
It appears that I am having that same issue. With those 2 lines commented, email is not being spam checked. With them uncommented, all emails are rejected.
I admit that I have no experience with these type of scripts. Any suggestions would be helpfull.
GlenC
Post by GlenC » 2006-01-05 21:03
elpresidente: Those lines are meant to delete the message. Result.Value = 1 means to discard the message. You can comment them out, or change it to Result.Value = 0 if that is not the solution you are wanting.
dila125: you are correct, the full script has two pairs of commands, but in the example you posted above you have mismatched the pairs. In effect, when it runs the line "rc = sh.run....." it will not find the command to expand to because it is commented out (i.e. "cmd = cmd /c......". In other words, cmd and rc are a pair, and cmd1 and rc1 are a pair.
Edit: ok... I see how you did it now. you modifed the rc line to use cmd1 instead of cmd. elpresidente... you will need to change that line also. It should be
I'm not sure why spamc wouldn't work for you. I haven't run it in this way in a while. Perhaps I need to try this script myself again and see if it needs tweaking.
GlenC
Post by GlenC » 2006-01-06 00:30
ok... I had to go back and research some things.... When you run SpamC, if you use the -E switch, it will return via the rc code a "1" if the message was spam, and a "0" if the message is ham OR if an error occurs.
If you run SpamC with the -x -E swtiches (both) it will then return a "1" for spam, a "0" for ham, and something greater than "1" for an error.
So, the IF/ELSEIF/ELSE checks the RC for 0, then 1, and if not either of those then there must have been a SpamD communication failure and it will call SpamAssassin directly.
Of course, using one or both switches results in a tradeoff... using -E alone will only return a 1 or a 0, so there is NO indication of a failure that will call spamassassin directly.
However, if you use -x -E, then you no longer have what is known as "Safe Fallback" mode (the message is returned unaltered in the case of an error) and the message NEEDS to be resubmitted and scanned by SpamAssassin directly.
I know it's a little confusing, especially because this thread is cut and pasted to death! But, personally I just use SpamC with the -E swtich now and allow it to do its Safe Fallback mode if something goes wrong. There was a time for me when SpamD wasn't reliable and I needed the extra check to make sure mail got scanned, but nowadays it is solid as a rock (knock on wood).
Hope this helps.
elpresidente
Post by elpresidente » 2006-01-06 16:22
I'm starting to think that I might want to install cygwin now. I assume I need to remove activestate's perl - not sure the best way to do that. Is this a good idea or should I stick with what I have and try to get the script working right?
GlenC
Post by GlenC » 2006-01-06 16:39
I think plenty of people have SA working with Activestate Perl. Can you post the relavant portions of your eventhandlers.vbs? Maybe something will be easier to pinpoint then.
elpresidente
Post by elpresidente » 2006-01-06 17:31
I had done a little tinkering but have revertted back to this:
  Dim fso
    result.Value = 0
    Exit sub
    oMessage.Save()
    Set fso = Nothing
    Exit Sub
    ' result.Value = 1
    ' Exit Sub
  End if
  Set fso = Nothing
  result.value = 0
Which does not appear to stop the sample spam messages I send from an external account.
