Can I install hMailServer in Windows XP SP2 Professional
Othenz
Post by Othenz » 2007-03-20 15:24
Just want to know if I can install hMailServer in Windows XP Professional with IIS6.[/list]
fileman
Post by fileman » 2007-03-20 16:10
xp pro as IIS 5.1
http://www.hmailserver.com/documentatio ... quirements
first read documentation and than post in forum, please
[PT]Cableguy
Re: Can I install hMailServer in Windows XP SP2 Professional
Post by [PT]Cableguy » 2007-03-20 16:40
Othenz wrote:Just want to know if I can install hMailServer in Windows XP Professional with IIS6.
Yes you can...i did. :wink:
aka: Bruno Vaz
hMailServer-4.3.1-B253 + phpwebadmin + roundcubemail-0.1beta2.2 + clamwin-0.88.7
wainman
Post by wainman » 2007-03-21 11:35
Attention: default max connections count of XP is 10.
fileman
Post by fileman » 2007-03-21 18:27
I don't remember where but I've read that is possible to increase limit of 10 connection
Post by ^DooM^ » 2007-03-21 21:07
brashquido
Post by brashquido » 2007-03-21 21:08
No it isn't, it is hardcoded into the executables in IIS 5.1.
Post by ^DooM^ » 2007-03-21 21:10
http://www.speedguide.net/read_articles.php?id=1497
This article however shows that you can. Use it at your own risk.
brashquido
Post by brashquido » 2007-03-21 21:37
yeah, good luck with that :). Not a chance I'd be doing that on a system I value.
Post by ^DooM^ » 2007-03-21 21:50
brashquido wrote:yeah, good luck with that :). Not a chance I'd be doing that on a system I value.
Me either ;)
chanas
Post by chanas » 2007-03-23 09:16
It works though :)
But if we are talking about a mail server doing more than 10 concurrent outbound connections then probably you should be looking at it more seriously.
Slug
Post by Slug » 2007-03-23 10:02
I thought we went through this before
Both XP & 2000 allow unlimited incoming TCP/IP connections (for P2P etc).
Both XP & 2000 have a maximum of 10 connections to network shares on a PC (for sharing files etc).
Michael
raymond
Post by raymond » 2007-03-23 10:11
Slug wrote:Both XP & 2000 allow unlimited incoming TCP/IP connections (for P2P etc).
Win XP SP2 introduced this limitation and changed the number of possible TCP connection attempts per second to 10 (from unlimited in SP1). This is Microsoft so called way of "reduce the threat" of worms spreading fast without control.
2000 hasn't been tweaked/changed so it should still allow unlimited incoming TCP/IP connections for P2P, etc.
Slug
Post by Slug » 2007-03-23 10:25
raymond wrote: Win XP SP2 introduced this limitation and changed the number of possible TCP connection attempts per second to 10 (from unlimited in SP1).
Yes you are correct, but a limit of 10 per second is not a limit of 10 connections in total, which is what they are discussing
Michael
Edit: If you are running system that needs more then 10 connections a sec, then you really do need to be on a better OS the XP or 2000.
Post by katip » 2007-03-23 21:01
There is a tool named XP-Antispy which provides (as a bonus) an option to increase the number of TCP connections on an XP (even up to unlimited). Freeware. Just google :)
BOOZy
Post by BOOZy » 2007-03-26 12:28
There are several tools that work with stable results.
However, if you run Windows update on your machine, and the TCP/IP stack gets updated, which is done quite often, the limitation is right back.
So make a note for yourself not to forget to reapply the patch after each update.
