Upgrading from 3.2 to 3.2.2 - Build 30
ansu2723
Post by ansu2723 » 2004-09-25 11:16
Hello!
Can I install this over my installed hMailServer? Will all settings and acounts still be there?
Best regards
Andreas Sund
Post by martin » 2004-09-25 14:20
Sure. It's always possible to upgrade to a newer version without losing any settings or accounts. Just do a backup first if something goes wrong..
ansu2723
Backup
Post by ansu2723 » 2004-09-26 12:56
Is it enough to copy the entire hmailserver folder?
layer
Re: Backup
Post by layer » 2004-09-26 13:26
ansu2723 wrote:Is it enough to copy the entire hmailserver folder?
yes... but if you have one external MySql server you need make one backup of the hMailserver database...
