"You do not have access to this property / method"
vpiscitelli
Post by vpiscitelli » 2006-11-13 00:18
Just upgraded to hMailServer 4.3 - Build 246 from hMailServer 4.2.2 - Build 199. Copied the phpWebAdmin folder. Now, when I tried to log in using my email address and password (this worked before) I get this.
Warning: (null)(): Invoke() failed: Exception occurred. Source: hMailServer COM library Description: You do not have access to this property / method. Ensure that hMailServer.Application.Authenticate() is called with proper login credentials. in C:\Program Files\Apache Group\Apache2\htdocs\<my domain>.com\html\phpWebAdmin\login.php on line 77
Fatal error: Call to a member function on a non-object in C:\Program Files\Apache Group\Apache2\htdocs\<my domain>.com\html\phpWebAdmin\login.php on line 78
I saw the post [HMS 4.3] Fatal error: Uncaught exception 'com_exception' but I am using Apache on 2003 Server and have copied the folder over.
Any ideas??
Re: "You do not have access to this property / method&q
Post by ^DooM^ » 2006-11-13 00:29
vpiscitelli wrote:Just upgraded to hMailServer 4.2.2 - Build 199 from hMailServer 4.3 - Build 246. Copied the phpWebAdmin folder. Now, when I tried to log in using my email address and password (this worked before) I get this.
You mean you have upgraded TO 4.3 from 4.2.2?
If so take a look at this.
http://www.hmailserver.com/documentatio ... hpwebadmin
cveillon
Post by cveillon » 2006-11-13 00:29
hMailServer 4.4.1-B273 Built-in MySQL
3 ea prod mx servers on XP Home, 1 ea on Win2k
vpiscitelli
Post by vpiscitelli » 2006-11-13 00:41
^DooM^ - I did go through the install doc and have everything configured as specified in the doc. Never touched DCOM permissions as I am not using IIS but Apache.
cveillon - The solution in that post was that he forgot to copy the newest phpWebAdmin folder. I have done that.
cveillon
Post by cveillon » 2006-11-13 23:53
Very strange. :roll:
I would double check these steps (excerpt from docs - thanks Doom) being very careful for mistyping:
# The file config.php contains the basic settings for PHPWebAdmin and needs to be modified to correctly adjust it for your system:
* Set the value of rootpath to your root web directory where PHPWebAdmin is placed.
Example:
$hmail_config['rootpath'] = "C:/wwwroot/PHPWebAdmin/";
* Set the value of rooturl to the URL where the PHPWebAdmin will be located.
Example:
$hmail_config['rooturl'] = "http://localhost/PHPWebAdmin/";
* Specify your username and password (hMailServer 3.x).
Example:
$hmail_config['admin'] = "administrator";
$hmail_config['adminpassword'] = "mysecretpassword";
# Open up php.ini, and make sure that short_open_tag is set to On
Hope this helps. :)
Chuck
