Backup Which Directories
neoform
Post by neoform » 2006-08-11 16:56
I do daily backups of all critical stuff on my server, i was wondering what directories i should backup in hmailsevrer..
(right now i'm using an external mysql server, so i'm guessing there's no need to backup the mysql dir)
is it just the 'data' directory that needs backing up?
cveillon
Post by cveillon » 2006-08-11 17:01
Try: http://www.hmailserver.com/documentatio ... up_restore
To find your data folder, check your C:\Program Files\hMailServer\Bin\hMailServer.ini file.
hMailServer 4.4.1-B273 Built-in MySQL
3 ea prod mx servers on XP Home, 1 ea on Win2k
neoform
Post by neoform » 2006-08-11 20:33
thanks, i didn't see that page before.. :P
cveillon
Post by cveillon » 2006-08-13 06:16
You're welcome. I really like the built in back-up myself. Have you given it a try? If you do, don't forget to stop the hmailserver service first.
