regular expression doesn't seem to work
aty154
Post by aty154 » 2006-07-06 08:39
I try to use regular expression for search particular word in message body and delete that email.
Following are selection and values I give in rule
Predefined Field = body
Search type = Regular Expression
Value = \bsex\b
I want to use regular expression cause if I use contain in search type then good emails can be deleted. This is only one of rule I am using there are many rules that are using regular expression also not working.
I set rule and try to test by sending email and put word in body but rule doesn’t seem to work. Please tell me what is problem.
Post by martin » 2006-07-06 15:51
Hmm. I'm no regex expert, but I don't know of the syntax \b? Where have you found that info? I've tested that regex using a couple of online regex tests and none of them match.
As far as I know, you should use .* if you want to match any character(s). Not \b
Post by ^DooM^ » 2006-07-06 16:01
Try this regex. This will look for the word sex in your document only if there is a space preceding the word sex though.
(\s[s][e][x])
Let us know how you get on.
aty154
Post by aty154 » 2006-07-07 07:53
I try using
(\s[s][e][x])
but rule don't work
I get regular expression
\bsex\b
from Regex Buddy software
I don't understand hmailserver Documentation recommand to use regex buddy tool then why regular expression is not working.
Post by martin » 2006-07-07 09:37
aty154 wrote:I don't understand hmailserver Documentation recommand to use regex buddy tool then why regular expression is not working.
Where does the hMailServer documentation recommend this? I've searched the documentation but could not find any reference to this tool. The only thing I've found is a link to the site http://www.regular-expressions.info/. This site has many links to different 3:rd party tools and libraries. So where did you find this recommendation?
Also, that the tool you use should suggest \bsex\b sounds weird to me. To me this does not even look like a regular expression. My guess is that you've misunderstood something in the software you use.
There are several online regex tests you can use. Here's one simple:
http://www.dotnetcoders.com/web/Learnin ... ester.aspx
And as I wrote, you can use .* to match <anything>. So in your case, you should be able to use .*SEX.*
But again, I'm no RegEx expert..
Post by ^DooM^ » 2006-07-07 13:44
.*sex.* will check the whole document and if it contains the letters sex anywhere it will return true. My way of doing it was more specific and only matched true if there was a space preceding the word sex. Both of these ways should work. If I get chance over the weekend I will try this out myself.
