problems with phpWebAdmin
jaswini
Post by jaswini » 2006-05-30 06:56
i'm having problems with php WebAdmin.. my root web directory is "C:\Inetpub\wwwroot".. i ve placed the php web admin folder inside it and changed the name of the config file.. the php.ini file is in the C:\WINNT folder. i checked those settings too..
the contents of my config.php file is what is given below..
$hmail_config['rootpath'] = "C:/Inetpub/wwwroot/";
$hmail_config['rooturl'] = "http://localhost/PHPWebAdmin/";
$hmail_config['includepath'] = $hmail_config['rootpath'] . "include/";
$hmail_config['temppath'] = $hmail_config['rootpath'] . "temp/";
$hmail_config['pluginpath'] = $hmail_config['rootpath'] . "plugins/";
$hmail_config['admin'] = "admin";
$hmail_config['adminpassword'] = "admin";
$hmail_config['defaultlanguage'] = "english";
$hmail_config['defaulttheme'] = "default";
When i put http://localhost/PHPWebAdmin in the browser, i keep getting an object not found message.. can u help me out?
Post by martin » 2006-05-30 17:11
This problem is almost always caused by a spelling mistake somewhere.
Can you access http://localhost?
If you create a folder named C:\inetpub\wwwroot\test, can you then access http://localhost/test/ afterwards?
jaswini
unable to access php web admin
Post by jaswini » 2006-05-31 06:20
i have xampp installed on my windows 2000.. when i put http://localhost, my xampp home page opens up.. i tried creating a folder "test" within wwwroot, but i'm not able to access that either.. got the same error-"object not found"..
kyon21
Post by kyon21 » 2007-12-27 03:56
Same problem
danny6167
Post by danny6167 » 2007-12-30 10:30
Why are you putting your files in "C:/Inetpub/wwwroot/" ?
Did you change the default doc root in the apache config file to use this folder instead of the default one?
You should find a folder called htdocs in your xampp foler. Thats where it should go by default.
