Spamassassin New Error - Winsock Error Does Not Show
jim.bus
Post by jim.bus » 2023-03-24 21:17
This is only an informative Posting informing of what appears to be new Spamassassin behavior.
I recently switched to hMailServer 5.6.9-B2607 but I don't believe this to be the cause of this new Error. But I have not seen this new presentation of the old Winsock Error. I notice the usual Spamassassin error that periodically occurs every so often. But the error was now different. The Winsock Error message (which usually accompanies the Test Connect failure Error Message) did not produce. But the the other Error message for the Test Connect did produce. I checked my Logs and the error only occurred after the passing of the email file to Spamassassin. It occurred after there were Two (2) Spamassassin session timeouts. Spamassassin is running locally on the same computer as my hMailServer.
"DEBUG" 48888 "2023-03-23 16:07:22.121" "Creating session 1145"
"TCPIP" 48888 "2023-03-23 16:07:22.124" "Connecting to 127.0.0.1:783..."
"DEBUG" 39152 "2023-03-23 16:07:22.126" "TCP connection started for session 1145"
"DEBUG" 39152 "2023-03-23 16:07:22.128" "Sending message to SpamAssassin. Session 1145, File: D:\hMailServer\Data\{56D8A52B-4716-4088-842B-A835E20009C0}.eml"
"DEBUG" 40056 "2023-03-23 16:08:52.136" "The client has timed out. Session: 1145"
"DEBUG" 39152 "2023-03-23 16:08:57.148" "The client has timed out. Session: 1145"
"DEBUG" 39152 "2023-03-23 16:09:02.824" "Parsing response from SpamAssassin. Session 1145"
"DEBUG" 39152 "2023-03-23 16:09:02.828" "Ending session 1145"
"ERROR" 48888 "2023-03-23 16:09:02.828" "Severity: 2 (High), Code: HM5508, Source: SpamAssassinTestConnect::TestConnect, Description: The SpamAssassin tests did not complete. Please confirm that the configuration (host name and port) is valid and that SpamAssassin is running."
"DEBUG" 39152 "2023-03-23 16:09:02.829" "Connection was terminated - Client is disconnected."
"DEBUG" 48888 "2023-03-23 16:09:02.830" "Spam test: SpamTestSpamAssassin, Score: 0"
If you think you understand quantum mechanics, you don't understand quantum mechanics.
