Using clamav and it works ok but getting some false positives. An external scanner will slow everything down but the data is on a ram disk so should not be too bad.
Any one using an external antivirus that works well for them? Thought I would check here first before starting to test different scanners.
Need a good external antivirus scanner
Re: Need a good external antivirus scanner
viewtopic.php?f=7&t=36974&p=231248&hili ... ty#p231248webguyz wrote: ↑2021-05-12 16:57Using clamav and it works ok but getting some false positives. An external scanner will slow everything down but the data is on a ram disk so should not be too bad.
I don't get false positives...
I call ClamAV from hMailServer _AND_ SpamAssassin ... hMail and SpamAss use different coding so they don't allways agree!
