Header Rewrite
mikedibella
Header Rewrite
Post by mikedibella » 2020-09-14 03:35
Some messages I receive need to get hairpined to an external address and for these messages I'd like to rewrite headers:
1. Create a new header X-Original-Reply-To = Reply-To
2. Create or overwrite Reply-To with From
3. Overwrite From with the a new email address consisting of the existing Display portion of the From address, but with an internal address substituted for for original external address.
Can I do this:
A. Entirely with a rule conditions and actions
B. Using a script action triggered by a rule condition
C. only by scripting an event handler
I'd be willing to for go combining the old sender display name in requirement 3 if I could do using approach A or B.
Re: Header Rewrite
Post by mattg » 2020-09-14 04:24
The create new header requires scripting, but either option 2 or 3 would do
as for your needs....
To track which BCC recipient (mild) spam is intended for, I do this
Sub XEnvelope(oMessage)
   Dim i, strEnvelope1, strEnvelope2
      If (i = 0) Then
         strEnvelope1 = oMessage.Recipients(i).Address
         strEnvelope2 = oMessage.Recipients(i).OriginalAddress
         strEnvelope1 = strEnvelope1 & ", " & oMessage.Recipients(i).Address
         strEnvelope2 = strEnvelope2 & ", " & oMessage.Recipients(i).OriginalAddress
   oMessage.HeaderValue("X-Envelope-To") = strEnvelope1
   oMessage.HeaderValue("X-Envelope-OriginalTo") = strEnvelope2
And I know that this works to retrieve the reply to
oMessage.HeaderValue("Reply-To")
Does that get you started?
mikedibella
Re: Header Rewrite
Post by mikedibella » 2020-09-14 04:58
Thanks, Matt. That should get me started.
