How to setup alerting on failure or que backing up
amplector
Post by amplector » 2020-06-05 19:01
I just need an email notification to be able to know when email flow is stopped (delivery failure or large que). Also, if logging could possibly be sent to a syslog server, I could then setup an alert there.
I would like to know how to implement this solution completely and in the most simple way. I am on version 5.6.4-B2283. I understand that I would go to Scripts and Edit the EventHandlers.vbs file.
What is the proper or some example syntax that I would implement the function OnDeliveryFailed?
Upon researching the forums I find more advanced articles like these below and it only confuses me.
https://www.hmailserver.com/forum/viewtopic.php?t=31345
http://blog.brainsen.com/post/logging-d ... mailserver
mikedibella
Re: How to setup alerting on failure or que backing up
Post by mikedibella » 2020-06-05 19:19
Consider that if HMS can't deliver messages, you won't receive your alert notification of the same if it too is sent via email.
I wrote this a while back:
https://www.hmailserver.com/forum/viewt ... ue#p192749
I have a monitoring service running on the server that executes this little utility every so often and sends an SMS if the queue count crosses a threshold.
amplector
Post by amplector » 2020-06-08 15:10
Interesting. What are some example monitoring services that would pull this off?
Post by mattg » 2020-06-09 02:06
This was one solution posted by a user - it works great for me
https://www.hmailserver.com/forum/viewt ... se#p206767
As for notification services, there are many commercial ones, but I use 'Monit' on my Ubuntu box.
