Hi Virinum,
Thank you for replying to my message. I ran a test at
https://www.mail-tester.com and got 4.8 score. Score details are as follows. Please advice what needs to be done if you think there is room for improvement.
TEST RESULT
The famous spam filter SpamAssassin. Score: -2.2. A score below -5 is considered spam.
You are not allowed to use one of your sender email addresses -3
[SPF]mydomain.org does not allow your server xx.xxx.xxx.x to use
email@mydomain.org
Sender Policy Framework (SPF) is an email validation system designed to prevent email spam by detecting email spoofing, a common vulnerability, by verifying sender IP addresses.
Verification details:
dig +short TXT mydomain.org :
"google-site-verification=hMT2YyG4ZDCANzCsDvPgNDJKso1zuaCFa8XyQY"
"v=spf1 ip4:xx.xxx.xxx.xx a mx include:mydomain.org ?all"
dig +short TXT @ns1.mydnsserver.com. mydomain.org :
spfquery --scope mfrom --id
info@mydomain.org --ip xx.xxx.xxx.x --helo-id mail.mydnsserver.com :
permerror
mydomain.org ... mydomain.org: Maximum DNS-interactive terms limit (10) exceeded
Received-SPF: permerror (mydomain.org ... mydomain.org: Maximum DNS-interactive terms limit (10) exceeded) receiver=ns303428.ip-xx-xx-xxx.eu; identity=mailfrom; envelope-from="
email@mydomain.org"; helo=mail.mydnsserver.com; client-ip=xx.xxx.xxx.x
Your reverse DNS does not match with your sending domain.
Reverse DNS lookup or reverse DNS resolution (rDNS) is the determination of a domain name that is associated with a given IP address.
Some companies such as AOL will reject any message sent from a server without rDNS, so you must ensure that you have one.
You cannot associate more than one domain name with a single IP address.
Your IP address xx.xxx.xxx.x is associated with the domain webserver.mydnsserver.com.
Nevertheless your message appears to be sent from mail.mydnsserver.com.
You may want to change your pointer (PTR type) DNS record and the host name of your server to the same value.
Here are the tested values for this check:
IP: xx.xxx.xxx.x
HELO: mail.mydnsserver.com
rDNS: webserver.mydnsserver.com
You're not blacklisted
No broken links
