need help
raderack
need help
Post by raderack » 2020-05-26 01:21
i setup my domain raderack.zapto.org
but i cant send email using my local phpbb forum and the hmailserver
this is the log
"DEBUG"	4184	"2020-05-25 20:19:03.168"	"Creating session 20"
"TCPIP"	4184	"2020-05-25 20:19:03.168"	"TCP - 127.0.0.1 connected to 127.0.0.1:25."
"DEBUG"	4184	"2020-05-25 20:19:03.168"	"TCP connection started for session 13"
"SMTPD"	4184	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"SENT: 220 MIGUEL-PC ESMTP"
"SMTPD"	4924	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	4924	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"SENT: 250-MIGUEL-PC[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	6056	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"RECEIVED: AUTH PLAIN"
"SMTPD"	6056	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"SENT: 334 Log on"
"SMTPD"	4924	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	4924	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"SENT: 235 authenticated."
"SMTPD"	4184	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	4184	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	4924	13	"2020-05-25 20:19:03.168"	"127.0.0.1"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	4924	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	9768	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	9768	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	9768	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	4924	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"RECEIVED: DATA"
"SMTPD"	4924	13	"2020-05-25 20:19:03.178"	"127.0.0.1"	"SENT: 354 OK, send."
"DEBUG"	9768	"2020-05-25 20:19:03.178"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-25 20:19:03.178"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-25 20:19:03.178"	"Saving message: {964977FF-B782-49F8-A836-88432422EA39}.eml"
"DEBUG"	2160	"2020-05-25 20:19:03.188"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2160	13	"2020-05-25 20:19:03.188"	"127.0.0.1"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	9768	13	"2020-05-25 20:19:03.188"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	9768	13	"2020-05-25 20:19:03.188"	"127.0.0.1"	"SENT: 221 goodbye"
"DEBUG"	4184	"2020-05-25 20:19:03.188"	"Ending session 13"
"DEBUG"	7944	"2020-05-25 20:19:03.188"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	6776	"2020-05-25 20:19:03.188"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	6776	"2020-05-25 20:19:03.188"	"Delivering message..."
"APPLICATION"	6776	"2020-05-25 20:19:03.188"	"SMTPDeliverer - Message 14: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{964977FF-B782-49F8-A836-88432422EA39}.eml"
"DEBUG"	6776	"2020-05-25 20:19:03.188"	"Applying rules"
"DEBUG"	6776	"2020-05-25 20:19:03.188"	"Performing local delivery"
"DEBUG"	6776	"2020-05-25 20:19:03.188"	"Local delivery completed"
"TCPIP"	6776	"2020-05-25 20:19:03.188"	"DNS MX lookup: hotmail.com"
"TCPIP"	6776	"2020-05-25 20:19:03.498"	"DNS - MX Result: 2 IP addresses were found."
"DEBUG"	6776	"2020-05-25 20:19:03.498"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.17.161), Port: 25, Security: 2, User name: "
"DEBUG"	6776	"2020-05-25 20:19:03.498"	"Creating session 21"
"TCPIP"	6776	"2020-05-25 20:19:03.498"	"Connecting to 104.47.17.161:25..."
"DEBUG"	4924	"2020-05-25 20:19:24.537"	"SMTPDeliverer - Message 14 - Connection failed: Host name: 104.47.17.161, message: Uma tentativa de conexão falhou porque o componente conectado não respondeu[nl]corretamente após um período de tempo ou a conexão estabelecida falhou[nl]porque o host conectado não respondeu"
"DEBUG"	4924	"2020-05-25 20:19:24.537"	"Ending session 21"
"DEBUG"	6776	"2020-05-25 20:19:24.537"	"External delivery process completed"
"DEBUG"	6776	"2020-05-25 20:19:24.537"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.18.97), Port: 25, Security: 2, User name: "
"DEBUG"	6776	"2020-05-25 20:19:24.537"	"Creating session 22"
"TCPIP"	6776	"2020-05-25 20:19:24.537"	"Connecting to 104.47.18.97:25..."
"DEBUG"	4924	"2020-05-25 20:19:45.537"	"SMTPDeliverer - Message 14 - Connection failed: Host name: 104.47.18.97, message: Uma tentativa de conexão falhou porque o componente conectado não respondeu[nl]corretamente após um período de tempo ou a conexão estabelecida falhou[nl]porque o host conectado não respondeu"
"DEBUG"	4924	"2020-05-25 20:19:45.537"	"Ending session 22"
"DEBUG"	6776	"2020-05-25 20:19:45.537"	"External delivery process completed"
"DEBUG"	6776	"2020-05-25 20:19:45.537"	"Summarizing delivery result"
"DEBUG"	6776	"2020-05-25 20:19:45.537"	"Summarized delivery results"
"TCPIP"	6776	"2020-05-25 20:19:45.537"	"DNS MX lookup: gmail.com"
"TCPIP"	6776	"2020-05-25 20:19:45.617"	"DNS - MX Result: 10 IP addresses were found."
"DEBUG"	6776	"2020-05-25 20:19:45.617"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (64.233.186.26), Port: 25, Security: 2, User name: "
"DEBUG"	6776	"2020-05-25 20:19:45.617"	"Creating session 23"
"TCPIP"	6776	"2020-05-25 20:19:45.617"	"Connecting to 64.233.186.26:25..."
"DEBUG"	4924	"2020-05-25 20:20:06.617"	"SMTPDeliverer - Message 14 - Connection failed: Host name: 64.233.186.26, message: Uma tentativa de conexão falhou porque o componente conectado não respondeu[nl]corretamente após um período de tempo ou a conexão estabelecida falhou[nl]porque o host conectado não respondeu"
"DEBUG"	4924	"2020-05-25 20:20:06.617"	"Ending session 23"
"DEBUG"	6776	"2020-05-25 20:20:06.617"	"External delivery process completed"
"DEBUG"	6776	"2020-05-25 20:20:06.617"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (2800:3f0:4003:c02::1b), Port: 25, Security: 2, User name: "
"DEBUG"	6776	"2020-05-25 20:20:06.617"	"Creating session 24"
"TCPIP"	6776	"2020-05-25 20:20:06.617"	"Connecting to 2800:3f0:4003:c02::1b:25..."
"DEBUG"	4924	"2020-05-25 20:20:06.699"	"TCP connection started for session 24"
"SMTPC"	4924	24	"2020-05-25 20:20:08.239"	"2800:3f0:4003:c02::1b"	"RECEIVED: 220 mx.google.com ESMTP p19si10314276qkj.158 - gsmtp"
"SMTPC"	4924	24	"2020-05-25 20:20:08.239"	"2800:3f0:4003:c02::1b"	"SENT: EHLO MIGUEL-PC"
"SMTPC"	4924	24	"2020-05-25 20:20:08.449"	"2800:3f0:4003:c02::1b"	"RECEIVED: 250-mx.google.com at your service, [2804:14c:5b74:9db0:8051:8ee7:33ad:30f][nl]250-SIZE 157286400[nl]250-8BITMIME[nl]250-STARTTLS[nl]250-ENHANCEDSTATUSCODES[nl]250-PIPELINING[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC"	4924	24	"2020-05-25 20:20:08.449"	"2800:3f0:4003:c02::1b"	"SENT: STARTTLS"
"SMTPC"	9768	24	"2020-05-25 20:20:08.659"	"2800:3f0:4003:c02::1b"	"RECEIVED: 220 2.0.0 Ready to start TLS"
"DEBUG"	9768	"2020-05-25 20:20:08.659"	"Performing SSL/TLS handshake for session 24. Verify certificate: True, Expected remote host name: gmail-smtp-in.l.google.com"
"DEBUG"	4924	"2020-05-25 20:20:08.749"	"Certificate verification succeeded for session 24."
"TCPIP"	9768	"2020-05-25 20:20:08.829"	"TCPConnection - TLS/SSL handshake completed. Session Id: 24, Remote IP: 2800:3f0:4003:c02::1b, Version: TLSv1.2, Cipher: ECDHE-ECDSA-AES128-GCM-SHA256, Bits: 128"
"SMTPC"	9768	24	"2020-05-25 20:20:08.829"	"2800:3f0:4003:c02::1b"	"SENT: EHLO MIGUEL-PC"
"SMTPC"	9768	24	"2020-05-25 20:20:09.049"	"2800:3f0:4003:c02::1b"	"RECEIVED: 250-mx.google.com at your service, [2804:14c:5b74:9db0:8051:8ee7:33ad:30f][nl]250-SIZE 157286400[nl]250-8BITMIME[nl]250-ENHANCEDSTATUSCODES[nl]250-PIPELINING[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC"	9768	24	"2020-05-25 20:20:09.049"	"2800:3f0:4003:c02::1b"	"SENT: MAIL FROM:<enarrais@gmail.com>"
"SMTPC"	5508	24	"2020-05-25 20:20:09.269"	"2800:3f0:4003:c02::1b"	"RECEIVED: 250 2.1.0 OK p19si10314276qkj.158 - gsmtp"
"SMTPC"	5508	24	"2020-05-25 20:20:09.269"	"2800:3f0:4003:c02::1b"	"SENT: RCPT TO:<enarrais@gmail.com>"
"SMTPC"	6056	24	"2020-05-25 20:20:09.619"	"2800:3f0:4003:c02::1b"	"RECEIVED: 250 2.1.5 OK p19si10314276qkj.158 - gsmtp"
"SMTPC"	6056	24	"2020-05-25 20:20:09.619"	"2800:3f0:4003:c02::1b"	"SENT: DATA"
Re: need help
Post by mattg » 2020-05-26 01:39
Please run the internal diagnostics and post the result here
raderack
Re: need help
Post by raderack » 2020-05-26 02:03
here it is
thanks
Test: Collect server details
Database type: MSSQL Compact
Test: Test IPv6
Test: Test outbound port
Test: Test backup directory
Test: Test MX records
Trying to resolve MX records for raderack.zapto.org...
ERROR: MX records for domain raderack.zapto.org could not be resolved
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain raderack.zapto.org...
ERROR: MX records for local domain raderack.zapto.org could not be resolved
Re: need help
Post by mattg » 2020-05-26 03:30
something in your system, probably your ISP, blocks port 25 outbound
This is normal with residential style internet plans
They do this so that you can't run a mailserver
raderack
Re: need help
Post by raderack » 2020-05-26 13:15
port 25 is open in the firewall(modem).
i need more ports? for smtp
Re: need help
Post by jimimaseye » 2020-05-26 13:58
https://www.hmailserver.com/documentati ... oting_tips
In particular, the 3rd entry.
raderack
Re: need help
Post by raderack » 2020-05-26 14:51
now this appear in hmail server,i checked smtp only
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"RECEIVED: AUTH PLAIN"
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"SENT: 334 Log on"
"SMTPD"	6056	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"RECEIVED: 	raderack@localhost ***"
"SMTPD"	6056	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"SENT: 235 authenticated."
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	4184	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	9768	94	"2020-05-26 09:48:50.222"	"127.0.0.1"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	9768	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	4184	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	4184	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"SENT: 250 OK"
"SMTPD"	4184	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	9768	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"RECEIVED: DATA"
"SMTPD"	9768	94	"2020-05-26 09:48:50.232"	"127.0.0.1"	"SENT: 354 OK, send."
"SMTPD"	2160	94	"2020-05-26 09:48:50.262"	"127.0.0.1"	"SENT: 250 Queued (0.016 seconds)"
"SMTPD"	6056	94	"2020-05-26 09:48:50.262"	"127.0.0.1"	"RECEIVED: QUIT"
"SMTPD"	6056	94	"2020-05-26 09:48:50.262"	"127.0.0.1"	"SENT: 221 goodbye"
"SMTPD"	4184	95	"2020-05-26 09:48:50.482"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPC"	6056	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: 220 raderack.zapto.org ESMTP"
"SMTPC"	6056	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"SENT: HELO raderack.zapto.org"
"SMTPD"	9768	95	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: HELO raderack.zapto.org"
"SMTPD"	9768	95	"2020-05-26 09:48:50.492"	"201.80.69.207"	"SENT: 250 Hello."
"SMTPC"	4184	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: 250 Hello."
"SMTPC"	4184	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"SENT: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	9768	95	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	9768	95	"2020-05-26 09:48:50.492"	"201.80.69.207"	"SENT: 250 OK"
"SMTPC"	9768	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: 250 OK"
"SMTPC"	9768	96	"2020-05-26 09:48:50.492"	"201.80.69.207"	"SENT: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	4184	95	"2020-05-26 09:48:50.492"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	4184	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"SMTPC"	6056	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: 530 SMTP authentication is required."
"SMTPC"	6056	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	6056	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	6056	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"SMTPC"	6056	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	4924	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	4924	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"SMTPC"	4184	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: 530 SMTP authentication is required."
"SMTPC"	4184	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: QUIT"
"SMTPD"	4184	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	4184	95	"2020-05-26 09:48:50.502"	"201.80.69.207"	"SENT: 221 goodbye"
"SMTPC"	9768	96	"2020-05-26 09:48:50.502"	"201.80.69.207"	"RECEIVED: 221 goodbye"
"SMTPD"	4184	97	"2020-05-26 09:49:50.504"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPC"	4184	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: 220 raderack.zapto.org ESMTP"
"SMTPC"	4184	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"SENT: HELO raderack.zapto.org"
"SMTPD"	4924	97	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: HELO raderack.zapto.org"
"SMTPD"	4924	97	"2020-05-26 09:49:50.514"	"201.80.69.207"	"SENT: 250 Hello."
"SMTPC"	4924	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: 250 Hello."
"SMTPC"	4924	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"SENT: MAIL FROM:<>"
"SMTPD"	6056	97	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: MAIL FROM:<>"
"SMTPD"	6056	97	"2020-05-26 09:49:50.514"	"201.80.69.207"	"SENT: 250 OK"
"SMTPC"	9768	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: 250 OK"
"SMTPC"	9768	98	"2020-05-26 09:49:50.514"	"201.80.69.207"	"SENT: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	4924	97	"2020-05-26 09:49:50.514"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	4924	97	"2020-05-26 09:49:50.524"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"SMTPC"	9768	98	"2020-05-26 09:49:50.524"	"201.80.69.207"	"RECEIVED: 530 SMTP authentication is required."
"SMTPC"	9768	98	"2020-05-26 09:49:50.524"	"201.80.69.207"	"SENT: QUIT"
"SMTPD"	4924	97	"2020-05-26 09:49:50.534"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	4924	97	"2020-05-26 09:49:50.534"	"201.80.69.207"	"SENT: 221 goodbye"
"SMTPC"	4184	98	"2020-05-26 09:49:50.534"	"201.80.69.207"	"RECEIVED: 221 goodbye"
raderack
Re: need help
Post by raderack » 2020-05-26 16:48
now is getting better but still cant get delivery
any help?
APPLICATION"	3904	"2020-05-26 11:42:15.650"	"Starting servers..."
"APPLICATION"	3904	"2020-05-26 11:42:16.220"	"Servers started."
"TCPIP"	6288	"2020-05-26 11:42:59.952"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	6288	103	"2020-05-26 11:42:59.952"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	10168	103	"2020-05-26 11:42:59.962"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	10168	103	"2020-05-26 11:42:59.962"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	6288	103	"2020-05-26 11:42:59.962"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	6288	103	"2020-05-26 11:42:59.972"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	10168	103	"2020-05-26 11:42:59.972"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	10168	103	"2020-05-26 11:42:59.972"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"TCPIP"	6288	"2020-05-26 11:43:27.822"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	6288	107	"2020-05-26 11:43:27.832"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	10168	107	"2020-05-26 11:43:27.832"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	10168	107	"2020-05-26 11:43:27.832"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	6288	107	"2020-05-26 11:43:27.832"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	6288	107	"2020-05-26 11:43:27.832"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	10168	107	"2020-05-26 11:43:27.842"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	10168	107	"2020-05-26 11:43:27.842"	"201.80.69.207"	"SENT: 530 SMTP authentication is required."
"TCPIP"	6288	"2020-05-26 11:44:19.955"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	6288	108	"2020-05-26 11:44:19.965"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9296	108	"2020-05-26 11:44:19.965"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9296	108	"2020-05-26 11:44:19.965"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"RECEIVED: AUTH LOGIN"
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"RECEIVED: cmFkZXJhY2tAcmFkZXJhY2suemFwdG8ub3Jn"
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	9296	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"RECEIVED: ***"
"SMTPD"	9296	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	10168	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9296	108	"2020-05-26 11:44:19.975"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	9296	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	6288	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	6288	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	10168	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	10168	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	6288	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	6288	108	"2020-05-26 11:44:19.985"	"201.80.69.207"	"SENT: 354 OK, send."
"SMTPD"	2160	108	"2020-05-26 11:44:20.265"	"201.80.69.207"	"SENT: 250 Queued (0.240 seconds)"
"APPLICATION"	9880	"2020-05-26 11:44:20.265"	"SMTPDeliverer - Message 38: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{6B45409B-7E1F-4DEA-85AD-6E60330F0207}.eml"
"SMTPD"	10168	108	"2020-05-26 11:44:20.275"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	10168	108	"2020-05-26 11:44:20.275"	"201.80.69.207"	"SENT: 221 goodbye"
"APPLICATION"	9880	"2020-05-26 11:44:20.285"	"SMTPDeliverer - Message 38: Relaying to host raderack.zapto.org."
"TCPIP"	9880	"2020-05-26 11:44:20.285"	"Connecting to 201.80.69.207:25..."
"APPLICATION"	9880	"2020-05-26 11:44:20.345"	"SMTPDeliverer - Message 38: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"APPLICATION"	9880	"2020-05-26 11:44:20.355"	"SMTPDeliverer - Message 38: Message delivery thread completed."
Re: need help
Post by jimimaseye » 2020-05-26 17:21
raderack
Re: need help
Post by raderack » 2020-05-26 17:33
[code]2020-05-26   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - loxxxxxxx                      Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - raxxxxxx.zaxxx.orx             Enabled: True
        Greylisting:     False
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  5 Mins: 60   Plain Text:         True  Bind: 127.0.0.1
                     Host: Domain2.com         Empty sender:       True  Batch recipients:   100
                  !! POINTS TO LOCAL DOMAIN !! Disc. on invalid:  False  Delivered-To hdr: False
                     Port:  25                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-05-26.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-05-26.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
[/code]
Re: need help
Post by jimimaseye » 2020-05-26 18:08
The diagnostic shows you your errors.
SMTP
You have a relay pointing to yourself. And why have you changed the bind settings?
Learn more here and how to configure correctly: https://www.hmailserver.com/documentati ... otocolsmtp
raderack
Re: need help
Post by raderack » 2020-05-26 18:50
where i setup the relay?
looked in smtp but isnt there
is incoming delay?
Email error
» EMAIL/SMTP
/adm/index.php
Ran into problems sending email at Line 1671. Response: 535 Authentication failed. Restarting authentication process.
Backtrace
Connecting to raderack.zapto.org:25
LINE: 1204 <- 220 raderack.zapto.org ESMTP
# EHLO Miguel-PC
LINE: 1551 <- 250-raderack.zapto.org
LINE: 1551 <- 250-SIZE 20480000
LINE: 1551 <- 250-AUTH LOGIN PLAIN
LINE: 1551 <- 250 HELP
# AUTH PLAIN
LINE: 1664 <- 334 Log on
# Omitting sensitive information
LINE: 1671 <- 535 Authentication failed. Restarting authentication process.
raderack
Re: need help
Post by raderack » 2020-05-26 19:13
Email error
» EMAIL/SMTP
/adm/index.php
Could not get mail server response codes.
Backtrace
raderack
Re: need help
Post by raderack » 2020-05-26 19:58
now im geting this
"TCPIP"	5868	"2020-05-26 14:55:37.953"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	178	"2020-05-26 14:55:37.963"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9080	178	"2020-05-26 14:55:37.973"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9080	178	"2020-05-26 14:55:37.973"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5868	178	"2020-05-26 14:55:37.973"	"201.80.69.207"	"RECEIVED: AUTH PLAIN"
"SMTPD"	5868	178	"2020-05-26 14:55:37.983"	"201.80.69.207"	"SENT: 334 Log on"
"SMTPD"	6592	178	"2020-05-26 14:55:37.983"	"201.80.69.207"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	6592	178	"2020-05-26 14:55:37.983"	"201.80.69.207"	"SENT: 535 Authentication failed. Restarting authentication process."
"TCPIP"	5868	"2020-05-26 14:56:45.613"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	183	"2020-05-26 14:56:45.613"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9080	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9080	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	6592	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"RECEIVED: AUTH PLAIN"
"SMTPD"	6592	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"SENT: 334 Log on"
"SMTPD"	9080	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	9080	183	"2020-05-26 14:56:45.623"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	5868	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	5868	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9080	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	9080	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	6592	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	6592	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	5868	183	"2020-05-26 14:56:45.633"	"201.80.69.207"	"SENT: 354 OK, send."
"SMTPD"	2160	183	"2020-05-26 14:56:45.883"	"201.80.69.207"	"SENT: 250 Queued (0.240 seconds)"
"SMTPD"	5868	183	"2020-05-26 14:56:45.883"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	5868	183	"2020-05-26 14:56:45.883"	"201.80.69.207"	"SENT: 221 goodbye"
"APPLICATION"	6240	"2020-05-26 14:56:45.883"	"SMTPDeliverer - Message 53: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{D4714B4D-6E47-40DA-86CB-A95BF9683F5C}.eml"
"APPLICATION"	6240	"2020-05-26 14:56:45.893"	"SMTPDeliverer - Message 53: Relaying to host localhost."
"TCPIP"	6240	"2020-05-26 14:56:45.953"	"Connecting to 127.0.0.1:25..."
"TCPIP"	6240	"2020-05-26 14:56:45.953"	"TCPConnection - Could not connect to 127.0.0.1 on port 25 since this would mean connecting to myself."
"TCPIP"	6240	"2020-05-26 14:56:45.953"	"Connecting to ::1:25..."
"TCPIP"	6240	"2020-05-26 14:56:45.953"	"TCPConnection - Could not connect to ::1 on port 25 since this would mean connecting to myself."
"APPLICATION"	6240	"2020-05-26 14:56:45.953"	"SMTPDeliverer - Message 53: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"APPLICATION"	6240	"2020-05-26 14:56:45.953"	"SMTPDeliverer - Message 53: Message delivery thread completed."
Re: need help
Post by RvdH » 2020-05-26 20:08
You still have a relay pointing to yourself. Clearly shown in your last log
Maybe you should go back to all defaults first, you have been tampering stuff and now experience the consequences
raderack
Re: need help
Post by raderack » 2020-05-26 20:17
where i change the relay to myself?
2020-05-26 20:08
raderack
Re: need help
Post by raderack » 2020-05-26 20:21
done it.
but still dont receive email
relaying problem solved
"TCPIP"	5868	"2020-05-26 15:19:40.020"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	191	"2020-05-26 15:19:40.020"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9080	191	"2020-05-26 15:19:40.030"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9080	191	"2020-05-26 15:19:40.030"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5868	191	"2020-05-26 15:19:40.030"	"201.80.69.207"	"RECEIVED: AUTH PLAIN"
"SMTPD"	5868	191	"2020-05-26 15:19:40.030"	"201.80.69.207"	"SENT: 334 Log on"
"SMTPD"	6592	191	"2020-05-26 15:19:40.030"	"201.80.69.207"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	6592	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	5868	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	5868	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9080	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	9080	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	9080	191	"2020-05-26 15:19:40.040"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	6592	191	"2020-05-26 15:19:40.050"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	6592	191	"2020-05-26 15:19:40.050"	"201.80.69.207"	"SENT: 354 OK, send."
"SMTPD"	2160	191	"2020-05-26 15:19:40.250"	"201.80.69.207"	"SENT: 250 Queued (0.208 seconds)"
"SMTPD"	5868	191	"2020-05-26 15:19:40.250"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	5868	191	"2020-05-26 15:19:40.250"	"201.80.69.207"	"SENT: 221 goodbye"
"APPLICATION"	6240	"2020-05-26 15:19:40.390"	"SMTPDeliverer - Message 58: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{997D6D1D-2B3A-4FA3-88AF-FC3A5206E2F5}.eml"
"APPLICATION"	6240	"2020-05-26 15:19:40.400"	"SMTPDeliverer - Message 58: Relaying to host raderack.zapto.org."
"TCPIP"	6240	"2020-05-26 15:19:40.400"	"Connecting to 201.80.69.207:25..."
"APPLICATION"	6240	"2020-05-26 15:19:40.400"	"SMTPDeliverer - Message 58: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"APPLICATION"	6240	"2020-05-26 15:19:40.440"	"SMTPDeliverer - Message 58: Message delivery thread completed."
raderack wrote:
2020-05-26 20:17
2020-05-26 20:08
Re: need help
Post by RvdH » 2020-05-26 21:44
You're still relaying (to yourself), but now to raderack.zapto.org (which has no MX records)
Why do you relay?
Virinum
Re: need help
Post by Virinum » 2020-05-26 22:54
raderack wrote:
2020-05-26 20:17
Settings -> Protocols -> SMTP
Tab "Delivery of e-Mail"
Make "Remote host name" under "SMTP Relayer" empty.
raderack
Re: need help
Post by raderack » 2020-05-26 23:32
now it cant send the email,but no major errors.
what i am missing?
"TCPIP"	5868	"2020-05-26 18:31:10.678"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	6592	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	6592	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"RECEIVED: AUTH LOGIN"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	6592	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"RECEIVED: cmFkZXJhY2tAcmFkZXJhY2suemFwdG8ub3Jn"
"SMTPD"	6592	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	9800	1077	"2020-05-26 18:31:10.698"	"201.80.69.207"	"RECEIVED: ***"
"SMTPD"	9800	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	6592	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	6592	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9800	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	9800	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9800	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.708"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.718"	"201.80.69.207"	"SENT: 354 OK, send."
"SMTPD"	2160	1077	"2020-05-26 18:31:10.918"	"201.80.69.207"	"SENT: 250 Queued (0.192 seconds)"
"APPLICATION"	8456	"2020-05-26 18:31:10.918"	"SMTPDeliverer - Message 79: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{477BE9EB-AF09-4822-A39C-745DE01287DF}.eml"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.918"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	5868	1077	"2020-05-26 18:31:10.918"	"201.80.69.207"	"SENT: 221 goodbye"
"TCPIP"	8456	"2020-05-26 18:31:10.928"	"DNS MX lookup: gmail.com"
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"DNS - MX Result: 10 IP addresses were found."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 64.233.190.26:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 2800:3f0:4003:c02::1a:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 172.253.120.27:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 172.217.218.26:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 2a00:1450:4013:c08::1a:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 209.85.233.26:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 2a00:1450:4010:c03::1a:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 142.250.4.26:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"Connecting to 2404:6800:4003:c06::1a:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.718"	"DNS MX lookup: hotmail.com"
"TCPIP"	8456	"2020-05-26 18:31:11.878"	"DNS - MX Result: 2 IP addresses were found."
"TCPIP"	8456	"2020-05-26 18:31:11.878"	"Connecting to 104.47.59.161:25..."
"TCPIP"	8456	"2020-05-26 18:31:11.878"	"Connecting to 104.47.55.161:25..."
"APPLICATION"	8456	"2020-05-26 18:31:11.878"	"SMTPDeliverer - Message 79: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"APPLICATION"	8456	"2020-05-26 18:31:11.878"	"SMTPDeliverer - Message 79: Message delivery thread completed."
Re: need help
Post by RvdH » 2020-05-26 23:41
https://www.hmailserver.com/documentati ... es_outside
Maybe you should first read the documentation, find out what a mailserver is and what is needed to run one
raderack
Re: need help
Post by raderack » 2020-05-27 00:07
i read it.
got no errors in the log,but still cant send email.
"TCPIP"	5868	"2020-05-26 19:04:56.437"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	1517	"2020-05-26 19:04:56.447"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9080	1517	"2020-05-26 19:04:56.447"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9080	1517	"2020-05-26 19:04:56.447"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5868	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: AUTH LOGIN"
"SMTPD"	5868	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: cmFkZXJhY2tAcmFkZXJhY2suemFwdG8ub3Jn"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	9080	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: ***"
"SMTPD"	9080	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	5868	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.457"	"201.80.69.207"	"SENT: 354 OK, send."
"APPLICATION"	9664	"2020-05-26 19:04:56.677"	"SMTPDeliverer - Message 86: Delivering message from enarrais@gmail.com to ezardx@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{7F60FA0A-2387-4FF1-84AA-29708BA054B3}.eml"
"SMTPD"	2160	1517	"2020-05-26 19:04:56.677"	"201.80.69.207"	"SENT: 250 Queued (0.224 seconds)"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.677"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	9800	1517	"2020-05-26 19:04:56.677"	"201.80.69.207"	"SENT: 221 goodbye"
"TCPIP"	9664	"2020-05-26 19:04:56.687"	"DNS MX lookup: hotmail.com"
"TCPIP"	5868	"2020-05-26 19:04:56.707"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"SMTPD"	5868	1530	"2020-05-26 19:04:56.707"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5868	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"RECEIVED: AUTH LOGIN"
"SMTPD"	5868	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"RECEIVED: cmFkZXJhY2tAcmFkZXJhY2suemFwdG8ub3Jn"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	9800	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"RECEIVED: ***"
"SMTPD"	9800	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	5868	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	5868	1530	"2020-05-26 19:04:56.717"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5868	1530	"2020-05-26 19:04:56.727"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	5868	1530	"2020-05-26 19:04:56.727"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9800	1530	"2020-05-26 19:04:56.727"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	9800	1530	"2020-05-26 19:04:56.727"	"201.80.69.207"	"SENT: 354 OK, send."
"SMTPD"	2160	1530	"2020-05-26 19:04:56.937"	"201.80.69.207"	"SENT: 250 Queued (0.192 seconds)"
"APPLICATION"	10128	"2020-05-26 19:04:56.937"	"SMTPDeliverer - Message 87: Delivering message from enarrais@gmail.com to enarrais@gmail.com. File: C:\Program Files (x86)\hMailServer\Data\{29031227-62B0-4492-ABB6-2C2668DC2532}.eml"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.937"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	9080	1530	"2020-05-26 19:04:56.937"	"201.80.69.207"	"SENT: 221 goodbye"
"TCPIP"	10128	"2020-05-26 19:04:56.947"	"DNS MX lookup: gmail.com"
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"DNS - MX Result: 12 IP addresses were found."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 64.233.186.26:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 2800:3f0:4003:c02::1b:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 172.253.120.26:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 172.217.218.26:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.977"	"Connecting to 2a00:1450:4013:c08::1a:25..."
"TCPIP"	10128	"2020-05-26 19:04:56.987"	"Connecting to 209.85.233.26:25..."
"TCPIP"	9664	"2020-05-26 19:04:57.007"	"DNS - MX Result: 2 IP addresses were found."
"TCPIP"	10128	"2020-05-26 19:04:57.007"	"Connecting to 2a00:1450:4010:c03::1b:25..."
"TCPIP"	9664	"2020-05-26 19:04:57.007"	"Connecting to 104.47.18.97:25..."
"TCPIP"	10128	"2020-05-26 19:04:57.007"	"Connecting to 142.250.4.26:25..."
"TCPIP"	9664	"2020-05-26 19:04:57.007"	"Connecting to 104.47.17.161:25..."
"TCPIP"	10128	"2020-05-26 19:04:57.007"	"Connecting to 2404:6800:4003:c06::1b:25..."
"APPLICATION"	9664	"2020-05-26 19:04:57.007"	"SMTPDeliverer - Message 86: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"APPLICATION"	10128	"2020-05-26 19:04:57.007"	"SMTPDeliverer - Message 87: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"APPLICATION"	9664	"2020-05-26 19:04:57.017"	"SMTPDeliverer - Message 86: Message delivery thread completed."
"APPLICATION"	10128	"2020-05-26 19:04:57.027"	"SMTPDeliverer - Message 87: Message delivery thread completed."
"APPLICATION"	10128	"2020-05-26 19:05:57.423"	"SMTPDeliverer - Message 78: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{7D3235B3-0415-4D23-8BA3-C4CEE883A4DC}.eml"
"TCPIP"	10128	"2020-05-26 19:05:57.423"	"DNS MX lookup: hotmail.com"
"TCPIP"	10128	"2020-05-26 19:05:57.653"	"DNS - MX Result: 2 IP addresses were found."
"TCPIP"	10128	"2020-05-26 19:05:57.653"	"Connecting to 104.47.18.97:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.653"	"Connecting to 104.47.17.161:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.653"	"DNS MX lookup: gmail.com"
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"DNS - MX Result: 12 IP addresses were found."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 64.233.186.26:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 2800:3f0:4003:c02::1b:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 172.253.120.26:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 172.217.218.26:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 2a00:1450:4013:c08::1a:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 209.85.233.26:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 2a00:1450:4010:c03::1b:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 142.250.4.26:25..."
"TCPIP"	10128	"2020-05-26 19:05:57.933"	"Connecting to 2404:6800:4003:c06::1b:25..."
"APPLICATION"	10128	"2020-05-26 19:05:57.933"	"SMTPDeliverer - Message 78: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"APPLICATION"	10128	"2020-05-26 19:05:57.933"	"SMTPDeliverer - Message 78: Message delivery thread completed."
2020-05-26 23:41
Re: need help
Post by RvdH » 2020-05-27 00:40
raderack wrote:
2020-05-27 00:07
i read it.
Read it again, as clearly you do not understand what is written there
You cannot send to the outside, most likely cause: your ISP blocks port 25
Probably this also will prevent you from receiving any mail
In all honesty, i don't think you should want to own a mailserver, the only way to make it work in your case is to relay it through (your ISP) SMTP and have some SMTP redirection service to receive (that delivers mail on another port then post 25)
raderack
Re: need help
Post by raderack » 2020-05-27 03:13
changed port 25 to 250,open in the modem firewall.
still nothing..
"DEBUG"	9524	"2020-05-26 22:11:41.988"	"Creating session 2529"
"TCPIP"	9524	"2020-05-26 22:11:41.988"	"TCP - 201.80.69.207 connected to 192.168.0.2:250."
"DEBUG"	9524	"2020-05-26 22:11:41.998"	"TCP connection started for session 2495"
"SMTPD"	9524	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	7448	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	7448	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	5028	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"RECEIVED: AUTH PLAIN"
"SMTPD"	5028	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"SENT: 334 Log on"
"SMTPD"	9524	2495	"2020-05-26 22:11:41.998"	"201.80.69.207"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	9524	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	5028	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	5028	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	7448	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	7448	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	9524	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	9524	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	5028	2495	"2020-05-26 22:11:42.008"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	5028	2495	"2020-05-26 22:11:42.018"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	7448	2495	"2020-05-26 22:11:42.018"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	7448	2495	"2020-05-26 22:11:42.018"	"201.80.69.207"	"SENT: 354 OK, send."
"DEBUG"	9524	"2020-05-26 22:11:42.499"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-26 22:11:42.499"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-26 22:11:42.499"	"Saving message: {B6BAB08D-F44F-433B-B3DD-3D3FA1D6BDE8}.eml"
"DEBUG"	2160	"2020-05-26 22:11:42.499"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2160	2495	"2020-05-26 22:11:42.499"	"201.80.69.207"	"SENT: 250 Queued (0.480 seconds)"
"DEBUG"	228	"2020-05-26 22:11:42.499"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	10152	"2020-05-26 22:11:42.499"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	10152	"2020-05-26 22:11:42.499"	"Delivering message..."
"APPLICATION"	10152	"2020-05-26 22:11:42.499"	"SMTPDeliverer - Message 105: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{B6BAB08D-F44F-433B-B3DD-3D3FA1D6BDE8}.eml"
"DEBUG"	10152	"2020-05-26 22:11:42.499"	"Applying rules"
"DEBUG"	10152	"2020-05-26 22:11:42.499"	"Performing local delivery"
"DEBUG"	10152	"2020-05-26 22:11:42.499"	"Local delivery completed"
"SMTPD"	9524	2495	"2020-05-26 22:11:42.499"	"201.80.69.207"	"RECEIVED: QUIT"
"DEBUG"	8360	"2020-05-26 22:11:42.499"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"SMTPD"	9524	2495	"2020-05-26 22:11:42.499"	"201.80.69.207"	"SENT: 221 goodbye"
"DEBUG"	8360	"2020-05-26 22:11:42.499"	"Delivering message..."
"DEBUG"	7448	"2020-05-26 22:11:42.499"	"Ending session 2495"
"TCPIP"	10152	"2020-05-26 22:11:42.499"	"DNS MX lookup: gmail.com"
"APPLICATION"	8360	"2020-05-26 22:11:42.499"	"SMTPDeliverer - Message 103: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{BD3177EC-90B5-4E99-B66A-48F496A1398D}.eml"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Applying rules"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Performing local delivery"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Local delivery completed"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"DNS MX lookup: gmail.com"
"TCPIP"	10152	"2020-05-26 22:11:42.509"	"DNS - MX Result: 10 IP addresses were found."
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (172.217.192.26), Port: 25, Security: 2, User name: "
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Creating session 2530"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"DNS - MX Result: 10 IP addresses were found."
"TCPIP"	10152	"2020-05-26 22:11:42.509"	"Connecting to 172.217.192.26:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (172.217.192.26), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 172.217.192.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Creating session 2531"
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2530"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"Connecting to 172.217.192.26:25..."
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"External delivery process completed"
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 172.217.192.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (2800:3f0:4003:c02::1b), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2531"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Creating session 2532"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"External delivery process completed"
"TCPIP"	10152	"2020-05-26 22:11:42.509"	"Connecting to 2800:3f0:4003:c02::1b:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (2800:3f0:4003:c02::1b), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 2800:3f0:4003:c02::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Creating session 2533"
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2532"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"Connecting to 2800:3f0:4003:c02::1b:25..."
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 2800:3f0:4003:c02::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (172.253.120.26), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2533"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Creating session 2534"
"TCPIP"	10152	"2020-05-26 22:11:42.509"	"Connecting to 172.253.120.26:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (172.253.120.26), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 172.253.120.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Creating session 2535"
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2534"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"Connecting to 172.253.120.26:25..."
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 172.253.120.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (2a00:1450:400c:c01::1b), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2535"
"DEBUG"	10152	"2020-05-26 22:11:42.509"	"Creating session 2536"
"TCPIP"	10152	"2020-05-26 22:11:42.509"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (2a00:1450:400c:c01::1b), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 2a00:1450:400c:c01::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.509"	"Creating session 2537"
"DEBUG"	7448	"2020-05-26 22:11:42.509"	"Ending session 2536"
"TCPIP"	8360	"2020-05-26 22:11:42.509"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"External delivery process completed"
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 2a00:1450:400c:c01::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (172.217.218.26), Port: 25, Security: 2, User name: "
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"Ending session 2537"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2538"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"External delivery process completed"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (172.217.218.26), Port: 25, Security: 2, User name: "
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 172.217.218.26:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2539"
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 172.217.218.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"TCPIP"	8360	"2020-05-26 22:11:42.519"	"Connecting to 172.217.218.26:25..."
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"Ending session 2538"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 172.217.218.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2539"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (2a00:1450:4013:c08::1a), Port: 25, Security: 2, User name: "
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2540"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (2a00:1450:4013:c08::1a), Port: 25, Security: 2, User name: "
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 2a00:1450:4013:c08::1a:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2541"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 2a00:1450:4013:c08::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"TCPIP"	8360	"2020-05-26 22:11:42.519"	"Connecting to 2a00:1450:4013:c08::1a:25..."
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2540"
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 2a00:1450:4013:c08::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"Ending session 2541"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (209.85.233.26), Port: 25, Security: 2, User name: "
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2542"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (209.85.233.26), Port: 25, Security: 2, User name: "
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 209.85.233.26:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2543"
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 209.85.233.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"TCPIP"	8360	"2020-05-26 22:11:42.519"	"Connecting to 209.85.233.26:25..."
"DEBUG"	7448	"2020-05-26 22:11:42.519"	"Ending session 2542"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 209.85.233.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (2a00:1450:4010:c03::1a), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2543"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2544"
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 2a00:1450:4010:c03::1a:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (2a00:1450:4010:c03::1a), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 2a00:1450:4010:c03::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2545"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2544"
"TCPIP"	8360	"2020-05-26 22:11:42.519"	"Connecting to 2a00:1450:4010:c03::1a:25..."
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 2a00:1450:4010:c03::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (142.250.4.26), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2545"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2546"
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 142.250.4.26:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (142.250.4.26), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 142.250.4.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2547"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2546"
"TCPIP"	8360	"2020-05-26 22:11:42.519"	"Connecting to 142.250.4.26:25..."
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 142.250.4.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (2404:6800:4003:c06::1a), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2547"
"DEBUG"	10152	"2020-05-26 22:11:42.519"	"Creating session 2548"
"TCPIP"	10152	"2020-05-26 22:11:42.519"	"Connecting to 2404:6800:4003:c06::1a:25..."
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (2404:6800:4003:c06::1a), Port: 25, Security: 2, User name: "
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 2404:6800:4003:c06::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	8360	"2020-05-26 22:11:42.519"	"Creating session 2549"
"DEBUG"	9524	"2020-05-26 22:11:42.519"	"Ending session 2548"
"TCPIP"	8360	"2020-05-26 22:11:42.529"	"Connecting to 2404:6800:4003:c06::1a:25..."
"DEBUG"	10152	"2020-05-26 22:11:42.529"	"External delivery process completed"
"DEBUG"	10152	"2020-05-26 22:11:42.529"	"Summarizing delivery result"
"DEBUG"	9524	"2020-05-26 22:11:42.529"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 2404:6800:4003:c06::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	9524	"2020-05-26 22:11:42.529"	"Ending session 2549"
"DEBUG"	10152	"2020-05-26 22:11:42.529"	"Summarized delivery results"
"DEBUG"	8360	"2020-05-26 22:11:42.529"	"External delivery process completed"
"TCPIP"	10152	"2020-05-26 22:11:42.529"	"DNS MX lookup: hotmail.com"
"DEBUG"	8360	"2020-05-26 22:11:42.529"	"Summarizing delivery result"
"DEBUG"	8360	"2020-05-26 22:11:42.529"	"Summarized delivery results"
"TCPIP"	8360	"2020-05-26 22:11:42.529"	"DNS MX lookup: hotmail.com"
"TCPIP"	8360	"2020-05-26 22:11:42.779"	"DNS - MX Result: 1 IP addresses were found."
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.48.33), Port: 25, Security: 2, User name: "
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Creating session 2550"
"TCPIP"	8360	"2020-05-26 22:11:42.779"	"Connecting to 104.47.48.33:25..."
"DEBUG"	9524	"2020-05-26 22:11:42.779"	"SMTPDeliverer - Message 103 - Connection failed: Host name: 104.47.48.33, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	9524	"2020-05-26 22:11:42.779"	"Ending session 2550"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"External delivery process completed"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Summarizing delivery result"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Summarized delivery results"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"SD::RescheduleDelivery_"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Retrieving retry options."
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Aborting delivery."
"APPLICATION"	8360	"2020-05-26 22:11:42.779"	"SMTPDeliverer - Message 103: Message could not be delivered. Returning error log to sender."
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Message not rescheduled for later delivery."
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"SD::SubmitErrorLog_"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Saving message: {1E63D25B-08AE-4EC3-8588-14E4FE4D35E3}.eml"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"SD::~SubmitErrorLog_"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Deleting message"
"DEBUG"	8360	"2020-05-26 22:11:42.779"	"Deleting message file."
"APPLICATION"	8360	"2020-05-26 22:11:42.789"	"SMTPDeliverer - Message 103: Message delivery thread completed."
"TCPIP"	10152	"2020-05-26 22:11:42.839"	"DNS - MX Result: 1 IP addresses were found."
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.48.33), Port: 25, Security: 2, User name: "
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Creating session 2551"
"TCPIP"	10152	"2020-05-26 22:11:42.839"	"Connecting to 104.47.48.33:25..."
"DEBUG"	9524	"2020-05-26 22:11:42.839"	"SMTPDeliverer - Message 105 - Connection failed: Host name: 104.47.48.33, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	9524	"2020-05-26 22:11:42.839"	"Ending session 2551"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"External delivery process completed"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Summarizing delivery result"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Summarized delivery results"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"SD::RescheduleDelivery_"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Retrieving retry options."
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Starting rescheduling."
"APPLICATION"	10152	"2020-05-26 22:11:42.839"	"SMTPDeliverer - Message 105: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	10152	"2020-05-26 22:11:42.839"	"Message rescheduled for later delivery."
"APPLICATION"	10152	"2020-05-26 22:11:42.839"	"SMTPDeliverer - Message 105: Message delivery thread completed."
Re: need help
Post by mattg » 2020-05-27 04:26
The point is that port 25 is needed to send mail between servers
Opening the firewall doesn't change that your ISP has likely blocked port25 outbound and probably inbound as well
If you send mail to my server (or any other mail server) it will need to be on port 25, or I won't get the mail
If my server (or any other in world) wants to send mail to your server they will use port 25 (unless specifically INDIVIDUALLY set to send on some other port)
You need port 25 open to run a mailserver
Contact your ISP
(You probably need to purchase business grade internet)
johang
Re: need help
Post by johang » 2020-05-27 08:13
do you want to operate a mailserver at home that sends AND recieves email ? ( go further down to **running mailserver at home when PORT 25 is blocked by your isp** )
OR
do you want ONLY to be able to send email out from your local PHPB-forum ??
if you only want to be able to send out email from a computer on your network, you talk to your isp and use their outgoing smtp server ( email relay server ) you will likely have to have a user to authenticate to be able to send email through the ISP email/relay servers ( if so.. you can set up a relay to use your isps mailserver via hmailserver configuration )
**running mailserver at home when PORT 25 is blocked by your isp** (( to recieve and send email directly to other emailservers on the internet YOU have to use port 25 !))
if you want to run your own mailserver at home and your isp is blocking port 25, you can ask the isp if they unblock your IP for port 25 for both in and outgoing traffic or you purchase their services to open port 25 both ingoing and outgoing traffic.
OR
you use other services/companies/organisations to recieve mail on port 25 on the internet and that service/company/organisation "relay" mail back to your email server on another port then the official SMTP port 25 ( that means you set up the agreed ( between YOU and service/company/organisation ) serverport to recieve and send email .. there are many different relaying services availiable on the internet.. some can be for free ( often with a cap on number of email sent or recieved ) or be a paid subscription service
raderack
Re: need help
Post by raderack » 2020-05-27 18:47
i will look for a smtp server free or paid
anyone known a good one?
raderack
Re: need help
Post by raderack » 2020-05-27 20:03
added mx from google in the domain..
still with errors
"DEBUG"	6936	"2020-05-27 15:02:38.518"	"Creating session 2698"
"TCPIP"	6936	"2020-05-27 15:02:38.548"	"TCP - 201.80.69.207 connected to 192.168.0.2:25."
"DEBUG"	6936	"2020-05-27 15:02:38.548"	"TCP connection started for session 2655"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.548"	"201.80.69.207"	"SENT: 220 raderack.zapto.org ESMTP"
"SMTPD"	5492	2655	"2020-05-27 15:02:38.548"	"201.80.69.207"	"RECEIVED: EHLO Miguel-PC"
"SMTPD"	5492	2655	"2020-05-27 15:02:38.548"	"201.80.69.207"	"SENT: 250-raderack.zapto.org[nl]250-SIZE 20480000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"RECEIVED: AUTH PLAIN"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"SENT: 334 Log on"
"SMTPD"	5492	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"RECEIVED: 	raderack@raderack.zapto.org ***"
"SMTPD"	5492	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"SENT: 235 authenticated."
"SMTPD"	7112	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"RECEIVED: MAIL FROM:<enarrais@gmail.com>"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"RECEIVED: RCPT TO:<enarrais@gmail.com>"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.558"	"201.80.69.207"	"RECEIVED: RCPT TO:<ezardx@hotmail.com>"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.568"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.568"	"201.80.69.207"	"RECEIVED: RCPT TO:<miguelpinheirobrasil@hotmail.com>"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.568"	"201.80.69.207"	"SENT: 250 OK"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.568"	"201.80.69.207"	"RECEIVED: DATA"
"SMTPD"	6936	2655	"2020-05-27 15:02:38.568"	"201.80.69.207"	"SENT: 354 OK, send."
"DEBUG"	7112	"2020-05-27 15:02:38.778"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-27 15:02:38.778"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	2160	"2020-05-27 15:02:38.778"	"Saving message: {D0D32CBF-4BE7-40CA-ABBA-8846D3E01052}.eml"
"DEBUG"	2160	"2020-05-27 15:02:38.788"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2160	2655	"2020-05-27 15:02:38.788"	"201.80.69.207"	"SENT: 250 Queued (0.208 seconds)"
"DEBUG"	10088	"2020-05-27 15:02:38.798"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	10196	"2020-05-27 15:02:38.798"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	10196	"2020-05-27 15:02:38.798"	"Delivering message..."
"APPLICATION"	10196	"2020-05-27 15:02:38.798"	"SMTPDeliverer - Message 112: Delivering message from enarrais@gmail.com to enarrais@gmail.com, ezardx@hotmail.com, miguelpinheirobrasil@hotmail.com. File: C:\Program Files (x86)\hMailServer\Data\{D0D32CBF-4BE7-40CA-ABBA-8846D3E01052}.eml"
"DEBUG"	10196	"2020-05-27 15:02:38.798"	"Applying rules"
"DEBUG"	10196	"2020-05-27 15:02:38.798"	"Performing local delivery"
"DEBUG"	10196	"2020-05-27 15:02:38.798"	"Local delivery completed"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.798"	"201.80.69.207"	"RECEIVED: QUIT"
"SMTPD"	7112	2655	"2020-05-27 15:02:38.798"	"201.80.69.207"	"SENT: 221 goodbye"
"DEBUG"	6936	"2020-05-27 15:02:38.798"	"Ending session 2655"
"TCPIP"	10196	"2020-05-27 15:02:38.798"	"DNS MX lookup: gmail.com"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"DNS - MX Result: 10 IP addresses were found."
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (64.233.186.27), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2699"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"Connecting to 64.233.186.27:25..."
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 64.233.186.27, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"Ending session 2699"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"External delivery process completed"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (2800:3f0:4003:c02::1a), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2700"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"Connecting to 2800:3f0:4003:c02::1a:25..."
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 2800:3f0:4003:c02::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"Ending session 2700"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (172.253.120.27), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2701"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"Connecting to 172.253.120.27:25..."
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 172.253.120.27, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"Ending session 2701"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: alt1.gmail-smtp-in.l.google.com (2a00:1450:400c:c01::1b), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2702"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"Connecting to 2a00:1450:400c:c01::1b:25..."
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 2a00:1450:400c:c01::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"Ending session 2702"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (172.217.218.27), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2703"
"TCPIP"	10196	"2020-05-27 15:02:39.998"	"Connecting to 172.217.218.27:25..."
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 172.217.218.27, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:39.998"	"Ending session 2703"
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Starting external delivery process. Server: alt2.gmail-smtp-in.l.google.com (2a00:1450:4013:c08::1b), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:39.998"	"Creating session 2704"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"Connecting to 2a00:1450:4013:c08::1b:25..."
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 2a00:1450:4013:c08::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"Ending session 2704"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"External delivery process completed"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (209.85.233.26), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Creating session 2705"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"Connecting to 209.85.233.26:25..."
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 209.85.233.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"Ending session 2705"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Starting external delivery process. Server: alt3.gmail-smtp-in.l.google.com (2a00:1450:4010:c03::1b), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Creating session 2706"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"Connecting to 2a00:1450:4010:c03::1b:25..."
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 2a00:1450:4010:c03::1b, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"Ending session 2706"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (142.250.4.26), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Creating session 2707"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"Connecting to 142.250.4.26:25..."
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 142.250.4.26, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"Ending session 2707"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Starting external delivery process. Server: alt4.gmail-smtp-in.l.google.com (2404:6800:4003:c06::1a), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Creating session 2708"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"Connecting to 2404:6800:4003:c06::1a:25..."
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 2404:6800:4003:c06::1a, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:40.008"	"Ending session 2708"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Summarizing delivery result"
"DEBUG"	10196	"2020-05-27 15:02:40.008"	"Summarized delivery results"
"TCPIP"	10196	"2020-05-27 15:02:40.008"	"DNS MX lookup: hotmail.com"
"TCPIP"	10196	"2020-05-27 15:02:41.368"	"DNS - MX Result: 2 IP addresses were found."
"DEBUG"	10196	"2020-05-27 15:02:41.368"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.17.161), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:41.368"	"Creating session 2709"
"TCPIP"	10196	"2020-05-27 15:02:41.368"	"Connecting to 104.47.17.161:25..."
"DEBUG"	6936	"2020-05-27 15:02:41.368"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 104.47.17.161, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:41.378"	"Ending session 2709"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"External delivery process completed"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Starting external delivery process. Server: hotmail-com.olc.protection.outlook.com (104.47.17.97), Port: 25, Security: 2, User name: "
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Creating session 2710"
"TCPIP"	10196	"2020-05-27 15:02:41.378"	"Connecting to 104.47.17.97:25..."
"DEBUG"	6936	"2020-05-27 15:02:41.378"	"SMTPDeliverer - Message 112 - Connection failed: Host name: 104.47.17.97, message: Uma operação de soquete foi tentada em uma rede inacessível"
"DEBUG"	6936	"2020-05-27 15:02:41.378"	"Ending session 2710"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Summarizing delivery result"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Summarized delivery results"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"SD::RescheduleDelivery_"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Retrieving retry options."
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Starting rescheduling."
"APPLICATION"	10196	"2020-05-27 15:02:41.378"	"SMTPDeliverer - Message 112: Message could not be delivered. Scheduling it for later delivery in 5 minutes."
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	10196	"2020-05-27 15:02:41.378"	"Message rescheduled for later delivery."
"APPLICATION"	10196	"2020-05-27 15:02:41.378"	"SMTPDeliverer - Message 112: Message delivery thread completed."
Re: need help
Post by jimimaseye » 2020-05-27 20:37
raderack wrote:
2020-05-27 20:03
What??
I think you need to research mail servers, how to configure them, and the requirements OR pay someone to do this for you. Mail servers are serious and need detailed attention. We are not here to 'teach about mail servers' but help with the technical issues that you cannot fathom out from your own knowledge (from experience or research) or the documentation.
johang
Re: need help
Post by johang » 2020-05-28 00:29
raderack wrote:
2020-05-27 20:03
still with errors
By adding mx records for your domain in a public DNS you have configured so all mailservers on the internet believes your mail is now handled by google ..
( do google know they are supposed to handle your email ? if you do not have an agreement with them they will not accept those emails )
i recommend you read https://www.dynu.com/en-US/Blog/Article ... ks-port-25 i am in no way affiliated with dynu i do not know if their pricing is good
but if you want to host a mailserver at home perhaps you can use their services
and i think you should look into their "Email Store/Forward" service and their "SMTP Outbound Relay" service
perhaps it is the right thing for you
