Issue to certificate file and private key file
PeterChan
Post by PeterChan » 2020-05-03 11:23
I do not know why error below happened in hMailserver, regarding my certificate file and private key file.
"ERROR" 4800 "2020-05-03 14:30:00.858" "Severity: 2 (High), Code: HM5113, Source: SslContextInitializer::InitServer, Description: Failed to load certificate file. Path: C:\dp2\Certificate file and key file\cert0.pfx, Address: 0.0.0.0, Port: 587, Error: use_certificate_file: no start line"
Re: Issue to certificate file and private key file
Post by RvdH » 2020-05-03 18:18
What do you expect to get as a answer? The reason is shown in the error message isn't?
Virinum
Post by Virinum » 2020-05-04 00:03
hMailServer doesn’t support .pfx certificates. You have to convert it to a .pem certificate and private key.
