DKIM Signing just not happening.
Rewire
Post by Rewire » 2020-04-25 17:24
Topic.
Trying to fix all the issues with my domain I've had for ages.
Looking at the logs, it doesn't look like it's even attempting to sign the messages with my DKIM key.
I've tried following the multiple guides available here, can't seem to resolve the issue.
Version is 5.6.7-B2425
Domain is ntillc.tk. Key is 1028 bit.
Re: DKIM Signing just not happening.
Post by RvdH » 2020-04-25 18:07
You need to enable DEBUG logging, then send a message to a external account to verify DKIM signing worked
https://www.sparkpost.com/email-tools/a ... n-checker/
Post by RvdH » 2020-04-25 18:25
Signing is triggered right after OnDeliverMessage
"DEBUG" 6784 "2020-04-25 18:11:22.937" "Executing event OnDeliverMessage"
"DEBUG" 6784 "2020-04-25 18:11:23.015" "Event completed"
"DEBUG" 6784 "2020-04-25 18:11:23.015" "Performing local delivery"
"DEBUG" 6784 "2020-04-25 18:11:23.015" "Local delivery completed"
"DEBUG" 6784 "2020-04-25 18:11:23.015" "Signing message using DKIM...
Rewire
Post by Rewire » 2020-04-25 18:28
As stated, DKIM is not working. Nothing is happening, no attempts showing up in the logs.
Debug logging is enabled.
"DEBUG"	952	"2020-04-25 16:23:28.055"	"TCP connection started for session 147"
"SMTPD"	952	147	"2020-04-25 16:23:28.056"	"98.146.216.209"	"SENT: 220 mail.ntillc.tk ESMTP"
"SMTPD"	5912	147	"2020-04-25 16:23:28.083"	"98.146.216.209"	"RECEIVED: EHLO [192.168.1.6]"
"SMTPD"	5912	147	"2020-04-25 16:23:28.084"	"98.146.216.209"	"SENT: 250-mail.ntillc.tk[nl]250-SIZE 32000000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5992	147	"2020-04-25 16:23:28.113"	"98.146.216.209"	"RECEIVED: STARTTLS"
"SMTPD"	5992	147	"2020-04-25 16:23:28.114"	"98.146.216.209"	"SENT: 220 Ready to start TLS"
"DEBUG"	5912	"2020-04-25 16:23:28.115"	"Performing SSL/TLS handshake for session 147. Verify certificate: False"
"TCPIP"	5912	"2020-04-25 16:23:28.187"	"TCPConnection - TLS/SSL handshake completed. Session Id: 147, Remote IP: , Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"SMTPD"	952	147	"2020-04-25 16:23:28.190"	"98.146.216.209"	"RECEIVED: EHLO [192.168.1.6]"
"SMTPD"	952	147	"2020-04-25 16:23:28.191"	"98.146.216.209"	"SENT: 250-mail.ntillc.tk[nl]250-SIZE 32000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	5992	147	"2020-04-25 16:23:28.275"	"98.146.216.209"	"RECEIVED: AUTH LOGIN"
"SMTPD"	5992	147	"2020-04-25 16:23:28.276"	"98.146.216.209"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	5912	147	"2020-04-25 16:23:28.302"	"98.146.216.209"	"RECEIVED: dHdvbHZlbkBudGlsbGMudGs="
"SMTPD"	5912	147	"2020-04-25 16:23:28.303"	"98.146.216.209"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	952	147	"2020-04-25 16:23:28.328"	"98.146.216.209"	"RECEIVED: ***"
"DEBUG"	5992	"2020-04-25 16:23:28.334"	"Creating session 149"
"TCPIP"	5992	"2020-04-25 16:23:28.335"	"TCP - 46.38.144.179 connected to 172.31.27.225:25."
"DEBUG"	5992	"2020-04-25 16:23:28.340"	"Client connection from 46.38.144.179 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	5992	"2020-04-25 16:23:28.340"	"Ending session 144"
"SMTPD"	952	147	"2020-04-25 16:23:28.375"	""	"SENT: 235 authenticated."
"SMTPD"	5992	147	"2020-04-25 16:23:28.400"	""	"RECEIVED: MAIL FROM:<@ntillc.tk> SIZE=7648"
"SMTPD"	5992	147	"2020-04-25 16:23:28.403"	""	"SENT: 250 OK"
"SMTPD"	5912	147	"2020-04-25 16:23:28.427"	""	"RECEIVED: RCPT TO:<@gmail.com>"
"SMTPD"	5912	147	"2020-04-25 16:23:28.429"	""	"SENT: 250 OK"
"SMTPD"	952	147	"2020-04-25 16:23:28.454"	""	"RECEIVED: DATA"
"SMTPD"	952	147	"2020-04-25 16:23:28.456"	""	"SENT: 354 OK, send."
"DEBUG"	3988	"2020-04-25 16:23:28.588"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	3660	"2020-04-25 16:23:28.592"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	3660	"2020-04-25 16:23:28.593"	"Saving message: {FC8B8409-9F7E-4D2C-87FA-8C0D96344520}.eml"
"DEBUG"	3660	"2020-04-25 16:23:28.616"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	3660	147	"2020-04-25 16:23:28.618"	""	"SENT: 250 Queued (0.128 seconds)"
"DEBUG"	3864	"2020-04-25 16:23:28.624"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	5444	"2020-04-25 16:23:28.626"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	5444	"2020-04-25 16:23:28.627"	"Delivering message..."
"SMTPD"	5284	147	"2020-04-25 16:23:28.645"	""	"RECEIVED: QUIT"
"SMTPD"	5284	147	"2020-04-25 16:23:28.647"	""	"SENT: 221 goodbye"
"DEBUG"	6848	"2020-04-25 16:23:28.648"	"Ending session 147"
"APPLICATION"	5444	"2020-04-25 16:23:28.693"	"SMTPDeliverer - Message 19656: Delivering message from@ntillc.tk to @gmail.com. File: C:\Program Files (x86)\hMailServer\Data\{FC8B8409-9F7E-4D2C-87FA-8C0D96344520}.eml"
"DEBUG"	5444	"2020-04-25 16:23:28.694"	"Applying rules"
"DEBUG"	5444	"2020-04-25 16:23:28.695"	"Performing local delivery"
"DEBUG"	5444	"2020-04-25 16:23:28.696"	"Local delivery completed"
"TCPIP"	5444	"2020-04-25 16:23:28.699"	"DNS MX lookup: gmail.com"
"DEBUG"	3988	"2020-04-25 16:23:28.715"	"Creating session 150"
"TCPIP"	3988	"2020-04-25 16:23:28.716"	"TCP - 9 connected to 172.31.27.225:143."
"DEBUG"	3988	"2020-04-25 16:23:28.718"	"TCP connection started for session 146"
"IMAPD"	3988	146	"2020-04-25 16:23:28.753"	"98.146.216.209"	"SENT: * OK IMAPrev1"
"TCPIP"	5444	"2020-04-25 16:23:28.724"	"DNS - MX Result: 5 IP addresses were found."
"DEBUG"	5444	"2020-04-25 16:23:28.757"	"Starting external delivery process. Server: gmail-smtp-in.l.google.com (74.125.142.27), Port: 25, Security: 2, User name: "
"DEBUG"	5444	"2020-04-25 16:23:28.757"	"Creating session 151"
"TCPIP"	5444	"2020-04-25 16:23:28.758"	"Connecting to 74.125.142.27:25..."
"DEBUG"	6848	"2020-04-25 16:23:28.772"	"TCP connection started for session 151"
"IMAPD"	6848	146	"2020-04-25 16:23:28.782"	"98.146.216.209"	"RECEIVED: 1 capability"
"IMAPD"	6848	146	"2020-04-25 16:23:28.782"	"98.146.216.209"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL STARTTLS NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	3988	146	"2020-04-25 16:23:28.807"	"98.146.216.209"	"RECEIVED: 2 STARTTLS"
"IMAPD"	3988	146	"2020-04-25 16:23:28.808"	"98.146.216.209"	"SENT: 2 OK Begin TLS negotiation now"
"DEBUG"	6848	"2020-04-25 16:23:28.810"	"Performing SSL/TLS handshake for session 146. Verify certificate: False"
"TCPIP"	6848	"2020-04-25 16:23:28.957"	"TCPConnection - TLS/SSL handshake completed. Session Id: 146, Remote IP: , Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"IMAPD"	5284	146	"2020-04-25 16:23:28.979"	"98.146.216.209"	"RECEIVED: 3 capability"
"IMAPD"	5284	146	"2020-04-25 16:23:28.980"	"98.146.216.209"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL STARTTLS NAMESPACE RIGHTS=texk[nl]3 OK CAPABILITY completed"
"SMTPC"	5284	151	"2020-04-25 16:23:28.984"	"74.125.142.27"	"RECEIVED: 220 mx.google.com ESMTP n27si3618559pgd.407 - gsmtp"
"SMTPC"	5284	151	"2020-04-25 16:23:28.985"	"74.125.142.27"	"SENT: EHLO mail.ntillc.tk"
"SMTPC"	6400	151	"2020-04-25 16:23:29.005"	"74.125.142.27"	"RECEIVED: 250-mx.google.com at your service, [35.167.65.37][nl]250-SIZE 157286400[nl]250-8BITMIME[nl]250-STARTTLS[nl]250-ENHANCEDSTATUSCODES[nl]250-PIPELINING[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC"	6400	151	"2020-04-25 16:23:29.006"	"74.125.142.27"	"SENT: STARTTLS"
"SMTPC"	6400	151	"2020-04-25 16:23:29.020"	"74.125.142.27"	"RECEIVED: 220 2.0.0 Ready to start TLS"
"DEBUG"	6400	"2020-04-25 16:23:29.022"	"Performing SSL/TLS handshake for session 151. Verify certificate: True, Expected remote host name: gmail-smtp-in.l.google.com"
"IMAPD"	6400	146	"2020-04-25 16:23:29.042"	"98.146.216.209"	"RECEIVED: 5 login "@ntillc.tk" ***"
"IMAPD"	6400	146	"2020-04-25 16:23:29.061"	"98.146.216.209"	"SENT: 5 OK LOGIN completed"
"IMAPD"	5888	146	"2020-04-25 16:23:29.087"	"98.146.216.209"	"RECEIVED: 6 append "Sent" (\Seen) {7648}"
"IMAPD"	5888	146	"2020-04-25 16:23:29.088"	"98.146.216.209"	"SENT: + Ready for literal data"
"DEBUG"	6400	"2020-04-25 16:23:29.168"	"Saving message: {15A357A6-0B16-4A3F-B298-A8F677FF881A}.eml"
"IMAPD"	6400	146	"2020-04-25 16:23:29.186"	"98.146.216.209"	"SENT: 6 OK APPEND completed"
"DEBUG"	2968	"2020-04-25 16:23:29.219"	"Certificate verification succeeded for session 151."
"TCPIP"	5912	"2020-04-25 16:23:29.239"	"TCPConnection - TLS/SSL handshake completed. Session Id: 151, Remote IP: 74.125.142.27, Version: TLSv1.2, Cipher: ECDHE-ECDSA-AES128-GCM-SHA256, Bits: 128"
"SMTPC"	5912	151	"2020-04-25 16:23:29.240"	"74.125.142.27"	"SENT: EHLO mail.ntillc.tk"
"SMTPC"	952	151	"2020-04-25 16:23:29.255"	"74.125.142.27"	"RECEIVED: 250-mx.google.com at your service, [35.167.65.37][nl]250-SIZE 157286400[nl]250-8BITMIME[nl]250-ENHANCEDSTATUSCODES[nl]250-PIPELINING[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC"	952	151	"2020-04-25 16:23:29.255"	"74.125.142.27"	"SENT: MAIL FROM:<@ntillc.tk>"
"SMTPC"	5888	151	"2020-04-25 16:23:29.270"	"74.125.142.27"	"RECEIVED: 250 2.1.0 OK n27si3618559pgd.407 - gsmtp"
"SMTPC"	5888	151	"2020-04-25 16:23:29.271"	"74.125.142.27"	"SENT: RCPT TO:<@gmail.com>"
"SMTPC"	5284	151	"2020-04-25 16:23:29.726"	"74.125.142.27"	"RECEIVED: 250 2.1.5 OK n27si3618559pgd.407 - gsmtp"
"SMTPC"	5284	151	"2020-04-25 16:23:29.727"	"74.125.142.27"	"SENT: DATA"
"SMTPC"	952	151	"2020-04-25 16:23:29.741"	"74.125.142.27"	"RECEIVED: 354  Go ahead n27si3618559pgd.407 - gsmtp"
"SMTPC"	952	151	"2020-04-25 16:23:29.742"	"74.125.142.27"	"SENT: [nl]."
"SMTPC"	6400	151	"2020-04-25 16:23:30.458"	"74.125.142.27"	"RECEIVED: 250 2.0.0 OK  1587831810 n27si3618559pgd.407 - gsmtp"
"SMTPC"	6400	151	"2020-04-25 16:23:30.459"	"74.125.142.27"	"SENT: QUIT"
"SMTPC"	6652	151	"2020-04-25 16:23:30.474"	"74.125.142.27"	"RECEIVED: 221 2.0.0 closing connection n27si3618559pgd.407 - gsmtp"
"DEBUG"	6652	"2020-04-25 16:23:30.475"	"Ending session 151"
"DEBUG"	5444	"2020-04-25 16:23:30.476"	"External delivery process completed"
"DEBUG"	5444	"2020-04-25 16:23:30.477"	"Summarizing delivery result"
"DEBUG"	5444	"2020-04-25 16:23:30.477"	"AWStats::LogDeliverySuccess"
"DEBUG"	5444	"2020-04-25 16:23:30.488"	"Summarized delivery results"
"DEBUG"	5444	"2020-04-25 16:23:30.491"	"Deleting message"
"DEBUG"	5444	"2020-04-25 16:23:30.497"	"Deleting message file."
"APPLICATION"	5444	"2020-04-25 16:23:30.498"	"SMTPDeliverer - Message 19656: Message delivery thread completed."
Rewire
Post by Rewire » 2020-04-25 18:39
Not a configuration issue, as far as I can tell.
2020-04-25   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - maxx.ntxxxxxx.tk               Enabled: True
      |- "Alias1.com" - ntxxxxxx.tk
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - maxx.ntxxxx.tk                 Enabled: True
      |- "Alias2.com" - ntxxxx.tk
                                                Private key: c:\program files (x86)\hmailserver\data\Domain2.com\dkim.ntillc.tk.pem
                                                Selector:    dkim
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
There is a total of 2 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins:  1   Plain Text:        False  Bind:
                     Host: Domain2.com         Empty sender:       True  Batch recipients:   100
Max Msg Size: 32000  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
        Loop limit:           5
        Recipient hosts:     15
  Routes:
    Domain2.com              - S: Local   R: Local  - Addr: All         !! TARGET RESOLVES TO SELF !!
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Spam:    False    Check HELO host:   False
  Add X-HmailServer-Reason:  False    Check MX records:  False
DNSBL ENTRIES:
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   SSL
       Certificate: C:\Program Files (x86)\hMailServer\Bin\neotitan.crt
       Private key: C:\Program Files (x86)\hMailServer\Bin\neotitan.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: SSL
               0.0.0.0         / 110   / POP3   -   StartTLS Optional   Cert: SSL
               0.0.0.0         / 143   / IMAP   -   StartTLS Optional   Cert: SSL
               0.0.0.0         / 587   / SMTP   -   StartTLS Required   Cert: SSL
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-04-25.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-25.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory C:\Users\Administrator\Documents\HmailServerBackup is writable.
HMAILSERVER.INI
Database folder:
Type=              MYSQL
Username=          root
Port=              3306
Server=            localhost
Internal=          0
Generated by HMSSettingsDiagnostics v2.00, Hmailserver Forum.
Post by RvdH » 2020-04-25 18:39
mmmm.... the hmailserver admin GUI says your domain is mail.ntillc.tk not ntillc.tk
You have ntillc.tk listed as domain alias, but a alias is not DKIM signed
Simply use ntillc.tk as domain, dump the mail.* alias..... or if you really need it for some weird reason, create a separate domain mail.ntillc.tk in hmailserver (with optionally his own DKIM, spf record etc)
Rewire
Post by Rewire » 2020-04-25 18:44
Does it matter since my username to sign in is mail.ntillc.tk?
Post by RvdH » 2020-04-25 18:49
Rewire wrote:
2020-04-25 18:44
Not exactly know what you mean with that
.... mail.ntillc.tk is the MX record (and A-record) to connect to the server, tw***en@ntillc.tk is the address/domain you are mailing from, not tw***en@mail.ntillc.tk
and as said, if you really need mail.ntillc.tk as domain create a separate domain in hmailserver, as you can not DKIM sign domain aliases
Rewire
Post by Rewire » 2020-04-25 18:54
Looks like it's trying to sign now and having an error.
"APPLICATION"	5444	"2020-04-25 16:51:26.908"	"SMTPDeliverer - Message 19660: Delivering message from @ntillc.tk to @neotitanllc.com. File: C:\Program Files (x86)\hMailServer\Data\{7B69B955-B082-4788-9BB7-2A80634FD4BC}.eml"
"DEBUG"	5444	"2020-04-25 16:51:26.908"	"Applying rules"
"DEBUG"	5444	"2020-04-25 16:51:26.909"	"Performing local delivery"
"DEBUG"	5444	"2020-04-25 16:51:26.910"	"Local delivery completed"
"DEBUG"	5444	"2020-04-25 16:51:26.910"	"Signing message using DKIM..."
"ERROR"	5444	"2020-04-25 16:51:26.913"	"Severity: 3 (Medium), Code: HM4227, Source: File::ReadFile, Description: An unknown error occurred while reading file from disk."
"SMTPD"	5912	197	"2020-04-25 16:51:26.914"	"98.146.216.209"	"RECEIVED: QUIT"
"SMTPD"	5912	197	"2020-04-25 16:51:26.915"	"98.146.216.209"	"SENT: 221 goodbye"
"ERROR"	5444	"2020-04-25 16:51:26.915"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-DeliveryTask', Message: Attempt to read from file which has not been opened."
"DEBUG"	5444	"2020-04-25 16:51:26.917"	"Logging exception.."
"DEBUG"	4068	"2020-04-25 16:51:26.916"	"Ending session 197"
"IMAPD"	5992	161	"2020-04-25 16:51:26.952"	"98.146.216.209"	"RECEIVED: DONE"
"IMAPD"	5992	161	"2020-04-25 16:51:26.966"	"98.146.216.209"	"SENT: 14 OK IDLE terminated"
"IMAPD"	4068	161	"2020-04-25 16:51:26.999"	"98.146.216.209"	"RECEIVED: 15 append "Sent" (\Seen) {7636}"
"IMAPD"	4068	161	"2020-04-25 16:51:27.000"	"98.146.216.209"	"SENT: + Ready for literal data"
"DEBUG"	5992	"2020-04-25 16:51:27.036"	"Saving message: {7EDE6F35-611B-4A0E-AB01-A8DCE842BF95}.eml"
"IMAPD"	5992	161	"2020-04-25 16:51:27.051"	"98.146.216.209"	"SENT: 15 OK APPEND completed"
"IMAPD"	2848	161	"2020-04-25 16:51:27.153"	"98.146.216.209"	"RECEIVED: 16 IDLE"
"IMAPD"	2848	161	"2020-04-25 16:51:27.154"	"98.146.216.209"	"SENT: + idling"
"DEBUG"	2848	"2020-04-25 16:51:27.155"	"The read operation failed. Bytes transferred: 0 Remote IP: 98.146.216.209, Session: 161, Code: 2, Message: End of file"
"DEBUG"	2848	"2020-04-25 16:51:27.156"	"Ending session 161"
"ERROR"	5444	"2020-04-25 16:51:27.790"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-04-25 165126_{721F76F6-343D-4A18-94F4-4DFF41C40E7C}.dmp"
"DEBUG"	5444	"2020-04-25 16:51:27.792"	"Completed logging of exception..."
Post by RvdH » 2020-04-25 19:00
Does the file c:\program files (x86)\hmailserver\data\ntillc.tk\dkim.ntillc.tk.pem exist?
You also seem to be signing it with dkim.ntillc.tk.pem, that doesn't look like to be the private key
verify the dkim.ntillc.tk.pem has not
-----BEGIN PUBLIC KEY-----
-----END PUBLIC KEY-----
But uses
-----END RSA PRIVATE KEY-----
in it
Rewire
Post by Rewire » 2020-04-25 19:04
Looks like it was a file permission issue, no problems with the formatting.
I changed the owner from Admin to Users and gave it full control of the file.
Issue has been fixed.
Thanks!
Post by RvdH » 2020-04-25 19:05
