PeterChan
- Normal user
Post
by PeterChan » 2020-04-18 17:33
To log details below, does it mean it is one failure try?
"SMTPD" 3896 1150 "2020-04-18 19:00:14.109" "45.143.223.100" "RECEIVED: RCPT to:<
spameri@tiscali.it>"
"SMTPD" 3896 1150 "2020-04-18 19:00:14.113" "45.143.223.100" "SENT: 530 SMTP authentication is required."
- Moderator
Post
by jimimaseye » 2020-04-18 18:26
Yes. It is standard spam. You will see that exact entry many times in your logs over time.
Ignore it.
PeterChan
- Normal user
Post
by PeterChan » 2020-04-19 15:35
Thanks. Do you mean no harm to the try in above?
How to reject the following try, through any Firewall Inbound/Outbound rule? Is it good idea to filter out specific IP (like the one below, which is 69.175.97.170) through any Firewall Inbound/Outbound rule?
"DEBUG" 3876 "2020-04-19 18:28:28.066" "TCP connection started for session 1210"
"SMTPD" 3876 1210 "2020-04-19 18:28:28.067" "69.175.97.170" "SENT: 220 WIN-APIUFD1NJEU ESMTP"
"SMTPD" 3856 1210 "2020-04-19 18:28:28.242" "69.175.97.170" "RECEIVED: EHLO sh-chi-us-gp1-wk102.internet-census.org"
"SMTPD" 3856 1210 "2020-04-19 18:28:28.244" "69.175.97.170" "SENT: 250-WIN-APIUFD1NJEU[nl]250-SIZE 20480000[nl]250-STARTTLS[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 3880 1210 "2020-04-19 18:28:28.419" "69.175.97.170" "RECEIVED: STARTTLS"
"SMTPD" 3880 1210 "2020-04-19 18:28:28.420" "69.175.97.170" "SENT: 220 Ready to start TLS"
"DEBUG" 3856 "2020-04-19 18:28:28.423" "Performing SSL/TLS handshake for session 1210. Verify certificate: False"
"TCPIP" 3892 "2020-04-19 18:28:28.596" "TCPConnection - TLS/SSL handshake failed. Session Id: 1210, Remote IP: 69.175.97.170, Error code: 336027900, Message: unknown protocol"
"DEBUG" 3892 "2020-04-19 18:28:28.597" "Ending session 1210"
- Moderator
Post
by mattg » 2020-04-19 17:58
That one failed too
PeterChan
- Normal user
Post
by PeterChan » 2020-04-20 08:26
mattg wrote: ↑2020-04-19 17:58
That one failed too
Is it having no harm to my machine? Any way to avoid it from happening?
- Moderator
Post
by mattg » 2020-04-20 15:23
PeterChan wrote: ↑2020-04-20 08:26
no
Not while you are connected to the internet -
there will always be someone who wants to test your system
