PeterChan
- Normal user
Post
by PeterChan » 2020-04-15 11:09
What to further enable, due to issue like
Microsoft Telnet> o localhost 465
Connecting To localhost...Could not open connection to the host, on port 465: Connect failed
I've already enabled TCP and UDP In/out rule on this port. Why does error happen?
- Moderator
Post
by jimimaseye » 2020-04-15 11:24
PeterChan
- Normal user
Post
by PeterChan » 2020-04-15 15:10
What is password to run it?
- Moderator
Post
by mattg » 2020-04-15 15:30
your hmailserver administrator password
PeterChan
- Normal user
Post
by PeterChan » 2020-04-16 04:18
Please help to report below
2020-04-15 Hmailserver: 5.6.7-B2425
DOMAINS
(No Domains Entered)
IP RANGES
Allow connections Other
SMTP: True Antispam : True !! 'Spam tests' not enabled !!
POP3: True Antivirus: True !! ANTIVIRUS NOT CONFIGURED !!
IMAP: True SSL/TLS: False
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: True Max invalid logon attempts: 3
Minutes Before Reset: 30 (0.50 hours, 0.02 days)
Minutes to Autoban: 60 (1.00 hours, 0.04 days)
INCOMING RELAYS
No entries
MIRRORING Disabled
PROTOCOLS
SMTP
No. Connections: 0 No Retries: 4 Mins: 60 Plain Text: False Bind:
Host: Domain0.com Empty sender: True Batch recipients: 100
Max Msg Size: 20480 Relay:- Incorrect endings: True Use STARTTLS: True
Loop limit: 5
Recipient hosts: 15
Routes:
No routes defined.
POP3
No. Connections: 0
IMAP
IMAP Quota: True
IMAP Idle: True
IMAP ACL: True
Delim: "."
ANTISPAM
Spam Mark: 5 Use SPF: False Use Spamassassin: False
Add X-HmailServer-Spam: True Check HELO host: False
Add X-HmailServer-Reason: True Check MX records: False
Add X-HmailServer-Subject: False Verify DKIM: False
DNSBL ENTRIES:
No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
Greylisting: False
WHITELISTING
No entries
Block Attachments: False
SSL CERTIFICATES
No entries
SSL/TLS
SSL 3.0 : False
TLS 1.0 : True
TLS 1.1 : True
SslCipherList :
RC4-SHA - HIGH - !aNULL
!eNULL - !EXPORT - !DES
!3DES - !MD5 - !PSK;
TCPIP PORTS Connection Sec
0.0.0.0 / 25 / SMTP - None
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - None
0.0.0.0 / 587 / SMTP - None
LOGGING Logging Enabled: False
Paths:-
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-15.log
SYSTEM TESTS
Database type: MSSQL
HMAILSERVER.INI
Database folder:
Type= MSSQL
Username= ws_login
Port= 0
Server= WIN-429I3QNHOQT\EXPR2012
Internal= 0
Generated by HMSSettingsDiagnostics v1.99, Hmailserver Forum.
- Moderator
Post
by jimimaseye » 2020-04-16 10:10
You are trying to connect on port 465 but you do not have port 465 configured (as shown above).
Try connecting on one if the ports configured.
PeterChan
- Normal user
Post
by PeterChan » 2020-04-16 12:16
Thanks. How to configure port 465?
