Fix my email server setup to stop spammers
Ratalinux
Post by Ratalinux » 2020-04-15 04:40
Hello everybody!
I'm just another newbie trying to get this thing to work as it should.
At first (following some YouTube tutorials) I installed and setup the mail server and everything seemed to work ok.
After a while, I started to face problems sending and receiving emails.
On sending, I started to get one of these responses:
451 Rejected - No data saved
STARTTLS not supported and the user requires enforcement
On trying to read, I started to get a "connection refused" response (from GMail client).
When I tried to find out why, I discover that my IP become blacklisted due to spammers intrusion.
According to what I read about it to get this fixed, I have to setup my server properly and once I'm sure it is right, I need to ask the blacklist databases to remove my IP from their records.
This is my original setup, which was working "fine" until now:
Protocols:
SMTP Enabled
POP3 Disabled
IMAP Disabled
Auto-Ban Enabled
IP Ranges - My Computer:
127.0.0.1 / 127.0.0.1
Allow connections:
SMTP Enabled
POP3 Disabled
IMAP Disabled
Anti-spam Enabled
Anti-virus Enabled
SSL/TLS Disabled
Allow deliveries from: all options enabled (including External to External)
Require SMTP authentication: all options disabled
IP Ranges - Internet:
0.0.0.0 / 255.255.255.255
Allow connections:
SMTP Enabled
POP3 Disabled
IMAP Disabled
Anti-spam Enabled
Anti-virus Enabled
SSL/TLS Disabled
According to this post:
https://www.hmailserver.com/documentati ... d_for_spam
...I should never enable External to External and I should require SMTP authentication.
I tried to do so, but I don't know if I'm on the right path.
What should I do ????
Thanks!
tunis
Re: Fix my email server setup to stop spammers
Post by tunis » 2020-04-15 07:54
Ratalinux wrote:
2020-04-15 04:40
...I should never enable c and I should require SMTP authentication.
Disable External to External if you don't relay email.
Enable require SMTP authentication on all except External to Local (for incoming mail to your server).
HMS 5.6.8 B2505.27 on Windows Server 2016 Core VM.
Post by jimimaseye » 2020-04-15 09:21
Post by RvdH » 2020-04-15 09:39
Amazing to see people still/always mess with the default ip ranges when they start using a mail server :shock: :?: :!:
Post by palinka » 2020-04-15 14:27
2020-04-15 09:39
Maybe someone should change the button that resets to default settings: turn it into a big round red button that says "DO NOT PRESS THIS BUTTON!". Then most of these issues would go away. :mrgreen:
Ratalinux
Post by Ratalinux » 2020-04-15 19:14
Thanks tunis! I really don't know if I'm going to relay email or not, because honestly I don't know exactly what that means. Anyway, I'll keep that disabled by now.
Thanks jimimaseye! Here's the diagnostic results:
2020-04-15   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - e-xxxxxxxxx.com                Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
     External To External - False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
There is a total of 3 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
 !! Service Not Enabled !!
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  E:\hMailServer\Logs\hmailserver_2020-04-15.log
    Error:    E:\hMailServer\Logs\ERROR_hmailserver_2020-04-15.log
    Event:    E:\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  E:\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory G:\HMailServerBackups is writable.
HMAILSERVER.INI
Program folder:  E:\hMailServer\
Database folder: E:\hMailServer\Database
Data folder:     E:\hMailServer\Data
Log folder:      E:\hMailServer\Logs
Temp folder:     E:\hMailServer\Temp
Event folder:    E:\hMailServer\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.99, Hmailserver Forum.
Ratalinux
Post by Ratalinux » 2020-04-15 19:26
Thanks again tunis & jimimaseye!
According to my mail server logs, all spam intrusion attempts are being properly blocked now.
Please let me know if based on the diagnostic report I sent, my setup is correct now and I can start the blacklist removal requests or if I need to fine tune anything else, like anti-virus, anti-spam, a stronger authentication method or anything like that.
I really appreciate you taking the time to give me a hand here.
Thanks again! :D
Post by jimimaseye » 2020-04-15 21:17
The setup looks acceptable now. You can increase comfort with the use of spamassassin and and antivirus but you basic setup is ok.
Ratalinux
Post by Ratalinux » 2020-04-16 03:58
Thanks once again! :D
