DMARC Report Aggregation Services
- Senior user
Anyone using a DMARC Report Aggregation Service? Any testimonials to share? Any decent free/freemium providers?
Re: DMARC Report Aggregation Services
I use Postmarkapp.com
Seems to be OK
Reports on about a tenth of the messages that I send (perhaps even less)
I don't really know what to compare that to
I get a weekly report and have done so for over a year
Just shows me that DMARC works,. although very occasionally I'll not get a 100% score, which means that someone is spamming using my domain(s), and It does tell me what IP was used to try that
Seems to be OK
- Senior user
Postmarkapp.com looks like a relay service to me. I was thinking more along the lines of a service that receives the DMARC reports from multiple domains under a single tenancy, processes the report XML and provides either a consolidated or single-domain view of the processed data.
Something like this: https://learn.valimail.com/dmarc-monitor
I don't use postmark as a relay
Postmark send me a report like that
I will forward to you one of the reports that I get, so that you can see
This looks like where I signed up
https://dmarc.postmarkapp.com/
- Senior user
@mattg: I want to thank you for the referral to Postmarkapp.com. I got my first report last night and it helped me to identify that my relay provider was sending from an IP not returned in the include:domain DNS lookup. Hopefully my manual add of an ipv4: tag will now clear that up.
Yeah I find the reports useful too
