Test Outbound Port Error - SMTP Protocol Configuration & Diagnostics - Relays, Issues Sending & Receiving Mail
BuckyJunior
Post by BuckyJunior » 2020-03-29 03:05
Upon configuring my installation of hMailServer and linking/logging into my defined accounts in hMailServer on Thunderbird, I am unable to receive or send mail.
In hMailServer's documentation, it is recommended to use an ISP's mail server relay in the event that port 25 is blocked. There is a problem with this, though. Due to being a Comcast customer using a residential plan, as well as Comcast's policies in regards to their mail relay, all activities on port 25 are blocked. This means that I cannot use the ISP's relay as referred to in hMailServer's documentation.
To my understanding, hMailServer requires the SMTP relay server to connect on port 25. Is this correct? When running diagnostics without a relay, 'Test outbound port' fails.
I attempted to use a relay on port 587, but this did not correct the issue in regards to sending and receiving mail. Diagnostics shows 'Test outbound port' was successful when using port 587, but with these settings I continue to have trouble receiving or sending mail.
Are there any other relays that support the connection of port 25?
Any suggestions on working around the problem of port 25 being blocked?
Thanks! :D
Alexander Buck
Re: Test Outbound Port Error - SMTP Protocol Configuration & Diagnostics - Relays, Issues Sending & Receiving Mail
Post by mattg » 2020-03-29 06:11
BuckyJunior wrote:
2020-03-29 03:05
Nope
That just affects the diagnostics
Create an SMTP relayer and set your comcast details including port587, test by sending a message
BuckyJunior
Post by BuckyJunior » 2020-03-29 20:05
Hi mattg,
Thank you for the quick reply.
As you suggested, I configured hMailServer to use Comcast through port 587.
I'm still having a bit of trouble.
When looking at the console, it appears outgoing mail reaches the SMTP server, but then dies on its way to its destination.
"IMAPD"	7040	19	"2020-03-29 04:09:32.587"	"51.83.66.171"	"SENT: * OK IMAPrev1"
"SMTPD"	7040	14	"2020-03-29 06:33:12.932"	"51.91.212.79"	"SENT: 220 apollotechnologies.us ESMTP"
"SMTPD"	7048	11	"2020-03-29 11:50:19.074"	"73.171.169.147"	"SENT: 220 apollotechnologies.us ESMTP"
"IMAPD"	7040	23	"2020-03-29 11:50:46.897"	"73.171.169.147"	"SENT: * OK IMAPrev1"
"IMAPD"	7048	23	"2020-03-29 11:50:46.925"	"73.171.169.147"	"RECEIVED: 1 capability"
"IMAPD"	7048	23	"2020-03-29 11:50:46.926"	"73.171.169.147"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	7064	23	"2020-03-29 11:50:46.957"	"73.171.169.147"	"RECEIVED: 3 login "alexander@apollotechnologies.us" ***"
"IMAPD"	7064	23	"2020-03-29 11:50:46.960"	"73.171.169.147"	"SENT: 3 OK LOGIN completed"
"IMAPD"	7048	23	"2020-03-29 11:50:46.972"	"73.171.169.147"	"RECEIVED: 4 namespace"
"IMAPD"	7048	23	"2020-03-29 11:50:46.973"	"73.171.169.147"	"SENT: * NAMESPACE (("" ".")) NIL (("#Public" "."))[nl]4 OK namespace command complete"
"IMAPD"	7040	23	"2020-03-29 11:50:46.979"	"73.171.169.147"	"RECEIVED: 5 list "" "*""
"IMAPD"	7040	23	"2020-03-29 11:50:46.980"	"73.171.169.147"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]* LIST (\HasNoChildren) "." "Trash"[nl]* LIST (\HasNoChildren) "." "Sent"[nl]5 OK LIST completed"
"IMAPD"	7064	23	"2020-03-29 11:50:46.985"	"73.171.169.147"	"RECEIVED: 6 lsub "" "*""
"IMAPD"	7064	23	"2020-03-29 11:50:46.986"	"73.171.169.147"	"SENT: * LSUB (\HasNoChildren) "." "INBOX"[nl]* LSUB (\HasNoChildren) "." "Trash"[nl]* LSUB (\HasNoChildren) "." "Sent""
"IMAPD"	7064	23	"2020-03-29 11:50:46.987"	"73.171.169.147"	"SENT: 6 OK LSUB completed"
"IMAPD"	7040	23	"2020-03-29 11:50:47.194"	"73.171.169.147"	"RECEIVED: 7 list "" "#Public*""
"IMAPD"	7040	23	"2020-03-29 11:50:47.195"	"73.171.169.147"	"SENT: 7 OK LIST completed"
"IMAPD"	7064	23	"2020-03-29 11:50:47.201"	"73.171.169.147"	"RECEIVED: 8 lsub "" "#Public*""
"IMAPD"	7064	23	"2020-03-29 11:50:47.201"	"73.171.169.147"	"SENT: "
"IMAPD"	7064	23	"2020-03-29 11:50:47.202"	"73.171.169.147"	"SENT: 8 OK LSUB completed"
"IMAPD"	7040	23	"2020-03-29 11:50:47.207"	"73.171.169.147"	"RECEIVED: 9 list "" "INBOX""
"IMAPD"	7040	23	"2020-03-29 11:50:47.207"	"73.171.169.147"	"SENT: * LIST (\HasNoChildren) "." "INBOX"[nl]9 OK LIST completed"
"IMAPD"	7064	23	"2020-03-29 11:50:47.458"	"73.171.169.147"	"RECEIVED: 10 select "INBOX""
"IMAPD"	7064	23	"2020-03-29 11:50:47.459"	"73.171.169.147"	"SENT: * 0 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1585312595] current uidvalidity[nl]* OK [UIDNEXT 7] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]10 OK [READ-WRITE] SELECT completed"
"IMAPD"	7048	23	"2020-03-29 11:50:47.474"	"73.171.169.147"	"RECEIVED: 11 myrights "INBOX""
"IMAPD"	7048	23	"2020-03-29 11:50:47.475"	"73.171.169.147"	"SENT: * MYRIGHTS "INBOX" lrswipkxtea[nl]11 OK Myrights complete"
"IMAPD"	7040	23	"2020-03-29 11:50:47.483"	"73.171.169.147"	"RECEIVED: 12 getacl "INBOX""
"IMAPD"	7040	23	"2020-03-29 11:50:47.484"	"73.171.169.147"	"SENT: * ACL "INBOX"[nl]12 OK GetAcl complete"
"IMAPD"	7064	23	"2020-03-29 11:50:47.495"	"73.171.169.147"	"RECEIVED: 13 getquotaroot "INBOX""
"IMAPD"	7064	23	"2020-03-29 11:50:47.496"	"73.171.169.147"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]13 OK GETQUOTAROOT completed"
"IMAPD"	7040	23	"2020-03-29 11:50:47.504"	"73.171.169.147"	"RECEIVED: 14 IDLE"
"IMAPD"	7040	23	"2020-03-29 11:50:47.505"	"73.171.169.147"	"SENT: + idling"
"IMAPD"	7040	26	"2020-03-29 11:50:49.035"	"73.171.169.147"	"SENT: * OK IMAPrev1"
"IMAPD"	7064	26	"2020-03-29 11:50:49.048"	"73.171.169.147"	"RECEIVED: 1 capability"
"IMAPD"	7064	26	"2020-03-29 11:50:49.049"	"73.171.169.147"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	7048	26	"2020-03-29 11:50:49.058"	"73.171.169.147"	"RECEIVED: 3 login "alexander@apollotechnologies.us" ***"
"IMAPD"	7048	26	"2020-03-29 11:50:49.059"	"73.171.169.147"	"SENT: 3 OK LOGIN completed"
"IMAPD"	7064	26	"2020-03-29 11:50:49.066"	"73.171.169.147"	"RECEIVED: 4 select "Sent""
"IMAPD"	7064	26	"2020-03-29 11:50:49.067"	"73.171.169.147"	"SENT: * 3 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1585344566] current uidvalidity[nl]* OK [UIDNEXT 8] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]4 OK [READ-WRITE] SELECT completed"
"IMAPD"	7040	26	"2020-03-29 11:50:49.075"	"73.171.169.147"	"RECEIVED: 5 myrights "Sent""
"IMAPD"	7040	26	"2020-03-29 11:50:49.075"	"73.171.169.147"	"SENT: * MYRIGHTS "Sent" lrswipkxtea[nl]5 OK Myrights complete"
"IMAPD"	7064	26	"2020-03-29 11:50:49.083"	"73.171.169.147"	"RECEIVED: 6 getacl "Sent""
"IMAPD"	7064	26	"2020-03-29 11:50:49.083"	"73.171.169.147"	"SENT: * ACL "Sent"[nl]6 OK GetAcl complete"
"IMAPD"	7048	26	"2020-03-29 11:50:49.091"	"73.171.169.147"	"RECEIVED: 7 getquotaroot "Sent""
"IMAPD"	7048	26	"2020-03-29 11:50:49.091"	"73.171.169.147"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]7 OK GETQUOTAROOT completed"
"IMAPD"	7040	26	"2020-03-29 11:50:49.098"	"73.171.169.147"	"RECEIVED: 8 UID fetch 1:* (FLAGS)"
"IMAPD"	7040	26	"2020-03-29 11:50:49.099"	"73.171.169.147"	"SENT: * 1 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	7040	26	"2020-03-29 11:50:49.100"	"73.171.169.147"	"SENT: * 2 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	7040	26	"2020-03-29 11:50:49.100"	"73.171.169.147"	"SENT: * 3 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	7040	26	"2020-03-29 11:50:49.101"	"73.171.169.147"	"SENT: 8 OK UID completed"
"IMAPD"	7048	26	"2020-03-29 11:50:49.155"	"73.171.169.147"	"RECEIVED: 9 IDLE"
"IMAPD"	7048	26	"2020-03-29 11:50:49.155"	"73.171.169.147"	"SENT: + idling"
"IMAPD"	7040	23	"2020-03-29 11:50:50.471"	"73.171.169.147"	"RECEIVED: DONE"
"IMAPD"	7040	23	"2020-03-29 11:50:50.472"	"73.171.169.147"	"SENT: 14 OK IDLE terminated"
"IMAPD"	7064	23	"2020-03-29 11:50:50.483"	"73.171.169.147"	"RECEIVED: 15 noop"
"IMAPD"	7064	23	"2020-03-29 11:50:50.484"	"73.171.169.147"	"SENT: 15 OK NOOP completed"
"IMAPD"	7040	23	"2020-03-29 11:50:50.492"	"73.171.169.147"	"RECEIVED: 16 getquotaroot "INBOX""
"IMAPD"	7040	23	"2020-03-29 11:50:50.492"	"73.171.169.147"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]16 OK GETQUOTAROOT completed"
"IMAPD"	7048	23	"2020-03-29 11:50:50.504"	"73.171.169.147"	"RECEIVED: 17 IDLE"
"IMAPD"	7048	23	"2020-03-29 11:50:50.505"	"73.171.169.147"	"SENT: + idling"
"IMAPD"	7040	23	"2020-03-29 11:50:56.281"	"73.171.169.147"	"RECEIVED: DONE"
"IMAPD"	7040	23	"2020-03-29 11:50:56.282"	"73.171.169.147"	"SENT: 17 OK IDLE terminated"
"IMAPD"	7048	23	"2020-03-29 11:50:56.290"	"73.171.169.147"	"RECEIVED: 18 noop"
"IMAPD"	7048	23	"2020-03-29 11:50:56.291"	"73.171.169.147"	"SENT: 18 OK NOOP completed"
"IMAPD"	7064	23	"2020-03-29 11:50:56.296"	"73.171.169.147"	"RECEIVED: 19 getquotaroot "INBOX""
"IMAPD"	7064	23	"2020-03-29 11:50:56.297"	"73.171.169.147"	"SENT: * QUOTAROOT "INBOX" ""[nl]* QUOTA "" ()[nl]19 OK GETQUOTAROOT completed"
"IMAPD"	7048	23	"2020-03-29 11:50:56.304"	"73.171.169.147"	"RECEIVED: 20 IDLE"
"IMAPD"	7048	23	"2020-03-29 11:50:56.305"	"73.171.169.147"	"SENT: + idling"
"SMTPD"	7040	24	"2020-03-29 11:51:26.534"	"73.171.169.147"	"SENT: 220 apollotechnologies.us ESMTP"
"SMTPD"	7048	24	"2020-03-29 11:51:26.556"	"73.171.169.147"	"RECEIVED: EHLO [192.168.1.160]"
"SMTPD"	7048	24	"2020-03-29 11:51:26.557"	"73.171.169.147"	"SENT: 250-apollotechnologies.us[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	7064	24	"2020-03-29 11:51:26.566"	"73.171.169.147"	"RECEIVED: AUTH LOGIN"
"SMTPD"	7064	24	"2020-03-29 11:51:26.566"	"73.171.169.147"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	7040	24	"2020-03-29 11:51:26.577"	"73.171.169.147"	"RECEIVED: YWxleGFuZGVyQGFwb2xsb3RlY2hub2xvZ2llcy51cw=="
"SMTPD"	7040	24	"2020-03-29 11:51:26.578"	"73.171.169.147"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	7048	24	"2020-03-29 11:51:26.585"	"73.171.169.147"	"RECEIVED: ***"
"SMTPD"	7048	24	"2020-03-29 11:51:26.586"	"73.171.169.147"	"SENT: 235 authenticated."
"SMTPD"	7040	24	"2020-03-29 11:51:26.593"	"73.171.169.147"	"RECEIVED: MAIL FROM:<alexander@apollotechnologies.us> SIZE=531"
"SMTPD"	7040	24	"2020-03-29 11:51:26.594"	"73.171.169.147"	"SENT: 250 OK"
"SMTPD"	7048	24	"2020-03-29 11:51:26.601"	"73.171.169.147"	"RECEIVED: RCPT TO:<alexander.g.buck@gmail.com>"
"SMTPD"	7048	24	"2020-03-29 11:51:26.603"	"73.171.169.147"	"SENT: 250 OK"
"SMTPD"	7040	24	"2020-03-29 11:51:26.609"	"73.171.169.147"	"RECEIVED: DATA"
"SMTPD"	7040	24	"2020-03-29 11:51:26.610"	"73.171.169.147"	"SENT: 354 OK, send."
"SMTPD"	6892	24	"2020-03-29 11:51:26.664"	"73.171.169.147"	"SENT: 250 Queued (0.048 seconds)"
"APPLICATION"	6972	"2020-03-29 11:51:26.665"	"SMTPDeliverer - Message 30: Delivering message from alexander@apollotechnologies.us to alexander.g.buck@gmail.com. File: C:\Program Files (x86)\hMailServer\Data\{3FE7F5CA-CF3C-4188-A0BA-2825F6B622D7}.eml"
"SMTPD"	7040	24	"2020-03-29 11:51:26.671"	"73.171.169.147"	"RECEIVED: QUIT"
"SMTPD"	7040	24	"2020-03-29 11:51:26.671"	"73.171.169.147"	"SENT: 221 goodbye"
"IMAPD"	7048	26	"2020-03-29 11:51:26.681"	"73.171.169.147"	"RECEIVED: DONE"
"IMAPD"	7048	26	"2020-03-29 11:51:26.681"	"73.171.169.147"	"SENT: 9 OK IDLE terminated"
"APPLICATION"	6972	"2020-03-29 11:51:26.683"	"SMTPDeliverer - Message 30: Relaying to host smtp.comcast.net."
"IMAPD"	7040	26	"2020-03-29 11:51:26.690"	"73.171.169.147"	"RECEIVED: 10 append "Sent" (\Seen) {531}"
"IMAPD"	7040	26	"2020-03-29 11:51:26.691"	"73.171.169.147"	"SENT: + Ready for literal data"
"IMAPD"	7040	26	"2020-03-29 11:51:26.701"	"73.171.169.147"	"SENT: * 4 EXISTS[nl]* 1 RECENT[nl]10 OK APPEND completed"
"IMAPD"	7064	26	"2020-03-29 11:51:26.803"	"73.171.169.147"	"RECEIVED: 11 IDLE"
"IMAPD"	7064	26	"2020-03-29 11:51:26.804"	"73.171.169.147"	"SENT: + idling"
"APPLICATION"	6972	"2020-03-29 11:51:34.001"	"SMTPDeliverer - Message 30: Message could not be delivered. Scheduling it for later delivery in 60 minutes."
"APPLICATION"	6972	"2020-03-29 11:51:34.003"	"SMTPDeliverer - Message 30: Message delivery thread completed."
"IMAPD"	7040	27	"2020-03-29 11:51:51.420"	"73.171.169.147"	"SENT: * OK IMAPrev1"
"IMAPD"	7048	27	"2020-03-29 11:51:51.428"	"73.171.169.147"	"RECEIVED: 1 capability"
"IMAPD"	7048	27	"2020-03-29 11:51:51.429"	"73.171.169.147"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]1 OK CAPABILITY completed"
"IMAPD"	7040	27	"2020-03-29 11:51:51.436"	"73.171.169.147"	"RECEIVED: 3 login "alexander@apollotechnologies.us" ***"
"IMAPD"	7040	27	"2020-03-29 11:51:51.438"	"73.171.169.147"	"SENT: 3 OK LOGIN completed"
"IMAPD"	7064	27	"2020-03-29 11:51:51.447"	"73.171.169.147"	"RECEIVED: 4 select "Sent""
"IMAPD"	7064	27	"2020-03-29 11:51:51.447"	"73.171.169.147"	"SENT: * 4 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1585344566] current uidvalidity[nl]* OK [UIDNEXT 9] next uid[nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)] limited[nl]4 OK [READ-WRITE] SELECT completed"
"IMAPD"	7040	27	"2020-03-29 11:51:51.455"	"73.171.169.147"	"RECEIVED: 5 getquotaroot "Sent""
"IMAPD"	7040	27	"2020-03-29 11:51:51.455"	"73.171.169.147"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]5 OK GETQUOTAROOT completed"
"IMAPD"	7064	27	"2020-03-29 11:51:51.462"	"73.171.169.147"	"RECEIVED: 6 UID fetch 1:* (FLAGS)"
"IMAPD"	7064	27	"2020-03-29 11:51:51.462"	"73.171.169.147"	"SENT: * 1 FETCH (UID 5 FLAGS (\Seen))"
"IMAPD"	7064	27	"2020-03-29 11:51:51.463"	"73.171.169.147"	"SENT: * 2 FETCH (UID 6 FLAGS (\Seen))"
"IMAPD"	7064	27	"2020-03-29 11:51:51.464"	"73.171.169.147"	"SENT: * 3 FETCH (UID 7 FLAGS (\Seen))"
"IMAPD"	7064	27	"2020-03-29 11:51:51.464"	"73.171.169.147"	"SENT: * 4 FETCH (UID 8 FLAGS (\Seen))"
"IMAPD"	7064	27	"2020-03-29 11:51:51.465"	"73.171.169.147"	"SENT: 6 OK UID completed"
"IMAPD"	7040	27	"2020-03-29 11:51:51.518"	"73.171.169.147"	"RECEIVED: 7 UID fetch 8 (UID RFC822.SIZE FLAGS BODY.PEEK[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type Reply-To)])"
"IMAPD"	7040	27	"2020-03-29 11:51:51.523"	"73.171.169.147"	"SENT: * 4 FETCH (UID 8 RFC822.SIZE 533 FLAGS (\Seen) BODY[HEADER.FIELDS (From To Cc Bcc Subject Date Message-ID Priority X-Priority References Newsgroups In-Reply-To Content-Type Reply-To)] {321}"
"IMAPD"	7040	27	"2020-03-29 11:51:51.523"	"73.171.169.147"	"SENT: )"
"IMAPD"	7040	27	"2020-03-29 11:51:51.524"	"73.171.169.147"	"SENT: 7 OK UID completed"
"IMAPD"	7048	27	"2020-03-29 11:51:51.573"	"73.171.169.147"	"RECEIVED: 8 IDLE"
"IMAPD"	7048	27	"2020-03-29 11:51:51.574"	"73.171.169.147"	"SENT: + idling"
"IMAPD"	7052	27	"2020-03-29 11:54:18.962"	"73.171.169.147"	"RECEIVED: DONE"
"IMAPD"	7052	27	"2020-03-29 11:54:18.963"	"73.171.169.147"	"SENT: 8 OK IDLE terminated"
"IMAPD"	7048	27	"2020-03-29 11:54:18.978"	"73.171.169.147"	"RECEIVED: 9 noop"
"IMAPD"	7048	27	"2020-03-29 11:54:18.979"	"73.171.169.147"	"SENT: 9 OK NOOP completed"
"IMAPD"	7052	27	"2020-03-29 11:54:18.985"	"73.171.169.147"	"RECEIVED: 10 getquotaroot "Sent""
"IMAPD"	7052	27	"2020-03-29 11:54:18.986"	"73.171.169.147"	"SENT: * QUOTAROOT "Sent" ""[nl]* QUOTA "" ()[nl]10 OK GETQUOTAROOT completed"
"IMAPD"	7048	27	"2020-03-29 11:54:18.993"	"73.171.169.147"	"RECEIVED: 11 UID fetch 9:* (FLAGS)"
"IMAPD"	7048	27	"2020-03-29 11:54:18.994"	"73.171.169.147"	"SENT: 11 OK UID completed"
"IMAPD"	7052	27	"2020-03-29 11:54:19.004"	"73.171.169.147"	"RECEIVED: 12 IDLE"
Alexander Buck
Post by RvdH » 2020-03-29 20:27
"APPLICATION" 6972 "2020-03-29 11:51:26.665" "SMTPDeliverer - Message 30: Delivering message from apollotechnologies. to gmail.. File: C:\Program Files (x86)\hMailServer\Data\{3FE7F5CA-CF3C-4188-A0BA-2825F6B622D7}.eml"
Your relay is greylisted...can't you authenticate to smtp.comcast.net? I think this will help bypassing greylisting by comcast
BuckyJunior
Post by BuckyJunior » 2020-03-30 03:18
Under 'Remote host name' I've got 'smtp.comcast.net' configured on port 587. 'Server requires authentication' is checked and I have input my username and password. SSL/TLS is enabled.
I'm not sure why I would be greylisted if I am connecting through Comcast's relay with authentication.
Alexander Buck
mikedibella
Post by mikedibella » 2020-03-30 04:49
Change Connection Security to STARTTLS (Optional). Enable Application, SMTP, TCP/IP and DEBUG logging. Disable all other logging. Re-run your test. Post another log excerpt.
BuckyJunior
Post by BuckyJunior » 2020-03-30 06:08
That did the trick in regards to sending mail. Thank you for the suggestion!
I am having trouble receiving mail, though. I tested sending an email from my Gmail account to my hMailServer email address, but I did not receive it. Gmail gave me this error:
The recipient server did not accept our requests to connect: timed out
Alexander Buck
Post by mattg » 2020-03-30 15:01
BuckyJunior
Post by BuckyJunior » 2020-03-30 20:34
I went through the list and checked intoDNS.com. intoDNS lists all as successful, including MX records.
All ports are forwarded on my router.
IP Ranges are set to default.
I'd call Comcast and ask whether or not they're blocking inbound mail, but due to COVID-19, Comcast support is unavailable.
Alexander Buck
mikedibella
Post by mikedibella » 2020-03-30 21:58
Ask someone you trust to telnet to your public IP on port 25. If they don't see "220" and your Welcome message in the telnet client, your ISP is firewalling port 25.
If your ISP is blocking port 25, you'll need to use a mail relay service to accept mail for you on port 25 and relay it to you on an alternate port.
BuckyJunior
Post by BuckyJunior » 2020-03-31 00:53
Comcast is, in fact, blocking both upstream and downstream connections on port 25, so that would make sense as to why I can send mail through port 587, but not receive on port 25.
https://www.xfinity.com/support/article ... cked-ports
Telnets failed.
This is unfortunate.
Does anyone have a suggestion as to what incoming relay/service to use?
Alexander Buck
mikedibella
Post by mikedibella » 2020-03-31 01:07
Start your search at your current domain registrar. You may already be paying for it.
