SPF not working correctly
mikernet
Post by mikernet » 2020-02-21 20:55
Running hMailServer version 5.6.7. Never had an issue like this in many years, until now. Here is an example of the log section that shows the email being greylisted:
"SMTPD"	2128	79087	"2020-02-17 01:29:03.833"	"40.107.223.80"	"SENT: 220 mail.singulink.com ESMTP"
"SMTPD"	2132	79087	"2020-02-17 01:29:03.865"	"40.107.223.80"	"RECEIVED: EHLO NAM11-DM6-obe.outbound.protection.outlook.com"
"SMTPD"	2132	79087	"2020-02-17 01:29:03.865"	"40.107.223.80"	"SENT: 250-mail.singulink.com[nl]250-SIZE 102400000[nl]250-STARTTLS[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	2128	79087	"2020-02-17 01:29:03.896"	"40.107.223.80"	"RECEIVED: STARTTLS"
"SMTPD"	2128	79087	"2020-02-17 01:29:03.896"	"40.107.223.80"	"SENT: 220 Ready to start TLS"
"SMTPD"	2176	79087	"2020-02-17 01:29:04.161"	"40.107.223.80"	"RECEIVED: EHLO NAM11-DM6-obe.outbound.protection.outlook.com"
"SMTPD"	2176	79087	"2020-02-17 01:29:04.161"	"40.107.223.80"	"SENT: 250-mail.singulink.com[nl]250-SIZE 102400000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	2132	79087	"2020-02-17 01:29:04.193"	"40.107.223.80"	"RECEIVED: MAIL FROM:<XXXXXXX@olg.ca> SIZE=64138"
"SMTPD"	2132	79087	"2020-02-17 01:29:04.443"	"40.107.223.80"	"SENT: 250 OK"
"SMTPD"	2160	79087	"2020-02-17 01:29:04.474"	"40.107.223.80"	"RECEIVED: RCPT TO:<XXXXXXXX@XXXXXXXXX.com>"
"SMTPD"	2160	79087	"2020-02-17 01:29:04.505"	"40.107.223.80"	"SENT: 451 Please try again later."
"SMTPD"	2128	79087	"2020-02-17 01:29:04.537"	"40.107.223.80"	"RECEIVED: QUIT"
"SMTPD"	2128	79087	"2020-02-17 01:29:04.537"	"40.107.223.80"	"SENT: 221 goodbye"
You can see from this tool that the SPF record for olg.ca is fine:
https://www.dmarcanalyzer.com/spf/checker/
The SPF record includes spf.protection.outlook.com, which contains 40.107.0.0/16, and thus this IP should be passing just fine.
You can see that the included SPF record of _spf.salesforce.com contains the following "exists:" macro:
v=spf1 exists:%{i}._spf.mta.salesforce.com -all
Could this be causing a problem for hMailServer? The macro is valid, but even if it wasn't I don't think that should prevent IPs from other valid included SPF records to all get thrown out...that would be a bit odd. Does hMailServer throw out the entire SPF record if it considers ANY of the included SPF records to be invalid?
Regardless, it seems to me that there is a bug here which should probably be fixed. I checked with multiple SPF validation tools and all of them say the records are good and the IP should pass.
Re: SPF not working correctly
Post by jimimaseye » 2020-02-21 21:13
Thats your hms sending code 451. You have greylisting enabled by chance?
mikernet
Post by mikernet » 2020-02-21 22:37
Yes, I have greylisting enabled with bypass on SPF pass. The issue is that SPF should be passing for that email server IP and domain.
mikernet
Post by mikernet » 2020-02-21 22:55
Let me know if you still want me to run that report, but I don't think this really has anything to do with my settings. hMailServer just fails to SPF pass mail coming from 40.107.223.80 for the olg.ca domain, which should pass no problem.
Post by jimimaseye » 2020-02-21 23:07
Run the report, yes. (We never assume anything without seeing it). That said it would be useful to see debug level logging for such an event too so we can see what is happening (if you can reproduce it) . Without this it isn't possible to judge.
mikernet
Post by mikernet » 2020-02-21 23:12
Can you elaborate on how I get the debug level logging you're looking for?
Here is the diagnostic report output:
2020-02-21   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - atxxxxxxxxxxxxxx.ca            Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: info@Domain1.com
                   Max size of accounts:    0
        Greylisting:      True
   "Domain2.com" - chxxxxxxxxxxxxxxxxx.com        Enabled: True
      |- "Alias1.com" - chxxxxxxxxxx.com
        Greylisting:      True
   "Domain3.com" - clxxxxxxxxxxxx.sixxxxxxx.com   Enabled: True
        Greylisting:      True
   "Domain4.com" - haxxxxxxxxx.ca                 Enabled: True
        Greylisting:      True
   "Domain5.com" - haxxxxxxxxx.com                Enabled: True
        Greylisting:      True
   "Domain6.com" - luxxxxxxxxxxxxx.ca             Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: shawn@Domain6.com
        Greylisting:      True
   "Domain7.com" - ofxxxxxxxxxxxxxxxxx.com        Enabled: True
        Greylisting:      True
   "Domain8.com" - paxxxxxxxxxxxxxxxxx.ca         Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: london@Domain8.com
        Greylisting:      True
   "Domain9.com" - poxxxxxxxx.ca                  Enabled: True
        Greylisting:      True
   "Domain10.com" - sbxxxxxxxxxxxxx.com           Enabled: True
        Greylisting:      True
   "Domain11.com" - sixxxxxxx.com                 Enabled: True
                   Max message size:   100000   Header:   Relaxed  Plus addressing: False
                                                Algorithm:   SHA1  Greylisting:      True
                                                Private key: e:\signing\Domain11.com\dkim_private_key.txt
                                                Selector:    mail
   "Domain12.com" - suxxxxxxxxxxxxxx.ca           Enabled: True
      |- "Alias2.com" - suxxxxxxxxxxxxxx.com
  Enabled: False   Max size:                0   Enabled: False     Catchall: shawn@Domain12.com
        Greylisting:      True
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 25     Name: My computer
IP: 192.168.0.0 - 192.168.255.255     Priority: 24     Name: Internal Network
     External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain11.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:     15
                              Minutes Before Reset:         1440  (24.00 hours, 1.00 days)
                              Minutes to Autoban:           1440  (24.00 hours, 1.00 days)
There is a total of 116 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries: 40 Mins: 10   Plain Text:         True  Bind:
Max Msg Size:102400  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  3       Use SPF:            True - 1    Use Spamassassin:    True
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 1    Hostname:       127.0.0.1
  Add X-HmailServer-Reason:   True    Check MX records:   True - 1    Port:                 783
  Add X-HmailServer-Subject:  True    Verify DKIM:       False        Use SA score:        True
              Subject Text: "[SPAM]"
  Spam delete threshold: 10         Maximum message size: 2048
DNSBL ENTRIES:
            b.barracudacentral.org      Score: 2     Result: 127.0.0.*
                  psbl.surriel.com      Score: 2     Result: 127.0.0.*
                ubl.unsubscore.com      Score: 4     Result: 127.0.0.*
                   cbl.abuseat.org      Score: 2     Result: 127.0.0.*
SURBL ENTRIES:
   No entries
GREYLISTING:
  Greylisting:   True       Defer mins: 5       Days Unused: 3      Days Used: 180
                            Bypass SPF: True     Bypass A/MX: False
Greylist WHITELIST ENTRIES:
   IP Address: 104.47.*
   IP Address: 209.235.143.14
   IP Address: 40.107.*
Greylist DOMAINS enabled:
           Domain1.com
           Domain2.com
                 |--   Alias1.com
           Domain3.com
           Domain4.com
           Domain5.com
           Domain6.com
           Domain7.com
           Domain8.com
           Domain9.com
           Domain10.com
           Domain11.com
           Domain12.com
                 |--   Alias2.com
WHITELISTING
              0.0.0.0            to    255.255.255.255              *[@t]on[dot]aibn[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]canadacomputers[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]yorkproperty[dot]ca
              0.0.0.0            to    255.255.255.255              *[@t]yorkdev[dot]ca
              0.0.0.0            to    255.255.255.255              *[@t]test[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]c1networx[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]eteki[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]sendgrid[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]dynastygamers[dot]com
ANTIVIRUS
GENERAL:
  Max Message Size: 0
     CLAM AV:   False
     CLAMWIN:   True       Executable: C:\Program Files (x86)\Sourcefire Inc\ClamAV\clamdscan.exe    Path:
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   mail.Domain11.com
       Certificate: E:\Certificates\Domain11.com-chain.pem
       Private key: E:\Certificates\Domain11.com-key.pem
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: mail.Domain11.com
               0.0.0.0         / 110   / POP3   -   StartTLS Optional   Cert: mail.Domain11.com
               0.0.0.0         / 143   / IMAP   -   StartTLS Optional   Cert: mail.Domain11.com
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: mail.Domain11.com
               0.0.0.0         / 587   / SMTP   -   StartTLS Optional   Cert: mail.Domain11.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: mail.Domain11.com
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: mail.Domain11.com
               0.0.0.0         / 1025  / SMTP   -   StartTLS Optional   Cert: mail.Domain11.com
  Paths:-
    Current:  E:\Logs\hmailserver_2020-02-21.log
    Error:    E:\Logs\ERROR_hmailserver_2020-02-21.log
    Event:    E:\Logs\hmailserver_events.log - Last Event: 2020/02/21
    Awstats:  E:\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL
HMAILSERVER.INI
Database folder:
Data folder:     E:\Data
Log folder:      E:\Logs
Temp folder:     E:\Temp
Event folder:    E:\Events
Type=              MSSQL
Username=          sa
Port=              0
Server=            mssql1
Internal=          0
Post by jimimaseye » 2020-02-22 00:33
Yep.
  Paths:-
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .   <<<<-------  HERE
                        AWSTATS     -      .
As above - enable it.
Post by mattg » 2020-02-22 02:02
mikernet wrote:
2020-02-21 20:55
I think this is the problem
https://www.spf-record.com/syntax
mikernet
Post by mikernet » 2020-02-22 02:10
That macro passes SPF validation on every test site I've tried, including macro resolution on the sample site I provided, so it must be following readily available standards.
Even if it wasnt though, I really dont think the entire SPF config shoul# be thrown away because of a bad included SPF record. A bad third party config shouldn't render someone's entire mail config broken when using other senders.
Post by mattg » 2020-02-22 03:22
The issue here is that hmailserver see that SPF as a fail
Then greylisting and your other antispam settings kick in
In my view greylisting is next to useless these days, especially if you select to bypass greylisting on an SPF pass
Any correctly formatted spf record that ends in +all will ALWAYS pass SPF checks
mikernet
Post by mikernet » 2020-02-22 06:21
Greylisting with SPF bypass still manages to stop a significant portion of spam for us before it has a chance to go anywhere else, but given hMailServer's current non-conformant SPF implementation and lack of ability to handle this situation, it seems that we need to disable it now.
If someone has a +all record then yes, I expect any delivery server to pass, that's not a problem. Never delivering mail because it gets trapped in a greylisting cycle due to incorrectly handled SPF results by hMailServer is the bigger issue for me.
The link you sent before is not the complete SPF specification. The relevant section on macros in the SPF formal RFC spec can be found here: https://tools.ietf.org/html/rfc7208#page-28
I urge you to consider the following updates:
1) Implement the full SPF specification, both for "pass on SPF bypass" greylisting setting as well as the "anti-spam > spam tests > use SPF" setting, which I'm sure does not currently work correctly either
2) Do not throw away an entire SPF record if an "include:" record is invalid. Once again, an invalid third party record should not render all your own records or other included records to be invalid as well.
mikernet
Post by mikernet » 2020-02-22 06:24
This made me wonder - if a third-party included record becomes "unavailable" and cannot be retrieved, does the whole SPF record get thrown out as well?
Post by mattg » 2020-02-22 09:23
OK, researching I can see that the RFCs have changed in 2014, and there is a new version of the spf testing library used in hMailserver
I've created a GitHub issue, and will do a pull request.
Don't know how long or if that will be implemented
https://github.com/hmailserver/hmailserver/issues/314
mikernet wrote:
2020-02-22 06:24
The only FAIL is where an SPF record is available, and it doesn't pass the tests.
Honestly, this is first I have heard of SPF Macros, and not many of us use SPF to bypass greylisting, because among other things we find that the spammers use valid SPF records, or find one of the millions of domains that have a +spf record.
I used to use greylisting a lot, but since the likes of gmail and Office365 have grown, and use multiple servers, greylisting is fairly useless.
This may make it. Upgrading an existing library to a newer version shouldn't be too hard.
We will see.
Post by jimimaseye » 2020-02-22 10:19
Whether or not the macro inclusion is the cause of the failure remains to be seen (hopefully the debug logging will give more info). However, according to that rfc in the event of a dns lookup failure (misconfiguration or recursion depth error etc) and a 'permerror' status returned, it is up to the implementation of the receiving server to decide on what choice it makes. Options are to accept and pass and therefore discard the possibility of it being spam or err on the side of caution and treat as suspect (reject) and apply existing antispam procedures. Arguments could be made for either.
Within hms spf checking is only used as PART of anti-spam measures and such failure alone will not trigger a rejection outright (it requires other checks and score determinations). (It would be interesting to see how spamassassin spf checking behaves on the same message).
Post by SorenR » 2020-02-22 14:14
2020-02-22 09:23
We will see.
I compared the original 1.10 library and the library from hMailServer 5.6.8 ...
- First of all the #define's and the #include's in RMSPF.C has been changed by Martin.
- There are massive codechanges from about line 2000 in RMSPF.C, Martin aparently changed a lot.
I just had to try replace the old version with the new version and compiling 5.6.8 failed big time. This is NOT going to be an easy task!
Version 1.10 -> http://www.pamho.net/source/RMSPF110S.ZIP
Version 1.12 -> http://www.pamho.net/source/RMSPF112S.ZIP
Post by RvdH » 2020-02-22 18:11
I noticed mattg placed a pull request in github... I dunno if that is tested code or if he simply replaced the libs without building/testing
Post by SorenR » 2020-02-22 18:17
2020-02-22 18:11
It's not.....
Attached files compile on my 5.6.8 and seems not to crash when run... 8)
PS... What does your .24 version cover ??? SURBL ??? :wink:
SPF.rar
(24.09 KiB) Downloaded 423 times
Post by RvdH » 2020-02-22 18:33
2020-02-22 18:17
The question should be if it validates SPF records properly :)
2020-02-22 18:17
Yup, its the altered SURBL regex
Post by SorenR » 2020-02-22 18:55
2020-02-22 18:33
2020-02-22 18:17
2020-02-22 18:17
Well... I do not have sufficient traffic to test that. Sometimes when I test my script changes I may sit for two hours before the right event occur. :roll:
I'll move the "fix" to my production server sometime later today and then we'll see. I have to reinstate all my SPF settings :roll:
Somehow it makes sense as I have seen different answers from hMailServer and SpamAssassin for quite some time and that is also why all SPF checking on my server is done by SpamAssassin :mrgreen:
Post by RvdH » 2020-02-22 19:19
Well, that is most likely because spamassassin does a better job checking spf.....hmailserver doesn't do anything other then checking the sending ip against DNS spf record
There are quite a few macro's that could be used, for example %{h} that validates the message helo/ehlo, %{s} with senders email address and %{d} for senders domain
https://www.zytrax.com/books/dns/ch9/spf.html
Post by RvdH » 2020-02-22 20:32
For now we only have a claim spf isn't working, it might as well be a DNS problem... or did someone actually test hmailserver's behavior when it encounteres a spf record using the exists:%{1} macro implementation? Haven't seen a debug log (yet)
Post by jimimaseye » 2020-02-22 20:52
2020-02-22 20:32
For now we only have a claim spf isn't working, it as well be a DNS problem... or did someone actually test hmailserver's behavior when it encounteres a spf record using the exists:%{1} macro implementation? Haven't seen a debug log (yet)
I eluded to this earlier when op first made the claim but he hasn't provided the evidence yet :
2020-02-21 23:07
Post by SorenR » 2020-02-22 21:31
Well....
http://www.pamho.net/source/RMSPF112.TXT
I did spend some time comparing the original 1.10 and the 1.10 from hMailServer - Martin made a lot of changes to the code.
So far everything just blaze past my GreyListing with SPF so clearly something is off ... Until it is confirmed and verified that hMailServer do have a SPF problem I will revert my changes.
Post by mattg » 2020-02-22 22:53
2020-02-22 18:11
Simple replace - no testing
2020-02-22 20:32
No checks done
I did however note that the existing hMailserver code doesn't check macros, and that the RFCs changed in 2014.
I didn't do a line by line compare, but I did check first few lines, last few lines and some random ones in between. Doing a full text compare as SorenR did is much more sensible.
Should I will remove the pull request?
2020-02-22 19:19
...that is most likely because spamassassin does a better job checking spf...
I think we've all known this a long time
I was hoping that this was an easy fix.
Post by RvdH » 2020-02-22 22:54
As far i understand the exists:%{i} macro doesn't do much more as checking if the value in %{i} resolves to any A-record, the returned IP address does not need to match that of the sender. So this apparently is the worst option that you can define in your spf record as it security wise doesn't verify anything
Post by mattg » 2020-02-22 23:10
probably second worst behind +all which allows ANY IP address
Post by RvdH » 2020-02-22 23:25
2020-02-22 23:10
As long as hmailserver ignores exists:%{i} and/or doesn't give false positives once it encounters such SPF record we should be good in my opinion, but I like many others here do not rely on hmailserver anti-spam masseurs, and have spamassassin in place to do the spam checking
Post by mattg » 2020-02-22 23:29
Me too
I think the point of this thread though specifically is the 'don't greylist on spf pass' option
Greylisting in my view, has been fairly ineffective since gMail and Office365 and the likes have really ramped up their domain hosting. (with their multiple servers)
not greylisting for spf pass is one of the few solutions to that, but that does require spf checking to work in hmailserver
Post by RvdH » 2020-02-22 23:40
2020-02-22 23:29
Me too
True, but we only have seen a claim that says hmailserver fails spf verification if a SPF record containing exists:%{i} exists :)
2020-02-22 23:29
Therefor i have my spfverify.exe, that enables dynamic greywhitelisting for the big ones (eg: gmail.com, outlook.com)
Basically spfverify.exe checks sending ip against HELO/EHLO domain SPF record, and because most of those use TLS, once they send the 2nd HELO/EHLO command they are whitelisted from greylisting when verified
Post by SorenR » 2020-02-23 18:13
2020-02-22 09:23
mikernet wrote:
2020-02-22 06:24
We will see.
https://datatracker.ietf.org/doc/rfc7208/ This explains why a new RFC was issued in 2014 when in fact the original from 2006 is still very much valid.
RFC 7208 was made due to updates in ... or as a result of ... RFC 8616, RFC 8553 and RFC 7372. From what I can read then RFC 4408 dated April 2006 should still be valid. The update to RFC 4408 by RFC 6652 in december 2018 appear not relevant to the way hMailServer lookup the SPF record.
Testing RMSPF 1.12 with hMailServer was done again today but as it currently functions as a black box all I can say is "it does NOT give the expected result".
RMSPF 1.12 is dated around the same time as the release of RFC 4408 so perhaps we can hope the author was aware of it.
mikernet
Post by mikernet » 2020-02-23 20:02
2020-02-22 22:54
That's not the macro though. As stated in the op, the macros is exists:%{i}._spf.mta.salesforce.com. So if the email server is 1.2.3.4, it will verify that 1.2.3.4._spf.mta.salesforce.com exists, and that DNS server is setup to only respond with valid records for authorized email servers, which is a perfectly valid and reasonable way to handle SPF.
Post by RvdH » 2020-02-23 20:21
mikernet wrote:
2020-02-23 20:02
2020-02-22 22:54
Nope, the mechanism is: %{i}._spf.mta.salesforce.com, So if the email server is 1.2.3.4, it will verify that 1.2.3.4._spf.mta.salesforce.com exists by checking if a A-record exist for that domain
But a A-record lookup for 1.2.3.4._spf.mta.salesforce.com might return a different ip address, and is not limited to the original 1.2.3.4 that send the mail
https://www.zytrax.com/books/dns/apd/rfc7208.txt
5.7. "exists"
This mechanism is used to construct an arbitrary domain name that is
used for a DNS A record query. It allows for complicated schemes
involving arbitrary parts of the mail envelope to determine what is
permitted.
exists = "exists" ":" domain-spec
The <domain-spec> is expanded as per Section 7. The resulting domain
name is used for a DNS A RR lookup (even when the connection type is
IPv6). If any A record is returned, this mechanism matches.
Domains can use this mechanism to specify arbitrarily complex
queries. For example, suppose example.com publishes the record:
v=spf1 exists:%{ir}.%{l1r+-}._spf.%{d} -all
Post by jimimaseye » 2020-02-23 20:29
We are still tackling a problem that we haven't yet proven exists. We are still assuming the macro is the cause of the original failure and are still waiting for the proof that .
mikernet
Post by mikernet » 2020-02-23 20:31
2020-02-23 20:21
mikernet wrote:
2020-02-23 20:02
2020-02-22 22:54
Nope, the mechanism is: %{i}._spf.mta.salesforce.com, So if the email server is 1.2.3.4, it will verify that 1.2.3.4._spf.mta.salesforce.com exists by checking a A-record exist for that domain
It doesn't matter what IP it returns as long as it WON'T return an A record for DNS entries that correspond to invalid email servers. The returned IP address doesn't mean anything other than "yes, the IP address that corresponds to the DNS record you requested is a valid email server".
How exactly is a nefarious sender going to take advantage of that? If a nefarious sender connects to hMailServer from IP 1.2.3.4 then the SPF record check will test 1.2.3.4._spf.mta.salesforce.com which in turn will NOT exist, since 1.2.3.4 is not a SalesForce email server.
*** dc1.singulink.com can't find 1.2.3.4._spf.mta.salesforce.com: Non-existent domain
mikernet
Post by mikernet » 2020-02-23 20:33
2020-02-23 20:29
Wee are still tackling a problem that we haven't yet proven exists. We arte still assuming the macro is the cause of the original failure and are still waiting for the proof that .
I'm working on a debug trace but that won't happen until Monday. The problem 100% exists that something in the VALID olg.ca SPF record is causing hMailServer to fail the SPF check though.
Post by RvdH » 2020-02-23 20:40
mikernet wrote:
2020-02-23 20:31
2020-02-23 20:21
mikernet wrote:
2020-02-23 20:02
How exactly is a nefarious sender going to take advantage of that? If a nefarious sender connects to hMailServer from IP 1.2.3.4 then the SPF record check will test 1.2.3.4._spf.mta.salesforce.com which in turn will NOT exist, since 1.2.3.4 is not SalesForce email server.
Sure, fine by me...i don't care much if it returns the expected ip address, but it my opinion it should (most i tested do)
For example: 52.31.115.240 send a mail, spf exists:%{i}._spf.sparkpostmail.com is in place there
52.31.115.240._spf.sparkpostmail.com resolves to A RR 52.31.115.240
mikernet
Post by mikernet » 2020-02-23 20:43
2020-02-23 20:40
It literally makes no difference for the security of this particular mechanism, which you stated is problematic for some reason that I can't figure out. That simply isn't true. The IP returned is completely irrelevant and returning the same IP as the DNS test request would do nothing to improve the security of the process.
Post by SorenR » 2020-02-23 20:45
mikernet wrote:
2020-02-23 20:33
Wireshark ?? I believe you should be able to filter "dns.spf" ...
Post by RvdH » 2020-02-23 20:46
mikernet wrote:
2020-02-23 20:43
2020-02-23 20:40
I find that weird....but hey, that might be just me :)
mikernet
Post by mikernet » 2020-02-23 20:47
2020-02-23 20:45
mikernet wrote:
2020-02-23 20:33
I need OLG to send me an email first :) They won't be in the office again until Monday.
Post by RvdH » 2020-02-23 20:59
mikernet wrote:
2020-02-23 20:47
2020-02-23 20:45
mikernet wrote:
2020-02-23 20:33
FYI, spfverify and dynamic greylistwhitelisting mentioned above would have worked for your case
Post by SorenR » 2020-02-24 17:19
I'm afraid we will have to rework - or look for an alternative SPF Lookup solution.
It appears the author of the current solution (Roger Moser) is no longer serving the e-mail and conferencing needs of sincere followers of His Divine Grace A.C. Bhaktivedanta Swami Prabhupada ... ISKCON ... commonly known as the "Hare Krishna Movement".
Post by RvdH » 2020-02-24 20:44
2020-02-24 17:19
Because? v1.10 already is able to parse spf exists:%{i} records, you referenced the v1.12 release notes for used library yourself so you should have seen it didn't add anything for that specific task
My guess this greylist problem as referred to by the OP as nothing to do with the SPF records used....i suspect it to be a problem with DNS (lookup)
Post by jimimaseye » 2020-02-24 21:22
2020-02-24 20:44
Yep. Still waiting for the proof. Lots of supposition, and a smidge of coincidence, but no proof. And the fact that the code (quoted) shows macros already handled in 5.6 suggests we are eating time on this theory.
tunis
Post by tunis » 2020-02-25 09:43
Maybe the SPF record has more then 10 lookups?
RMSPF.cpp#L137
https://sendgrid.com/.../spf-limitations/
Post by RvdH » 2020-02-25 10:07
tunis wrote:
2020-02-25 09:43
RMSPF.cpp#L137
i count just 4 lookups...
include:_spf.fireeyecloud.com
include:spf.protection.outlook.com
include:_spf.salesforce.com
The "include", "a", "mx", "ptr", and "exists" mechanisms as well as the "redirect" modifier do count against this limit. The "all", "ip4", and "ip6" mechanisms do not require DNS lookups and therefore do not count against this limit
Post by SorenR » 2020-02-25 12:39
Came across this site https://vamsoft.com/support/tools/spf-policy-tester
Click on the "advanced" tab and use these data from the forum.
Sender IP Address: 40.107.223.80
Sender Address: XXXXXXX@olg.ca
HELO/EHLO Domain: NAM11-DM6-obe.outbound.protection.outlook.com
Yes, RFC says that if sender is not found the HELO/EHLO greeting should be used. :roll:
I can't include the output here due to formatting issues but --> Click on TEST ... A complete evaluation is made. Interesting in a sort of weird geek'ish fasion :mrgreen: 8)
It appears that only 2 of 10 lookups are used. If we assume the evaluation is performed (top down) the same way hMailServer is doing it (still need to see a WireShark trace of the DNS data exchange) then the "_spf.salesforce.com" record is not even queried thus the macro is never "seen" AND this reveals a completely different problem alltogether.
Post by RvdH » 2020-02-25 13:41
2020-02-25 12:39
Should, but hmailserver does not check SPF for HELO/EHLO altogether ....therefor my initial remark saying SPF testing in hmailserver is very limited/basic
mikernet
Post by mikernet » 2020-02-25 13:47
I don't think I've ever had a problem with HELO not being used before. I would be surprised if a legit mail sender would rely on that behavior. Would that not completely eliminate the purpose of SPF anyway?
The basic test in the link you provided which does not use HELO passes fine though.
Post by RvdH » 2020-02-25 13:53
https://vamsoft.com/support/tools/spf-policy-tester seems to stop processing once a match (pass result) is found, and therefor is not expanding/walking all spf record values
Post by SorenR » 2020-02-25 13:56
mikernet wrote:
2020-02-25 13:47
It would only be a problem if there is no sender... How often do you get emails with no sender?
A blank sender usually means a Delivery Notification in the form of a NDR ...
mikernet
Post by mikernet » 2020-02-25 13:57
Oh sorry, misread what he said.
Post by SorenR » 2020-02-25 13:59
2020-02-25 13:53
Anything wrong with that?
Post by RvdH » 2020-02-25 14:00
2020-02-25 13:59
2020-02-25 13:59
You noticed it didn't expand _spf.salesforce.com, i only giving the reason why
Post by SorenR » 2020-02-25 14:26
2020-02-25 14:00
2020-02-25 13:59
2020-02-25 13:59
I get that ... I have not been really deep into the rmspf.cpp code but is that not the way it works? It would seem a complete waste of time and cpu cycles to continue to the end and if that is the case then we have a different problem with SPF ...
+0 ms		Starting SPF policy evaluation.
			Policy: "v=spf1 ip4:34.223.9.0/24 ip4:34.223.11.128/26 ip4:34.223.11.192/26 ip4:34.223.12.0/25
			ip4:38.27.116.128/27 ip4:165.254.91.16/28 ip4:38.27.116.96/27 ip4:165.254.91.96/27
			ip4:149.13.95.32/27 ip4:154.57.155.16/28 ip4:209.135.212.132 ip4:162.210.234.132 ip4:100.25.99.0/25
			ip4:100.24.127.128/25 ip4:3.122.63.0/24 ip4:52.215.218.128/25 ip4:63.34.31.0/25 ip4:63.34.218.0/24
			ip4:3.123.5.0/24 ip4:34.223.36.0/24 ip4:3.93.93.0/24 ip4:3.112.99.0/24 ip4:3.112.100.0/25
			ip4:3.112.100.128/25 -all"
+0 ms		The policy passed syntax validation with 1 warning(s).
			Warning #1: The length of the policy (484 characters) exceeds the recommended limit of 450
			characters. This may cause the evaluation to fail (see RFC7208, Section 3.4.).
Post by RvdH » 2020-02-25 15:28
2020-02-25 14:26
Most likely
Off-topic...
I myself am a bit curious how that SPFMAXLOOKUPS is calculated, for a SPF record like "v=spf1 mx -all" you have to do 2 lookups, first query and resolve the MX record(s), next get the A-record for that record(s)
Post by SorenR » 2020-02-25 15:47
2020-02-25 15:28
2020-02-25 14:26
Most likely
Off-topic...
https://tools.ietf.org/html/rfc7208#section-4.6.4
Post by SorenR » 2020-02-25 16:21
Post by RvdH » 2020-02-25 16:41
For hmailserver?
the ARSoft.Tools.Net is written in C#, and hmailserver is written in C++
mikernet
Post by mikernet » 2020-02-25 21:36
"DEBUG"	63464	"2020-02-25 14:33:14.018"	"Creating session 940"
"DEBUG"	63464	"2020-02-25 14:33:14.018"	"Executing event OnClientConnect"
"DEBUG"	63464	"2020-02-25 14:33:14.440"	"Event completed"
"DEBUG"	63464	"2020-02-25 14:33:14.440"	"TCP connection started for session 939"
"SMTPD"	63464	939	"2020-02-25 14:33:14.440"	"40.107.223.81"	"SENT: 220 mail.singulink.com ESMTP"
"SMTPD"	83224	939	"2020-02-25 14:33:14.486"	"40.107.223.81"	"RECEIVED: EHLO NAM11-DM6-obe.outbound.protection.outlook.com"
"SMTPD"	83224	939	"2020-02-25 14:33:14.486"	"40.107.223.81"	"SENT: 250-mail.singulink.com[nl]250-SIZE 102400000[nl]250-STARTTLS[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	63408	939	"2020-02-25 14:33:14.518"	"40.107.223.81"	"RECEIVED: STARTTLS"
"SMTPD"	63408	939	"2020-02-25 14:33:14.518"	"40.107.223.81"	"SENT: 220 Ready to start TLS"
"DEBUG"	63408	"2020-02-25 14:33:14.518"	"Performing SSL/TLS handshake for session 939. Verify certificate: False"
"SMTPD"	83116	939	"2020-02-25 14:33:14.799"	"40.107.223.81"	"RECEIVED: EHLO NAM11-DM6-obe.outbound.protection.outlook.com"
"SMTPD"	83116	939	"2020-02-25 14:33:14.799"	"40.107.223.81"	"SENT: 250-mail.singulink.com[nl]250-SIZE 102400000[nl]250-AUTH LOGIN PLAIN[nl]250 HELP"
"SMTPD"	83036	939	"2020-02-25 14:33:14.830"	"40.107.223.81"	"RECEIVED: MAIL FROM:<XXXXX@olg.ca> SIZE=31985"
"DEBUG"	83036	"2020-02-25 14:33:14.955"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	83036	"2020-02-25 14:33:14.971"	"Spam test: SpamTestHeloHost, Score: 1"
"DEBUG"	83036	"2020-02-25 14:33:14.986"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	83036	"2020-02-25 14:33:15.033"	"Spam test: SpamTestSPF, Score: 0"
"DEBUG"	83036	"2020-02-25 14:33:15.033"	"Total spam score: 1"
"SMTPD"	83036	939	"2020-02-25 14:33:15.049"	"40.107.223.81"	"SENT: 250 OK"
"SMTPD"	63408	939	"2020-02-25 14:33:15.080"	"40.107.223.81"	"RECEIVED: RCPT TO:<XXXXXX@sbgamingsystems.com>"
"SMTPD"	63408	939	"2020-02-25 14:33:15.111"	"40.107.223.81"	"SENT: 451 Please try again later."
"SMTPD"	83224	939	"2020-02-25 14:33:15.143"	"40.107.223.81"	"RECEIVED: QUIT"
"DEBUG"	83224	"2020-02-25 14:33:15.143"	"Deleting message file."
"SMTPD"	83224	939	"2020-02-25 14:33:15.143"	"40.107.223.81"	"SENT: 221 goodbye"
"DEBUG"	63408	"2020-02-25 14:33:15.158"	"Ending session 939"
"DEBUG"	83924	"2020-02-25 14:33:20.096"	"No messages to index."
