IMAP Sync Issue
MarHMS
IMAP Sync Issue
Post by MarHMS » 2020-02-14 08:32
On February 12th at about 12:30 PM, the explorer.exe for our Windows Server 2012 R2 hanged. We were forced to shutdown the server.
Since that incident, we've been encountering synchronization issues with a few of our Outlook email clients. Not all emails would sync. For a few, no emails are being synced for the entire 2017-2019 period. The period is random for other affected users. However, all emails are being displayed when using our webmail, Afterlogic Webmail Lite.
We've followed articles online re IMAP related issues with the Outlook email client.
Removed and re-added both the IMAP account and the mail profile. Added INBOX to root folder. None of which helped.
Used the reset mail settings option in Outlook Professional Plus 2016 which seemed to have helped. The emails were slowly being synced in the Inbox IMAP folder, but then after an hour, the Inbox was empty. Upon restarting the client, the issue resurfaced.
Upon checking the hMailServer error log, the following errors were observed:
"ERROR"	2756	"2020-02-12 12:44:42.751"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: Source: ADOConnection::Execute, Code: HM10046, Description: Unknown error when executing SQL statement.
select * from hm_messages where  messageaccountid = ?  and messagefolderid = ?  order by messageuid asc
Microsoft OLE DB Provider for SQL Server
Query timeout expired"
"ERROR"	2640	"2020-02-12 12:45:50.841"	"Severity: 3 (Medium), Code: HM5406, Source: ClamAVVirusScanner::Scan, Description: Unable to connect to ClamAV stream port at localhost:1669."
"ERROR"	2740	"2020-02-12 12:46:25.204"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: Source: ADOConnection::Execute, Code: HM10046, Description: Unknown error when executing SQL statement.
"ERROR"	2760	"2020-02-12 12:46:37.582"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: Source: ADOConnection::Execute, Code: HM10046, Description: Unknown error when executing SQL statement.
"ERROR"	2772	"2020-02-12 13:58:17.329"	"Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR"	2772	"2020-02-12 13:58:17.329"	"Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - E:\HMAIL\Data\domain\email\A6\{A6BEDCF9-4862-4EF7-A480-1C7E62919265}.eml"
"ERROR"	2772	"2020-02-12 13:58:17.345"	"Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR"	2772	"2020-02-12 13:58:17.345"	"Severity: 3 (Medium), Code: HM4227, Source: File::ReadFile, Description: An unknown error occurred while reading file from disk."
"ERROR"	2772	"2020-02-12 13:58:17.345"	"Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR"	2772	"2020-02-12 13:58:17.345"	"Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - E:\HMAIL\Data\domain\email\8F\{8F4B9B55-10F3-4C4A-A99A-FC1B23ABC226}.eml"
"ERROR"	2772	"2020-02-12 13:58:17.501"	"Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR"	2772	"2020-02-12 13:58:17.501"	"Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - E:\HMAIL\Data\domain\email\DD\{DD0A17B1-639D-4151-80A0-086BE0573C9A}.eml"
Please assist.
Re: IMAP Sync Issue
Post by mattg » 2020-02-14 08:48
Seems like a dying disk to me
Run some disk checks on those drives
MarHMS
Re: IMAP Sync Issue
Post by MarHMS » 2020-02-14 08:51
2020-02-14 08:48
Server is a VM. Hyper-V on Windows Server 2016 in raid-5 config. All drives are healthy.
MarHMS
Re: IMAP Sync Issue
Post by MarHMS » 2020-02-17 18:47
2020-02-14 08:48
Ran the disk checks and no problem was identified.
Tried Thunderbird and I had to restart it to retrieve new emails.
Webmail works without a problem, it's just those desktop mail clients.
Re: IMAP Sync Issue
Post by mattg » 2020-02-17 23:39
Try turning off sync in thunderbird
Are these LARGE accounts? How many messages?
