Change to other account
PeterChan
Post by PeterChan » 2020-01-29 04:11
How to configure one other account vs SQL server?
Re: Change to other account
Post by mattg » 2020-01-29 05:12
You want to change your SQL server connection account?
Create a new user in SQL using SQL Server Management Studio or similar, AND then change the hmailserver.ini to reflect the change
PeterChan
Post by PeterChan » 2020-01-29 05:20
Thanks. Previous password was encrypted below
Username=sa
Password=****************removed********
How to put other password well?
Post by mattg » 2020-01-29 05:45
It is Blowfish encrypted
./bin/DBSetupQuick.exe is probably easiest way to enter new username and password
PeterChan
Post by PeterChan » 2020-01-29 10:58
Sorry, nothing comes out, in the following
Post by Dravion » 2020-01-29 14:14
DBQuick.exe does this:
if (_application.Database.DatabaseType == hMailServer.eDBtype.hDBTypeMSSQLCE ||
             _application.Database.DatabaseType == hMailServer.eDBtype.hDBTypeUnknown)
            InitializeInternalDatabase();
It basically creates a Internal MS-SQL-CE Database, but it doesn't create a MS-SQL Server (not CE), a MySQL or PostgreSQL Database, but it launches DBUpdater.exe if a Database
was already created and needs a updated Database SQL-Structure or Data. DBUpdater.exe quits if nothing is to do.
PeterChan
Post by PeterChan » 2020-01-30 05:50
What does nothing happen, when I call "DBSetupQuick.exe"?
PeterChan
Post by PeterChan » 2020-01-31 06:39
Any help?
