diagnostic error
cuiting813
diagnostic error
Post by cuiting813 » 2020-01-07 12:26
someone who can help me ? I follow the video:
https://www.youtube.com/watch?v=ht6gK0hGfPA
every step is correct, but I have error:
Test: Collect server details
Database type: MySQL
Test: Test IPv6
Test: Test outbound port
Local address is 35.223.93.114.
ERROR: Unable to bind to address 35.223.93.114.
Test: Test backup directory
Test: Test MX records
Trying to resolve MX records for everyrains.com...
Host name found: mail.everyrains.com
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain everyrains.com...
Trying to connect to host mail.everyrains.com...
Trying to connect to TCP/IP address 35.223.93.114 on port 25.
ERROR: Was not able to open connection.
nitro
Re: diagnostic error
Post by nitro » 2020-01-07 12:50
It seems a port error, check the following link to check that they are configured correctly.
https://www.hmailserver.com/forum/view ... 906cd0221d
You must also ensure that the ports are routed to your computer. If I telnet to port 25 of your ip, the server does not respond to me.
Post by mattg » 2020-01-07 16:37
I think you have a value in SMTP >> Advanced >> bind to
You should leave that blank unless you KNOW that you need it
