Providing a client certification to a remote server when acting as a relay
rcroteau
Post by rcroteau » 2019-11-15 03:54
HI,
I have a requirement to present a client certificate to the remote SMTP server I'm relaying to. Going thru the docs, forums and googling around, I've come to the conclusion that hMailServer doesn't allow for that requirement for now.
Am I correct in my assessment or have I missed something :?:
mikedibella
Re: Providing a client certification to a remote server when acting as a relay
Post by mikedibella » 2019-11-15 06:03
You can do that with stunnel.
The config would look something like this:
[SMTPwithClientAuth]
client = yes
accept = 127.0.0.1:2525
connect = smtp.remote-server.com:465
delay = yes
CAFile = remote-server-root-certificate.pem
Cert = my-client-certificate.pem
key = my-client-certificate.key
verify = 2
Point your Route to localhost:2525 without SSL/TLS and stunnel will connect to smtp.remote-server.com on port 465, negotiating TLS and verifying the remote's server certificate is signed by remote-server-root-certificate.pem and presenting my-client-certificate.pem as the client certificate.
