Autoban weirdness
Autoban weirdness
Post by palinka » 2019-11-12 16:17
Something strange happened last night. Its actually happened a couple of times before but this is the first time I investigated it.
I run a script every 5 minutes to check telnet with the logic that if there is no response, something must be wrong and therefore, restart hmailserver service. That script is here: https://www.hmailserver.com/forum/viewt ... 01#p215301
Early this morning, someone (unknown account) attempted to login through webmail (on localhost) and 127.0.0.1 got autobanned. Autoban priority is 20 and My Computer IP Range priority is 25. For some reason, despite the priority elevation, 127.0.0.1 was denied access, therefore, my script was denied access and that started a loop of restarting hmailserver service until the autoban expired 1 hour later. I also noticed my activesync mail clients failed login (connection is via WAN -> https:443 -> localhost on hmailserver), so its not an issue particular to my script - 127.0.0.1 was genuinely blocked during the autoban.
So the question is: why did My Computer IP Range not override the autoban? Running 5.7.0. Is this a bug?
If I'm just wrong and this is not a bug, is there a strategy to work around it?
Settings:
2019-11-12   Hmailserver: 5.7.0-B2486
DOMAINS
   "Domain1.com" - 12x.dyxx.com                   Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - djxxxxx.dyxx.com               Enabled: False
   "Domain3.com" - lixxx.dyxx.net                 Enabled: True
                                                Private key: c:\xampp\apache\conf\altcerts\dynu.net\mail._domainkey.Domain3.com.pem
                                                Selector:    mail
   "Domain4.com" - pixxxx.us                      Enabled: True
                   Max message size:        0   Header:   Relaxed  Plus addressing:  True
                   Max size of accounts:    0   Body:     Relaxed  Character:           +
                                                Private key: c:\xampp\apache\conf\altcerts\Domain4.com\mail.Domain4.com.pem
                                                Selector:    mail
   "Domain5.com" - q-xxx.com                      Enabled: True
        Greylisting:     False
   "Domain6.com" - rgxxxxx.com                    Enabled: True
                                                Private key: c:\xampp\apache\conf\altcerts\Domain6.com\mail.Domain6.com.pem
                                                Selector:    mail
   "Domain7.com" - spxx.dyxx.net                  Enabled: True
        Greylisting:     False
   "Domain8.com" - wax.dyxx.net                   Enabled: True
  Enabled: False   Max size:                0   Enabled: True      Catchall: sms@Domain8.com
                                                Private key: c:\xampp\apache\conf\altcerts\dynu.net\mail._domainkey.Domain8.com.pem
                                                Selector:    mail
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 25     Name: My computer
     External To Local    -  True              External To Local    -  True
     External To External - False
IP: 192.168.99.0 - 192.168.99.255     Priority: 15     Name: LAN
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
                              Minutes Before Reset:            5  (0.08 hours, 0.00 days)
There is a total of 6 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Domain8.com         Empty sender:       True  Batch recipients:   100
Max Msg Size: 40960  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                      EXTERNAL.TLD  (ok)       Disc. on invalid:   True  Delivered-To hdr: False
                     Port: 587                 Max number commands:   3  Loop limit:           5
                     Con. Sec.: StartTLS Required
  Routes:
    Domain5.com              - S: Local   R: Local  - Addr: All         (ok)
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  3       Use SPF:            True - 3    Use Spamassassin:    True
  Add X-HmailServer-Subject:  True    Verify DKIM:       False        Use SA score:        True
              Subject Text: "[POSSIBLE SPAM]"
  Spam delete threshold: 8000         Maximum message size: 1024
DNSBL ENTRIES:
                 torexit.dan.me.uk      Score: 6     Result: 127.0.0.100
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
                  dbl.spamhaus.org      Score: 5
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              [*redacted*][@t]tmomail[dot]net
              0.0.0.0            to    255.255.255.255              +1[*redacted*][@t]tmomail[dot]net
              0.0.0.0            to    255.255.255.255              tims[@t]stripersonline[dot]com
ANTIVIRUS
GENERAL:
  Max Message Size: 26214
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   lews-combined
       Certificate: C:\ProgramData\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org\Domain8.com-chain.pem
       Private key: C:\ProgramData\letsencrypt-win-simple\httpsacme-v01.api.letsencrypt.org\Domain8.com-key.pem
   Domain8.com
       Certificate: C:\xampp\certificates\Domain8.com-chain.pem
       Private key: C:\xampp\certificates\Domain8.com-key.pem
SSL/TLS
             TLS 1.0 :  False
             TLS 1.1 :  False
             TLS 1.2 :   True
             TLS 1.3 :   True                Verify Remote SSL/TLS Certs:   True
SslCipherList  :
HIGH                            - !TLSv1                          - !SSLv3;
               0.0.0.0         / 25    / SMTP   -   StartTLS Optional   Cert: Domain8.com
               0.0.0.0         / 110   / POP3   -   StartTLS Optional   Cert: Domain8.com
               0.0.0.0         / 143   / IMAP   -   StartTLS Optional   Cert: Domain8.com
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: Domain8.com
               0.0.0.0         / 587   / SMTP   -   StartTLS Optional   Cert: Domain8.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: Domain8.com
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: Domain8.com
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-11-12.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-11-12.log
    Event:    C:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Last Event: 2019/11/12
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory X:\HMS-BACKUP is writable.
There are 4 error logs in the log directory.
HMAILSERVER.INI
Database folder:
Data folder:     X:\HMS-DATA\Data
Type=              MYSQL
Username=          hmailserver
Port=              3306
Server=            localhost
Internal=          0
[settings]
DisableAUTHList=25
Re: Autoban weirdness
Post by RvdH » 2019-11-12 21:41
Autoban priority is changed in 5.7.x
https://www.hmailserver.com/forum/viewt ... =7&t=34313
Post by palinka » 2019-11-12 23:18
2019-11-12 21:41
My autoban entries are being reported as priority 20. Are they actually 100? Is this a bug or a setup problem?
Post by mattg » 2019-11-12 23:50
2019-11-12 21:41
ONLY on the version used by that user
ie Dravion's version
hMailserver still sets them at 20
Post by mattg » 2019-11-12 23:51
2019-11-12 16:17
Can you show logs of this happening please
Post by palinka » 2019-11-13 00:01
2019-11-12 23:51
2019-11-12 16:17
I will as soon as I get back to my computer, but they don't show anything other than "denied access due to ip range policy" or something to that effect.
Also, everything went back to normal exactly when the autoban expired (1 hour). Basically, hmailserver service was restarted every 5 minutes for that hour - as should be expected under those circumstances. But why were the priorities not respected?
Post by RvdH » 2019-11-13 00:14
2019-11-12 23:50
2019-11-12 21:41
No, maybe your used scripts do, but hmailserver 5.7.x internally set them to 100 (eg: a faulty login via webmail or such, that block localhost being only 30 if default score is used)
Prove? Here you go: https://github.com/hmailserver/hmailser ... n.cpp#L120
Post by palinka » 2019-11-13 00:47
2019-11-13 00:14
2019-11-12 23:50
2019-11-12 21:41
In my hmailserver admin interface and also the webadmin, autobans are showing as priority 20.
My autobans are mostly called by script and they are all currently showing priority 20. The one that triggered the restart loop was a bad logon. Unfortunately I didn't get a chance to see it because it was the middle of the night and expired before I got up.
I just intentionally attempted logon with a bad password and indeed, the autoban was priority 100. Also, I looked at the autoban script I use (Soren's) and it does make the priority 20, so that accounts for what I'm seeing in the IP ranges.
I guess that's the answer. Problem solved.
edit - changed My Computer and LAN IP ranges to 125, tested bad logon again and everything is working fine again. Autoban called for bad logon and I can still connect to localhost. Life is good again. :mrgreen:
Post by RvdH » 2019-11-13 00:50
2019-11-13 00:47
I know :)
But i am still a bit curious why martin changed that value in 5.7.x, i really can't see a reason for that and as it shows it breaks running instances...so it is a silly change in my opinion
Post by palinka » 2019-11-13 00:53
2019-11-13 00:50
2019-11-13 00:47
I know :)
Some of us are a little slower... :lol:
Post by jimimaseye » 2019-11-13 01:59
2019-11-13 00:14
Thats bloomin' rubbish. Why has he done that? That breaks rules on continual software development as it potentially makes upgrading problematic - people will have to review and modify their configuration with ip ranges to ensure webmail ranges are now over 100 instead of 20. I wonder if he knows he has done it and left out there (perhaps it was a temporary thing 5 years ago when the development was just for his own use).
Post by mattg » 2019-11-13 08:18
Has he also changed the default internet and Localhost rages Priority
Post by RvdH » 2019-11-13 09:57
2019-11-13 08:18
Only the 'My computer' range is higher, eg: 30 instead of the 15 it was before.... 'Internet' range is still 10
Post by jimimaseye » 2019-11-13 10:05
2019-11-13 09:57
2019-11-13 08:18
It seems like he has just stuck his finger in the air and chosen numbers depending on the direction of the wind. It doesn't make sense.
Post by RvdH » 2019-11-13 11:03
The change of the 'My computer' range i kinda could understand, as a default install with previous value (15) would lockout localhost when auto-ban (20) is enabled...but once he also changed the auto-ban priority in 5.7.x the change to the 'My computer' range is redundant again
I have also posted this on github, https://github.com/hmailserver/hmailserver/issues/306
Maybe martin can explain
Post by palinka » 2019-11-13 13:37
2019-11-13 09:57
2019-11-13 08:18
Nothing changed for me - meaning I upgraded and my old settings remained the same, but the new autoban = 100 was unknown to me until I investigated it yesterday.
Post by RvdH » 2019-11-13 13:52
2019-11-13 13:37
2019-11-13 09:57
2019-11-13 08:18
That only would be the case in a new/fresh database on 5.7.x indeed, if you upgraded and retained your previous settings it remains te same
des519
Post by des519 » 2020-07-15 23:12
OMG!!!!!!!!!! 😇
I have lost 5 night's sleep over this issue.
This now works for my external ip app to send me notifications
internet 10 - 5.7 default
localhost 80 - was 30
external ip app 100 - had to set to this to make it work.
