Issue to connect
Re: Issue to connect
You aren't giving us much to work with
Is this a clean install?
What has recently changed?
Show the contents of your hMailserver.ini with the passwords changed to the text '***password***' please
See below
ProgramFolder=C:\Program Files (x86)\hMailServer
DatabaseFolder=
DataFolder=C:\Program Files (x86)\hMailServer\Data
LogFolder=C:\Program Files (x86)\hMailServer\Logs
TempFolder=C:\Program Files (x86)\hMailServer\Temp
EventFolder=C:\Program Files (x86)\hMailServer\Events
[GUILanguages]
[Security]
AdministratorPassword=???
Type=MYSQL
Username=root
Password=???
Port=3306
Server=127.0.0.1
Database=hmail
Internal=0
Check if MySQL Service is running and try again
Yes, MySQL80 is running.
What libmysql.dll do you have? Currently hmailserver is only working with libmysql.dll 5.x and won't work with libmysql.dll 8.x
Please see the file below and how to know its exact version?
Does it mean I should not use MySQL80?
If you have Visual Studio 2013 installed, you can see if you running the 32 or 64 Bit version of libmysql.dll by running this command
dumpbin /headers "C:\Program Files\MySQL\MySQL Server 8.0\lib\libmysql.dll" | findstr "machine"
Result could be: machine (x64) which means it is a 64-Bit DLL.
But be careful!
hMailServer 32-Bit can only use 32-Bit versions of libmysql.dll while x64 (64-Bit Versions) can only use 64-Bit Version of libmysql.dll.
You also need to be aware that libmysql.dll Version after 5.24.x will not work. If you install MySQL Database server version 8.x the libmysql.dll
version which can bin found in the MySQL Installfolder \ lib Directory doesn't work with any version of hMailServer. Your need a version 5.24.x but not later!
But be careful!
MySQL57 (version 5.7.28) service is up and running and how to resolve issue below
to ensure hMailserver would be connecting to MySQL57?Re: Issue to connect
you need a 32 bit version of libmysql.dll
Currently, file below
C:\Program Files\MySQL\MySQL Server 5.7\lib\libmysql.dll
is 64-bit. Does it mean it would be fine if 32-bit libmysql.dll file is being used?
yes
exactly what we are saying
hMailserver is 32 bit, it needs the 32 bit .dll to connect to the database
I already set up 5.7.28 (32-bit) on server but I still have got the issue below
Can you confirm that the database is accessible using a MySql administrator such as MySQL Workbench?
You can also try a telnet to the address and port of Mysql where you should get an answer
Yes, I can access MySQL 5.7 using root password. Here is what I've got with telnet command (on port 3306).
Intente seguir el procedimiento para confirmar que usa la dll correcta.
https://www.hmailserver.com/forum/viewtopic.php?t=31562
