SENT: 535 Authentication failed. Restarting authentication process.
miha123
Post by miha123 » 2019-10-03 11:12
Hi guys.
I am struggling to set hmailserver settings and DNS for about a week now. Problem is that my mails are getting into the spam folder in Gmail. I did and read everything on the forum but can't find a solution to my problem.
I have also set all DNS records OK according to https://mxtoolbox.com/domain
Can you help me with this?
Bellow is a configuration for my system:
[code]2019-10-03   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - ebxx.si                        Enabled: True
                                                Private key: c:\dkim\dkim.Domain1.com.pem
                                                Selector:    dkim
   "Domain2.com" - mixxxxxxxx.si                  Enabled: True
                                                Private key: c:\dkim\dkim.Domain2.com.pem
                                                Selector:    dkim
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-10-03.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-10-03.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=          sa
Port=              0
Server=            web.minioffice.si
Internal=          0
[/code]
Re: SENT: 535 Authentication failed. Restarting authentication process.
Post by palinka » 2019-10-03 12:26
I don't understand the title of the post. Are you getting errors? You didn't mention any. Are you receiving mail? Any problems sending mail besides having it land in spam folders?
Config looks pretty vanilla. Nothing wrong with it, although you probably want to get some spam processing up and running.
You left a domain name in the bottom of the diagnostic, so i used it on some tests at mx toolbox. Everything looks good except your spf policy is set to soft fail. You should make that a hard fail. "-" instead of "~".
As far as gmail goes, they have their own reasons for sending you to spam. You'll only find out why by asking them. Good luck with that. :roll: However, there are some things you can do, and most of them you've already done (spf, dkim, dmarc). Have you registered with Google postmaster? https://gmail.com/postmaster/
miha123
Post by miha123 » 2019-10-03 12:44
Yes sorry for not describing things properly.
The title is error I am getting from log when sending to Gmail address (code bellow). On some other email providers (MS exchange) works OK.
After everything works, I am going to turn anti-spam ON.
About SPF policy I will change that to hardfail~.
I have also registered and successfully verify my domain and also subdomain (smtp) to postmaster (google). Strange is that sometimes it works for just some minutes (30min) and then again to spam.
"DEBUG"	6044	"2019-10-01 09:15:19.421"	"TCP connection started for session 12"
"SMTPD"	6044	12	"2019-10-01 09:15:19.421"	"45.142.195.150"	"SENT: 220 mail.****.si ESMTP"
"SMTPD"	6044	12	"2019-10-01 09:15:20.405"	"45.142.195.150"	"RECEIVED: EHLO User"
"SMTPD"	6044	12	"2019-10-01 09:15:20.405"	"45.142.195.150"	"SENT: 250-mail.***.si[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	372	12	"2019-10-01 09:15:21.405"	"45.142.195.150"	"RECEIVED: RSET"
"SMTPD"	372	12	"2019-10-01 09:15:21.405"	"45.142.195.150"	"SENT: 250 OK"
"SMTPD"	6044	12	"2019-10-01 09:15:22.421"	"45.142.195.150"	"RECEIVED: AUTH LOGIN"
"SMTPD"	6044	12	"2019-10-01 09:15:22.421"	"45.142.195.150"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	372	12	"2019-10-01 09:15:23.311"	"45.142.195.150"	"RECEIVED: dmFsZXJpZUBtaW5pb2ZmaWNlLnNp"
"SMTPD"	372	12	"2019-10-01 09:15:23.311"	"45.142.195.150"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	924	12	"2019-10-01 09:15:24.139"	"45.142.195.150"	"RECEIVED: ***"
"SMTPD"	924	12	"2019-10-01 09:15:24.155"	"45.142.195.150"	"SENT: 535 Authentication failed. Restarting authentication process."
"SMTPD"	372	12	"2019-10-01 09:15:25.374"	"45.142.195.150"	"RECEIVED: QUIT"
"SMTPD"	372	12	"2019-10-01 09:15:25.374"	"45.142.195.150"	"SENT: 221 goodbye"
Post by palinka » 2019-10-03 13:32
The log is not gmail. It's your hmailserver. It is a spammer trying to guess the password to account valerie at minioffice dot si. the password was incorrect and hmailserver is doing its job by booting the connection with an authentication error. valerie at minioffice dot si could not be authenticated due to incorrect password.
RECEIVED: EHLO User
This is a spambot. If you turned on check helo and check mx records, this guy wouldn't have even got to the stage where he could attempt to authenticate. (I think - to be honest I'm not sure if those tests reject the connection or add a spam score). Either way, it's just another day of being a mail admin. You're going to see a LOT of these unless you get hardened.
jim.bus
Post by jim.bus » 2019-10-04 14:11
First '~' is not an SPF Hard Fail It is the Soft Fail. You need to use '-' for a Hard Fail without the quotes. It's also possible GMail might be marking SPAM on Emails with an SPF Soft Fail. I believe I heard some Email Servers are fussy that way too because a Soft Fail is like not testing the server with SPF. It really didn't check anything for the Receiving Email Server because '~' (Soft Fail) means 'Accept all other Domains'.
Also GMail may be balk at your email if you don't have a PTR (Reverse DNS) entry for your Server. GMail is one of the fussiest of the Email Servers when it comes to receiving Email from other Email Servers so I would be surprised if they don't have a PTR check as well as an SPF Check.
