hmailserver Relaying Spam without Permission HELP!
- CopBlaster
- New user
- Contact:
I have been blacklisted by spamcop because someone sent emails to my sever spoofing my email address and for some reason hmailserver allows this?
I changed my password and it keeps happening. I do not allow external to external emails without authentication. Here is an example header where clearly the IP address this originated from is not mine:
Received: from BN6PR1101CA0018.namprd11.prod.outlook.com
(2603:10b6:405:4a::28) by CY4PR11MB1928.namprd11.prod.outlook.com
(2603:10b6:903:11e::18) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.20.2263.24; Fri, 20 Sep
2019 10:40:42 +0000
Received: from SN1NAM01FT009.eop-nam01.prod.protection.outlook.com
(2a01:111:f400:7e40::204) by BN6PR1101CA0018.outlook.office365.com
(2603:10b6:405:4a::28) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384) id 15.20.2284.19 via Frontend
Transport; Fri, 20 Sep 2019 10:40:42 +0000
Authentication-Results: spf=pass (sender IP is 93.174.95.43)
smtp.mailfrom=stdcarriers.com; student.sjvc.edu; dkim=fail (invalid public
key) header.d=stdcarriers.com;student.sjvc.edu; dmarc=pass action=none
header.from=stdcarriers.com;
Received-SPF: Pass (protection.outlook.com: domain of stdcarriers.com
designates 93.174.95.43 as permitted sender) receiver=protection.outlook.com;
client-ip=93.174.95.43; helo=mail.copblaster.com;
Received: from mail.copblaster.com (93.174.95.43) by
SN1NAM01FT009.mail.protection.outlook.com (10.152.65.54) with Microsoft SMTP
Server id 15.20.2199.13 via Frontend Transport; Fri, 20 Sep 2019 10:40:41
+0000
dkim-signature: v=1; a=rsa-sha256; d=stdcarriers.com; s=dkim;
c=relaxed/relaxed; q=dns/txt; h=From:Reply-To:Subject:Date:Message-ID:To:MIME-Version:Content-Type:Content-Transfer-Encoding:Content-Description;
bh=cckFWA8U9nJF45DxzSYjGjNf1N52CBPP/vzUa998DzY=;
b=NPFMpsmc+FjHVEJ7te0no4S0lo8ulLEIm2GEv5bjXp+tVwPN2dUciNpYbEVdD96pOrnPZJcDQjW+aU1IGJjwDzLb5ig3xGzAXbfSl5JMscuOHHu5tBkYw3J1S8n6+668Z6tR6+QPJ8JA62MuqJuSVOJT9AQxaJimT+DEe/EKrIggq4HCJfNcKsFrkghW/L8+60PGIUVnNGJKTulyndQaMZrZpaI2sPp1YCJXJH2Tyu9e8hDp0rFNR0AERl
V+5ljQ9/ODaDF928aCysCNFgLVpjVElUkHMyhKWhd9Uu+oVkUzUhzehVaIPb2velfh79XesvpKtoa5bIiQ90AEKe/icg==
Received: from [192.168.8.101] (Unknown [197.255.167.137])
by mail.copblaster.com with ESMTP
; Fri, 20 Sep 2019 02:20:52 -0700
Message-ID: <7E32DCCB-C0BD-4CD9-8956-C1E898A3BB65@mail.copblaster.com>
Content-Type: text/plain; charset="iso-8859-1"
MIME-Version: 1.0
Content-Description: Mail message body
Subject: Attention Fund Beneficiary
To: Recipients <webmaster@stdcarriers.com>
From: "Mr. John Wagner" <webmaster@stdcarriers.com>
Date: Fri, 20 Sep 2019 10:20:50 +0100
Reply-To: sprinig12@163.com
X-Antivirus: Avast (VPS 190919-4, 09/19/2019), Outbound message
X-Antivirus-Status: Clean
Return-Path: webmaster@stdcarriers.com
X-EOPAttributedMessage: 0
X-EOPTenantAttributedMessage: 3eb71b57-cc15-4846-8f7d-9f4b5370070a:0
X-Forefront-Antispam-Report: CIP:93.174.95.43;IPV:NLI;CTRY:NL;EFV:NLI;
X-MS-PublicTrafficType: Email
X-MS-Office365-Filtering-Correlation-Id: 479fe40f-29c0-4348-659d-08d73db6fbde
X-Microsoft-Antispam:
BCL:6;PCL:0;RULEID:(2390118)(7020095)(4652040)(5600167)(711020)(4605104)(4709080)(1402095)(71702078);SRVR:CY4PR11MB1928;
X-MS-TrafficTypeDiagnostic: CY4PR11MB1928:
X-MS-Exchange-PUrlCount: 1
2019 10:40:42 +0000
+0000
MIME-Version: 1.0
- jimimaseye
- Moderator
Re: hmailserver Relaying Spam without Permission HELP!
- CopBlaster
- New user
- Contact:
Here are the results of the script. I just enabled requiring authentication for internal to external addresses, so that is new.
2019-09-20 Hmailserver: 5.6.7-B2425
DOMAINS
"Domain1.com" - coxxxxxxxx.com Enabled: True
Enabled: False Max size: 0 Enabled: True
Max message size: 0 Header: Relaxed Plus addressing: False
Max size of accounts: 0 Body: Relaxed
Algorithm: SHA256 Greylisting: False
Private key: c:\pmta\dkim.Domain1.com.pem
Selector: dkim
"Domain2.com" - cyxxxxxxxxxxxxxxxxx.com Enabled: True
Private key: c:\pmta\dkim.Domain2.com.pem
Selector: dkim
"Domain3.com" - cyxxxxxxxxxxx.net Enabled: True
Enabled: False Max size: 0 Enabled: False
Max message size: 0 Plus addressing: False
Greylisting: False
"Domain4.com" - noxxxxxxxxxxxxx.com Enabled: True
Private key: c:\pmta\dkim.Domain4.com.pem
Selector: dkim
"Domain5.com" - noxxxxxxxxx.com Enabled: True
Private key: c:\pmta\dkim.Domain5.com.pem
Selector: dkim
"Domain6.com" - stxxxxxxxxx.com Enabled: True
Private key: c:\pmta\dkim.Domain6.com.pem
Selector: dkim
"Domain7.com" - stxxxxxxxxxxxx.com Enabled: True
Greylisting: False
"Domain8.com" - suxxxxxxxxxxxxx.com Enabled: True
Greylisting: False
IP RANGES
Allow connections Other
SMTP: True Antispam : False
POP3: True Antivirus: False
IMAP: True SSL/TLS: False
External To External - False
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: False
INCOMING RELAYS
No entries
MIRRORING Disabled
PROTOCOLS
SMTP
No. Connections: 0 No Retries: 4 Mins: 60 Plain Text: False Bind:
Host: EXTERNAL.TLD Empty sender: False Batch recipients: 100
Max Msg Size: 20480 Relay:- Incorrect endings: True Use STARTTLS: False
Loop limit: 5
Recipient hosts: 15
Routes:
No routes defined.
POP3
No. Connections: 0
IMAP
IMAP Quota: True
IMAP Idle: True
IMAP ACL: True
Delim: "."
ANTISPAM
Spam Mark: 5 Use SPF: True - 3 Use Spamassassin: False
Add X-HmailServer-Spam: True Check HELO host: True - 2
Add X-HmailServer-Reason: True Check MX records: True - 2
Add X-HmailServer-Subject: False Verify DKIM: True - 5
DNSBL ENTRIES:
zen.spamhaus.org Score: 3 Result: 127.0.0.2-8|127.0.0.10-11
bl.spamcop.net Score: 3 Result: 127.0.0.2
SURBL ENTRIES:
multi.surbl.org Score: 3
GREYLISTING:
Greylisting: False
WHITELISTING
No entries
Block Attachments: True
*.bat Batch processing file
*.cmd Command file for Windows NT
*.com Command
*.cpl Windows Control Panel extension
*.csh CSH script
*.exe Executable file
*.inf Setup file
*.lnk Windows link file
*.msi Windows Installer file
*.msp Windows Installer patch
*.pif Program Information file
*.reg Registration key
*.scf Windows Explorer command
*.scr Windows Screen saver
SSL CERTIFICATES
*Domain1.com
Certificate: C:\Users\Administrator\Documents\sslbk\certificate.cert
Private key: C:\Users\Administrator\Documents\sslbk\key.key
SSL/TLS
SSL 3.0 : True
TLS 1.0 : True
TLS 1.1 : True
SslCipherList :
RC4-SHA - HIGH - !aNULL
!eNULL - !EXPORT - !DES
!3DES - !MD5 - !PSK;
TCPIP PORTS Connection Sec
0.0.0.0 / 25 / SMTP - SSL/TLS !! External Email Blocked !! Cert: *Domain1.com
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - StartTLS Optional Cert: *Domain1.com
0.0.0.0 / 587 / SMTP - StartTLS Optional Cert: *Domain1.com
LOGGING Logging Enabled: False
Paths:-
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-09-20.log - !! ERRORS PRESENT !!
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Program Files (x86)\hMailServer\hmailbk is writable.
HMAILSERVER.INI
Type= MSSQLCE
Username=
Port= 0
Server=
Internal= 1
- jimimaseye
- Moderator
Good. That was your cause.
Also do it for Local To Local otherwise you will have an inbox full of spam.
- CopBlaster
- New user
- Contact:
How would it be possible for an external email to an external address to be treated as internal at any point?
How is an email from an external source effected by internal settings like that?
- CopBlaster
- New user
- Contact:
Now it seems like I can't send or receive any emails at all. Now that SMTP authentication is required even though I have passwords setup.
- jimimaseye
- Moderator
'External' means "domain not hosted by you" (it's nothing to with the machine address). Now you know that, look back at your settings.
(You'r email client will now require passwords to send).
- CopBlaster
- New user
- Contact:
External is domain not hosted by me, so how can hMailServer allow emails that claim to be from 123.com?
- jimimaseye
- Moderator
Without seeing the SMTP log file entries of the exchange it is not possible to verify this.
- CopBlaster
- New user
- Contact:
My delivery que has like 20,000 messages so I am deleting that, maybe then I can send and receive normally.
- CopBlaster
- New user
- Contact:
Working good now
- jimimaseye
- Moderator
Another spambot shut down.
Result.
Result.
- CopBlaster
- New user
- Contact:
Ah noA vulnerablity in hMailServer allowed these messages to be sent through the system without having to be authenticated.
This was CLEARLY a configuration issue with this ONE installation of hmailserver, where the mail admin changed a DEFAULT setting to an unsafe setting
And that site, no HTTPS, and copyright notice dated 2012
LOL. He said vulnerability. Oh noes! I better properly configure my installation so I'm not vulnerable too!mattg wrote: ↑2019-09-21 02:11Ah noA vulnerablity in hMailServer allowed these messages to be sent through the system without having to be authenticated.
