DKIM and aliased domains
ras07
Post by ras07 » 2019-08-21 03:11
I have hMailServer set up with a single domain, call it xyz.com.
I have xyz.org and xyz.net as domain name aliases (configured in Domains | xyz.com , Names tab).
The appropriate DNS TXT records are all set for xyz.com, xzy.org, and xyz.net. (All set to the same key.)
DKIM works fine for email sent from, for example, ras@xyz.com. But if I send from ras@xyz.org or ras@xyz.net, the email does not get signed (no dkim-signature header is created).
Is this expected behavior? Is there a way to get hMailServer to sign emails where the sending account is an aliased domain?
ras
Re: DKIM and aliased domains
Post by mattg » 2019-08-21 05:50
can't be done
Here is a work around >> viewtopic.php?f=7&t=33067&p=206863&hili ... as#p206772
And a enhancement request to vote on
viewtopic.php?f=2&t=29029&p=181446#p181446
Personally I still believe that the D in DKIM is 'Domain' and that DKIM should be individualised per domain (FQDN)
ras07
Post by ras07 » 2019-08-21 06:43
2019-08-21 05:50
Would be fine with me if it signed the message as the alias domain name, but used the same key
Post by mattg » 2019-08-21 06:55
How many accounts do you that use that domain name alias?
ras07
Post by ras07 » 2019-08-21 07:17
2019-08-21 06:55
A few dozen user accounts on 3 domains (all aliased together).
