can send, cannot receive email
Re: can send, cannot receive email
Post by mattg » 2019-07-15 13:48
First step
Run this an post the results >> viewtopic.php?f=20&t=30914
Joe
Post by Joe » 2019-08-15 02:17
I have the same problem. Here are the test results.
2019-08-14   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - 93xxxx.com                     Enabled: True
  Enabled: False   Max size:              100   Enabled: False
                   Max message size:       10                      Plus addressing: False
                   Max size of accounts:   10
        Greylisting:     False
IP RANGES
     IMAP:   True !! Protocol DISABLED !!      SSL/TLS:    False
     External To Local    -  True              External To Local    -  True
     External To External - False
     External To Local    -  True           !! External To Local    -  True !!
       !! EXTERNAL INBOUND ON SUB IP RANGES OR EXTERNAL DOWNLOADS ONLY !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
Max Msg Size: 20480  Relay:-                   Incorrect endings:  True  Use STARTTLS:     False
                      EXTERNAL.TLD  (ok)       Disc. on invalid:   True  Delivered-To hdr: False
                     Port: 465                 Max number commands: 100  Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
 !! Service Not Enabled !!
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2019-08-14.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2019-08-14.log
    Event:    C:\Program Files\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  C:\Program Files\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Program folder:  C:\Program Files\hMailServer\
Database folder: C:\Program Files\hMailServer\Database
Data folder:     C:\Program Files\hMailServer\Data
Log folder:      C:\Program Files\hMailServer\Logs
Temp folder:     C:\Program Files\hMailServer\Temp
Event folder:    C:\Program Files\hMailServer\Events
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v1.96, Hmailserver Forum.
Post by mattg » 2019-08-15 02:39
You have External to local requiring SMTP AUTH for the Internet range
That will never work
On the IP ranges tab there is a 'default' button - press that, then try again
Joe
Post by Joe » 2019-08-15 02:54
still don't seam to be able to receive.
DOMAINS
        Greylisting:     False
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Con. Sec.: SSL/TLS
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Joe
Post by Joe » 2019-08-15 03:04
Going to bed now. Day job starts at 4am :)
Post by mattg » 2019-08-15 03:31
check this list https://www.hmailserver.com/documentati ... om_outside
Also, some ISPs stop incoming port 25, but mostly only if they also block outgoing port 25
Please enable all logging, try and send to you from the internet and show all logs created after 30 seconds
If no logging then please detail your domain name so that we can test it
Joe
Post by Joe » 2019-08-15 14:12
The web site is 931mev.com
When i telnet the web page on port 25 it looks OK
When I telnet the static IP the ISP gave me in does not work. I think spamhause has the IP address blocked. The ISP is Frontier. I had to relay through their server to get the outgoing e-mail to work.
I won't be able to check the logs for a day or two. (never did get that webPHP to work)
Joe
Post by Joe » 2019-08-15 17:09
I got this error when I tried to send an e-mail from outside.
This is an automatically generated Delivery Status Notification.
THIS IS A WARNING MESSAGE ONLY.
YOU DO NOT NEED TO RESEND YOUR MESSAGE.
Delivery to the following recipients has been delayed.
<JD@931mev.com>
The reason for the problem:
4.1.2 - Bad destination host ‘Multiple DNS queries were attempted and failed: DNS Runaway Error looking up mail.931mev.com (A). Nameserver was: .\nDNS Runaway Error looking up mail.931mev.com (AAAA). Nameserver was: .’
mikedibella
Post by mikedibella » 2019-08-15 17:17
You have an MX record for 931mev.com that resolves to mail.931mev.com, but you do not have an A record for mail.931mev.com that resolves to an IP address.
Post by mattg » 2019-08-15 17:25
Your MX has a priority of 0, change that to 10
You have no A record for mail.931mev.com which should be fixed. My mx record points to an IPv4 address
https://intodns.com/931mev.com
Joe
Post by Joe » 2019-08-17 01:21
Attached is how I have Godaddy set up.
https://intodns.com/931mev.com still indicates I have no A Name. Did I do it right?
mikedibella
Post by mikedibella » 2019-08-17 01:27
No. The name should be just mail.
A mail 34.214.94.163
Joe
Post by Joe » 2019-08-17 01:38
Success!!!!!!!!!!!!!!!!
I don't think my ISP will give me a revers dns, but it did not seem to make a difference
Joe
Post by Joe » 2019-08-17 02:57
Thank You mattg and mikedibella!!!!
I have been futzing around with this since 2014. (good thing i have a day job, hey). Definitely owe you guys a beer.
Not sure that it matters, but I get the attached message when I run a diagnostics. But hey, everything works - send and receive!!
Thanks Again,
Joe
Post by mattg » 2019-08-17 03:03
That error is because you use port 465 in your SMTP Relayer
If your server works that's great
Do your self a favour and run some open relay tests
https://www.hmailserver.com/documentati ... elay_tests
Joe
Post by Joe » 2019-08-17 04:01
I don't have a default domain set.
I don't have catch-all address set.
First open relay test http://www.aupads.org/test-relay.html gave the following:
Relay test result
All tests performed, no relays accepted by remote host.
The second open relay test http://www.dnsgoodies.com/ gave the following:
Good News!
All tests for an open relay on your mail server failed.
Your mail server does not allow open relay.
So, I guess i'm good.
How often should I run these tests?
Is there anything else I should be on the look out for?
Would sending statistics help you monitor for abnormalities?
Post by mattg » 2019-08-17 05:15
Good work
Check that when you make changes to config
I keep SMTP logs so that I can track for too much mail, and you should at least check the size of those logs to ensure that you haven't been hacked.
I get about 15 -20 attempts most days to crack passwords, or to test my security
and I don't allow port 25 AUTH, so my numbers would be much higher if I did allow port 25 AUTH
just keep an eye on your logs
Joe
Post by Joe » 2019-08-17 07:00
Will do. Thank you Sir!
