thunderbird client-hmailserver
byrd44
Post by byrd44 » 2019-06-20 03:41
I setup hmailserver and configured it ...no errors it will let me send mail with thunderbird but cant receive mail. I will let a admin who knows hmailserver in my server to fix ….I tried everything .
byrd44
Re: thunderbird client-hmailserver
Post by byrd44 » 2019-06-20 03:46
thx in advance for any help ...I also read the forum help on troubleshooting it may be bout mx records ...don't know where to fix that on my server
Post by mattg » 2019-06-20 15:52
Run this and post the results
viewtopic.php?f=20&t=30914
Also, check the internal diagnostics in the GUI and post the results of that too please
byrd44
Post by byrd44 » 2019-06-20 23:51
2019-06-20   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - hixxxxxxx.com                  Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                      EXTERNAL.TLD             Disc. on invalid:  False  Delivered-To hdr: False
                  !! Target does not resolve !!
                     Port:  25                                           Loop limit:           5
                     Req Auth: False                                     Recipient hosts:     15
                     Con. Sec.: None
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 26    / SMTP   -   None
               0.0.0.0         / 2525  / SMTP   -   None
  Paths:-
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-06-20.log
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\Program Files (x86)\hMailServer\backuphmail is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
byrd44
Post by byrd44 » 2019-06-20 23:52
Test: Collect server details
Test: Test IPv6
Test: Test outbound port
SMTP relayer is in use.
Trying to connect to host mail.twc.com...
Trying to connect to TCP/IP address 107.14.73.68 on port 25.
Received: 220 dnvrco-cmomta02 cmsmtp 220 Welcome to Road Runner (WLIP).
Connected successfully.
Test: Test backup directory
Test: Test MX records
Trying to resolve MX records for hillbilly.com...
Host name found: park-mx.above.com
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain hillbilly.com...
Trying to connect to host park-mx.above.com...
Trying to connect to TCP/IP address 103.224.212.34 on port 25.
Received: 220 localhost go-smtpd.
Post by mattg » 2019-06-21 01:25
What do you have in the SMTP relayer fields?
can you please show a screenshot
byrd44
Post by byrd44 » 2019-06-21 03:20
ok here it is ty
Post by mattg » 2019-06-21 06:09
Can you enable all logging, try and send to your gmail/hotmail/yahoo etc account, wait 90 seconds and then post all logs created.
I suspect that the SMTP relayer doesn't work without username and password details
byrd44
Post by byrd44 » 2019-06-21 06:46
it works sending ...just cant receive.
byrd44
Post by byrd44 » 2019-06-21 06:59
"DEBUG" 4904 "2019-06-20 21:53:58.257" "Creating session 11"
"TCPIP" 4904 "2019-06-20 21:53:58.272" "TCP - 80.82.77.227 connected to 192.168.1.102:110."
"DEBUG" 4904 "2019-06-20 21:53:58.272" "TCP connection started for session 3"
"POP3D" 4904 3 "2019-06-20 21:53:58.272" "80.82.77.227" "SENT: +OK POP3"
"DEBUG" 4896 "2019-06-20 21:53:58.413" "The read operation failed. Bytes transferred: 0 Remote IP: 80.82.77.227, Session: 3, Code: 2, Message: End of file"
I can send mail from mail client to yahoo but when I send from yahoo to my hmail email acct I don't get the mail.
byrd44
Post by byrd44 » 2019-06-21 07:15
I put user name and pass in relayer section and it still lets me send to yahoo and I get mail in yahoo but when I send back to my email in hmailserver ….no luck receiving it.
Post by jimimaseye » 2019-06-21 10:20
byrd44 wrote:
2019-06-21 06:59
That section of logging does not relate to incoming email. Incoming mail will connect with SMTPD entries. Recheck.
If there are no connections when sending in then they are not teaching your server. Check firewall and inbound routing of port 25. Check external mx records point to your address.
Post by mattg » 2019-06-21 11:01
Your mx record points to
hillbilly.com. 3600 MX 10 park-mx.above.com.
I don't think that is your hMailserver?
Looking at the greeting in your internal diagnostics, that isn't a hMailserver greeting.
looks like a GoLang server response
Your incoming mail will ALWAYS be sent to the MX record
byrd44
Post by byrd44 » 2019-06-21 17:32
I have to go do business today. when I get back I will work on this some more ...thank you ….ill keep this open til we fix.
byrd44
Post by byrd44 » 2019-06-24 20:52
I ran hmail server in a vps on my computer before ...I created the domain. didn't have to buy a domain ...everything worked great .til I done this one ….can anyone team view with me and fix this issue ...im goin around in circles.thank you
Post by mattg » 2019-06-24 23:47
To be honest, I'm not sure that you meet the technical requirements to run a mailserver
shown at the bottom of this page
https://www.hmailserver.com/documentati ... quirements
It's not in the greater interest to have someone running a mail server from a VPS that they can turn on and off, with really bad DNS records. If that same server is managed by someone who doesn't understand the technical bits then sooner or later the spammers will get a hold of it (if you're not intending to spam yourself)
If you really need this, then you should PAY someone physically close to you to help you with the technical bits
