Port 25 SMTP not work after update
baccai
Post by baccai » 2019-06-14 18:19
Re: Port 25 SMTP not work after update
Post by katip » 2019-06-14 19:11
ur welcome :)
what you update?
Post by Dravion » 2019-06-14 19:30
Hi baccai
Run the following command
1) Open a Windows Command prompt
2) type in: sc query hmailserver
And post the result:
Should enable all Logging checkboxes (in hMailAdmin) in Section
Settings -> Logging ->
Enabled [x]
Application [x]
SMTP [x]
POP3 [x]
IMAP [x]
TCP/IP [x]
Debug [x]
Debug [x]
AWStats [x]
This will result in Logfiles into the Folder (Default folder is) C:\Program Files (x86)\hMailServer\Logs
After you enabled logging, try to repeat your action, accessing Port 25 and grab your logfiles and attache it to your
next reply.
64-Bit builds of hMailserver
