Working with attachments.
Post by SorenR » 2019-06-08 17:18
I'm exploring a bit of attachment handling as one of my users lost a word doc that was sent to her - and she did not bother to check it on receipt :roll:
Email clearly says:
The attachment %MACRO_FILE% was blocked for delivery by the e-mail server. Please contact your system administrator if you have any questions regarding this.
Administrator
Yeah... "The server is blocking the doc file and I can't get it" ... Me: "Nope, the server deleted it! Tell them to send it again and I'll switch protection off temporarely" ...
Now, IIRC hMailServer is doing it's AntiVirus stuff (including blocked attachment stuff) between OnDeliveryStart() and OnDeliverMessage() so ... If I intercept the message in OnDeliveryStart() and it matches one or more of the blocked attachments I can clone the message and forward it to a "Quarantine" account and let hMailServer do it's stuff on the original message. IIRC I can whitelist the "Quarantine" account to make it exempt from AntiVirus checking.
I also came across a thread here where someone wanted to rename certain attachments and it has not turned out to be such a straight forward task.
I'm playing with the idea to identify mails with the specific attachments and use RegEx to rename filenames directly in the .eml file and then use "oMessage.RefreshContent" to have hMailServer work with the new data.
I have no idea if it will work, there is only one way to find out 8)
Still need to play a bit with that ... In the meantime! I have a base of close to 10K SPAM mails and I have been playing :mrgreen:
Working with non-capturing groups in RegEx to get attachment filenames from Mime headers and the attachment object. I wanted to see if either can be relied on 100%.
I have in rare results seen Mime headers where the filename is NOT embedded in quotes and for some reason I fail to resolve a search string with optional quotes. Following are all embedded in quotes ...
FileName:       C:\hMailServer\Data\domain.tld\spam\34\{34AB7D0A-D953-4BF1-A391-6847BE1A5B26}.eml
Match:          Content-Type: image/jpeg; name="0EYH2LypqwM.jpg"
SubMatch:       0EYH2LypqwM.jpg
Match:          Content-Disposition: attachment; filename="0EYH2LypqwM.jpg"; size=58558; creation-date="Wed, 14
Attachment:     0EYH2LypqwM.jpg
FileName:       C:\hMailServer\Data\domain.tld\spam\61\{61F154A2-CD3B-4EBF-B47A-D710B9E18471}.eml
Match:          Content-Disposition: attachment; filename="INVOICE-Yu-Gi-Oh.docx"
SubMatch:       INVOICE-Yu-Gi-Oh.docx
Attachment:     INVOICE-Yu-Gi-Oh.docx
FileName:       C:\hMailServer\Data\domain.tld\spam\57\{57C0AB41-3FC7-41FD-8CD5-697AF8C16EB6}.eml
Match:          Content-Type: application/octet-stream; name="SEO-pricelist.html"
SubMatch:       SEO-pricelist.html
Match:          Content-Disposition: attachment; filename="SEO-pricelist.html"
Attachment:     SEO-pricelist.html
FileName:       C:\hMailServer\Data\domain.tld\spam\E8\{E8C9ABA0-5B69-4D40-A53B-28D401F244FE}.eml
Match:          Content-Type: text/html; name="Card Member Document.html"
SubMatch:       Card Member Document.html
Match:          Content-Disposition: attachment; filename="Card Member Document.html"
Attachment:     Card Member Document.html
Sub DoStuff(oMessage)
   Dim i, strRegEx, Match, Matches
   strRegEx = "^content-.*name=""(.*?)"".*"
      Set Matches = oLookup(strRegEx, .OpenTextFile(oMessage.Filename, 1).ReadAll, True)
   If (Matches.Count > 0) Or (oMessage.Attachments.Count > 0) Then
      WScript.Echo( "" )
'     WScript.Echo( LPad("To:", 15, " ") & vbTab & oMessage.HeaderValue("X-Envelope-To") )
'     WScript.Echo( LPad("From:", 15, " ") & vbTab & oMessage.HeaderValue("X-Envelope-From") )
'     WScript.Echo( LPad("Subject:", 15, " ") & vbTab & oMessage.Subject )
      WScript.Echo( LPad("FileName:", 15, " ") & vbTab & oMessage.Filename )
      For Each Match in Matches
         If Match.SubMatches.Count > 0 Then
            WScript.Echo( LPad("Match:", 15, " ") & vbTab & Match.Value )
            WScript.Echo( LPad("SubMatch:", 15, " ") & vbTab & Match.SubMatches(0) )
      If (oMessage.Attachments.Count > 0) Then
         For i = 0 To oMessage.Attachments.Count-1
            WScript.Echo( LPad("Attachment:", 15, " ") & vbTab & oMessage.Attachments(i).Filename )
Re: Working with attachments.
Post by SorenR » 2019-07-03 20:14
Changed direction a bit...
Sub OnDeliveryStart(oMessage)
        Dim i, strBaseName, TEMPDIR : TEMPDIR = "C:\hMailServer\Temp"
            '   Extract Base FileName from message {name}.eml
            strBaseName = .GetBaseName(.GetFile(oMessage.Filename))
            '   Save attachments prefixed with message filename
            oMessage.Attachments(i).SaveAs( TEMPDIR & "\" & strBaseName & "." & oMessage.Attachments(i).Filename )
            EventLog.Write( TEMPDIR & "\" & strBaseName & "." & oMessage.Attachments(i).Filename )
            On Error Resume Next
                '   Delete previously saved attachment
                .DeleteFile( TEMPDIR & "\" & strBaseName & "." & oMessage.Attachments(i).Filename )
                If Err.Number <> 0 Then
                    '   No file deleted means hMailServer changed the attached file filename
                    EventLog.Write( "FILE BLOCKED BY HMAILSERVER: " & TEMPDIR & "\" & strBaseName & "." & oMessage.Attachments(i).Filename )
            On Error Goto 0
Re: Working with blocked attachments.
Post by SorenR » 2019-07-04 01:32
Ready for testing.
When an email is received and hMailServer block the attachment, the blocked attachment is re-attached to a cloned message and sent to Postmaster.
    '    Check if 2'nd Run.
    If (oMessage.HeaderValue("X-hMailServer-AttachmentID") <> "") Then Exit Sub
        Dim oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject")
        '   1'st Run. Extract Base FileName from message {name}.eml
        strBaseName = oFSO.GetBaseName(oFSO.GetFile(oMessage.Filename))
        Set oFSO = Nothing
    Dim i, strBaseName, strFilename, TEMPDIR : TEMPDIR = "C:\hMailServer\Temp"
    Dim Blocked : Blocked = False
    Dim oFile, oFiles, oFolder, oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject")
        '   2'nd Run re-attach blocked file(s) for Postmaster
            .Pattern = oMessage.HeaderValue("X-hMailServer-AttachmentID")
            Set oFolder = oFSO.GetFolder(TEMPDIR & "\")
            Set oFiles = oFolder.Files
            For Each oFile In oFiles
                '    List files to re-attach.
                If .Test(oFile.Name) Then
                    oMessage.attachments.add(TEMPDIR & "\" & oFile.Name)
                    '   Delete file when attached.
                    oFSO.DeleteFile( TEMPDIR & "\" & oFile.Name )
        Set oFile = Nothing
        Set oFiles = Nothing
        Set oFolder = Nothing
        Set oFSO = Nothing
        '    We are done ...
        Exit Sub
            '    1'st Run Delete saved files
            oFSO.DeleteFile( TEMPDIR & "\" & strBaseName & "." & oMessage.Attachments(i).Filename )
            '    OOPS, no file to delete = attachment blocked by hMailServer
            If Err.Number <> 0 Then Blocked = True
        If Blocked Then
            '    Clone mail and prepare for 2'nd run to re-attach blocked file(s) for Postmaster.
                strFilename = .Filename
                oFSO.CopyFile oMessage.Filename, strFilename, True
                .RefreshContent
                '    Address to Postmaster.
                .AddRecipient "Postmaster", "postmaster@acme.inc"
                .HeaderValue("Message-ID") = "<" & CStr(oMessage.ID) & "-" & Mid(oMessage.HeaderValue("Message-ID"),2)
                .HeaderValue("X-hMailServer-AttachmentID") = strBaseName
                .Save
        On Error Goto 0
        Set oFSO = Nothing
        Exit Sub
    Set oFSO = Nothing
Post by SorenR » 2019-07-07 02:24
Update
    '   Exit Sub
    '   If no attachments, skip!
    If (oMessage.Attachments.Count = 0) Then Exit Sub
    EventLog.Write( "Sub OnDeliveryStart(oMessage)" )
    Dim ATTDIR : ATTDIR = "C:\hMailServer\Attachments"
    Dim i, strBaseName, strFolder
    '   Create unique folder.
    '   Eg: oMessage.Filename = {2B1BE048-D0DA-4743-B723-0C3A2E392134}.eml
    '                  Folder = C:\hMailServer\Attachments\2B\{2B1BE048-D0DA-4743-B723-0C3A2E392134}
    EventLog.Write( "(1'st run) strBaseName = " & strBaseName )
    strFolder = ATTDIR & "\" & UCase(Mid(strBaseName, 2, 2))
    If Not oFSO.FolderExists(strFolder) Then oFSO.CreateFolder strFolder
    strFolder = strFolder & "\" & strBaseName
    EventLog.Write( "(1'st run) strFolder = " & strFolder )
        EventLog.Write( "(1'st run) save attachment as " & strFolder & "\" & oMessage.Attachments(i).Filename )
        oMessage.Attachments(i).SaveAs( strFolder & "\" & oMessage.Attachments(i).Filename )
    Set oFSO = Nothing
    '   Exit Sub
    EventLog.Write( "Sub OnDeliverMessage(oMessage)" )
    Dim MAILNAME : MAILNAME = "Postmaster"
    Dim MAILADDR : MAILADDR = "postmaster@mydomain.tld"
    Dim i, strBaseName, strFilename, strFolder, Blocked : Blocked = False
    '   Delete saved attachments and mark blocked attachments for handling.
    If (oMessage.HeaderValue("X-hMailServer-AttachmentID") = "") Then
        strFolder = ATTDIR & "\" & UCase(Mid(strBaseName, 2, 2)) & "\" & strBaseName
            oFSO.DeleteFile( strFolder & "\" & oMessage.Attachments(i).Filename )
            If Err.Number = 0 Then
                EventLog.Write( "(1'st run) delete file " & strFolder & "\" & oMessage.Attachments(i).Filename )
                Err.Clear
                Blocked = True
                EventLog.Write( "(1'st run) delete file " & strFolder & "\" & oMessage.Attachments(i).Filename & " FAILED!" )
        On Error Goto 0
        EventLog.Write( "(1'st run) Blocked = " & Blocked )
        '   Send mail to Postmaster. Blocked file(s) will be attached later.
        If Blocked Then
            EventLog.Write( "(1'st run) send mail to " & MAILNAME )
                .RefreshContent
                .AddRecipient MAILNAME, MAILADDR
                .Subject = "[Blocked attachment] " & .Subject
                .Save
            Set oFSO = Nothing
            Exit Sub
        EventLog.Write( "(1'st run) delete folder " & strFolder )
        oFSO.DeleteFolder strFolder
        Set oFSO = Nothing
        Exit Sub
        '   Clear passed attachments.
        oMessage.attachments.Clear
        strBaseName = oMessage.HeaderValue("X-hMailServer-AttachmentID")
        EventLog.Write( "(2'nd run) strBaseName = " & strBaseName )
        EventLog.Write( "(2'nd run) strFolder = " & strFolder )
        Set oFolder = oFSO.GetFolder(strFolder)
        '   Re-attach blocked file(s) and delete folder.
            EventLog.Write( "(2'nd run) attach file " & strFolder & "\" & oFile.Name )
            oMessage.attachments.add(strFolder & "\" & oFile.Name)
        EventLog.Write( "(2'nd run) delete folder " & strFolder )
'       oMessage.HeaderValue("X-hMailServer-AttachmentID").Delete
        Set oFile = Nothing
        Set oFSO = Nothing
