SSL certificate for hMail server
DZeD
Post by DZeD » 2019-06-08 07:04
hMail ver 5.6.7-B2425
I am having trouble to install my SSL certfiicate - i have read this post
https://www.hmailserver.com/forum/viewtopic.php?t=22371
I created the private key and CSR using this information
https://knowledge.digicert.com/generali ... O1678.html
I purchased the certificate via RapidSSL and received
ServerCertificate.cer
CACertificate-ROOT-2.cer
CACertificate-INTERMEDIATE-1.cer
I am a little lost regarding the next steps to get this working - any guidance would be appreciated
Darren
Re: SSL certificate for hMail server
Post by Dravion » 2019-06-08 10:43
DZeD wrote:
2019-06-08 07:04
Darren
The only interresting file for hMailServer is ServerCertificate.cer but here where the Problems starts.
CER files are Microsoft crap which only works with Software using the Microsoft Windows SSL System but hMailServer (and most programs dont use the Windows SSL-System and relying on OpenSSL.
To makes things even more complicated, *.cer files
can be formatted as PKCS7 (Microsoft properitary)
and RSA x509 Format. The last format version can be used by hMailServer while the first format not and must be converted in X509 *.crt file format.
If you converted your ServerCertificate.cer to a ServerCertificate.crt file (X509 base64) you need to get your private Key file which was created as part of the CSR step. I hope you did not delete your Private key file because without it your purchased SSL-Certificate is complete useless.
Post by mattg » 2019-06-09 01:43
DZeD wrote:
2019-06-08 07:04
Perhaps you can detail WHAT trouble you are having so that we don't need to guess...
'Trouble getting this working' means what? That you don't know which files to use, OR that your smart phone rejects the certificates as untrusted OR that you have failed some online cert test OR
