hmailserver & Cloudflare
Technoman
Post by Technoman » 2019-05-26 09:37
I have a static IP and I host a MyBB website on my windows OS 7 here at home. I have transferred my Domain over to cloudflare so since cloudflare doesn't have a email server i decided to go with hmailserver hosting since it;s completely free. I would need the email server to send and receive emails through the MyBB smtp mail settings. Temporary right now for a few days I am using mailgun until i get hmailserver all setup.
I have never used a email server before but i defiantly want to try now as it's completely private and that is the way i like it
Ok so I am very good at following videos so my questions is are there any videos explaining how to setup our Domain email within hmailserver & Cloudflare?
Thank You
Re: hmailserver & Cloudflare
Post by jimimaseye » 2019-05-26 09:48
If you have a static ip and seeing up hms lb the end of that ip (presumably your home address) then why not simply point your mx dns entries for the domain to your static ip and send emails directly? Why do you want to channel through cloud flare servers?
Technoman
Post by Technoman » 2019-05-26 17:54
2019-05-26 09:48
Thanks @jimimaseye for the reply
Yes I am running a home webserver on windows with cloudflare pointing the Domain to my static ip
A. Where can i get the information that is needed for the mx, txt, cname that i can put into the dns entry of cloudflare as i have never done this before?
B. What do i need to configure or setup on the hemailserver?
I am new at all this bare with me please can you slowly walk me through this
Post by Dravion » 2019-05-26 20:56
In your Cloudflare DNS-Setting, first you need to add an A Record with your static, public ip pointing to your hMailServer and a Hostname.
Next you need to add an MX record which points to your A Record you created before (for your MX Record numeric value type in 10 or 20).
Now you need to wait 72h before your DNS-Settings are syncronized worldwide to all DNS-Zones.
This is only needed for SMTP . For POP3 and IMAP its easier. Your just should create an A Record with its Hostname poiting to your Public ip.
64-Bit builds of hMailserver
Technoman
Post by Technoman » 2019-05-26 21:20
Dravion wrote:
2019-05-26 20:56
Hi thanks for replying @Dravion
A record = Name + ipv4 address
example: mydomain.com + static ip
Dravion wrote:
2019-05-26 20:56
MX record = Name + Server + priority
example: mydomain.com + static Ip + 10
Above is this correct or am i missing something with hostname?
Configuring hemailserver will be next step after we get cloudlfare setup properly.
Post by mattg » 2019-05-26 23:45
A record like 'mail.example.com'
IPv4 Address = 123.123.123.xxx (static IP address goes here)
Leaving TTL to automatic is probably safe
MX Priority = 10
In HMailserver
Protocol >> SMTP >> Delivery of email >>Local host name
Also use 'mail.example.com' as above
If you can set an RDNS through your ISP, set it to the same 'mail.example.com'
Then if you want to really clever (not mandatory) get a certificate for that same address 'mail.example.com'
Technoman
Post by Technoman » 2019-05-27 04:54
2019-05-26 23:45
Thank you so the first part with A record has been done. Now it;s figuring out the rest of what needs to be put into the dns of cloudflare
MX record any guidance of what to put into cloudflare?
my domain is example mydomain.com
Post by mattg » 2019-05-27 07:03
Name is the same as you made for the MAIL A record
(hopefully like mail.example.com as opposed to example.com as you have written)
The bit that says 'click to configure' is where I'm guessing you will be asked for a priority, here put 10
Technoman
Post by Technoman » 2019-05-27 21:19
2019-05-27 07:03
I just want to know why i can't use mydomain.com instead I have to put mail.mydomain.com in other words then i would be forced using something.mail.mydomain.com and i dont want it like that i want support@mydomain.com that is the reason i only put mydomain.com. Then if it's only mydomain.com i can use *@mydomain.com correct?
Post by SorenR » 2019-05-27 22:29
Technoman wrote:
2019-05-27 21:19
2019-05-27 07:03
SERVER:
mail.mydomain.com A 123.123.123.123
[FQDN] A [IP Address]
MAIL DOMAIN:
MyDomain.com MX 10 mail.mydomain.com
[@domain] MX [priority] [server (FQDN)]
FQDN = Fully Qualified Domain Name
This will tell the world that mail for john.doe@mydomain.com is delivered to server on mail.mydomain.com.
Technoman
Post by Technoman » 2019-05-31 18:05
Thanks everyone in this community for trying to help me but unfortunately I am more of a visual person and up to now i have got no where but dead ends. I have checked Youtube and searched online to no avail in how to make hemailserver work with cloudflare in a production environment.
If anyone is out there who has hemailserver working alongside with cloudflare would you be kind enough to upload a video onto Youtube so that way i can follow it. Much appreciated!
mikedibella
Post by mikedibella » 2019-05-31 18:30
Login into the Cloudflare portal and select the domain corresponding to the right-hand side of your email address (i.e. email = my-name@my-domain, then select my-domain).
Choose the DNS tile from the top.
Using the Add Record button, add the following records:
Type, Name, Value, TTL
A, mail, public ip address of hMailServer interface, Automatic
MX, my-domain, server=mail.my-domain priority=10, Automatic
Replace my-domain above with the right-hand side from your email address.
That is all you need to receive mail.
Technoman
Post by Technoman » 2019-06-01 20:51
I was finally able to find a video on Youtube that covers pretty much email mx records plus public and private dkim key alongside with hemailserver this is a 2 part video except its not in English but regardless its something that i can try out.
https://www.youtube.com/watch?v=dRre45YJdHA&t=95s
Technoman
Post by Technoman » 2019-06-03 05:54
The only thing was i had to change the code a bit for dkim but its working 100% now. I'm so freaking happy! :D
Thanks guys for all the help!
