Blocking hackers gaining user names via "550 Unknown user"
superscan811
Post by superscan811 » 2019-05-12 11:31
Is there a way to Auto Ban an IP from consecutive attempts to gain valid email addresses via the 550 error, similar to the login attempt Auto Ban
Have been getting an excessive amount of attempts like this..
"SMTPD" 5108 3342 "2019-05-12 00:33:10.846" "185.222.211.30" "RECEIVED: RCPT TO:<ihk7o11olbvofcu@xxxxxx>"
"DEBUG" 5108 "2019-05-12 00:33:10.846" "AWStats::LogDeliveryFailure"
"SMTPD" 5108 3342 "2019-05-12 00:33:10.846" "185.222.211.30" "SENT: 550 Unknown user"
Cheers.
Re: Blocking hackers gaining user names via "550 Unknown user"
Post by SorenR » 2019-05-12 12:17
superscan811 wrote:
2019-05-12 11:31
Cheers.
Create a Catch-All user ... Then every thinkable username exists on your server :mrgreen:
superscan811
Post by superscan811 » 2019-05-12 13:03
I like that idea, only I have very limited bandwidth.
I manually firewall auto banned IP's, just to help gain back a little speed, rather than allow them to continuously re-attempt to login.
The majority of the time they end up being auto banned, because as soon as they find a valid email, their script attempt to login.
Just wanting to further reduce their impact.
Post by mattg » 2019-05-12 15:59
In SMTP >> RFC Compliance
What do you have for Maximum number of invalid commands?
I have mine set to 5
Post by SorenR » 2019-05-12 18:02
You could try this...
1: You will delay anything they do.
2: BOT's and general SPAM is all about time, if you delay them they skip your server.
3: Any LEGIT SMTP server WILL ignore the 20 sec delay and proceed to deliver mail.
4: Disable AUTH on port 25, move your clients to port 587 TLS or 465 SSL by inserting [settings] DisableAuthList=25 into hmailserver.ini.
Option Explicit
Function Wait(sec)
      .Run "timeout /T " & Int(sec), 0, True       ' Windows 7/2003/2008 or later
'     .Run "sleep -m " & Int(sec * 1000), 0, True  ' Windows 2003 Resource Kit
'     .Run "powershell Start-Sleep -Milliseconds " & Int(sec * 1000), 0, True
Sub OnClientConnect(oClient)
   '   Filter out "impatient" servers. Alternative to GreyListing.
Sub OnHELO(oClient)
'*  ********** SPAM test: DNSBlackLists, HeloHost, MXRecords, SPF
   If (oClient.Username = "") Then Wait(20)
'*  ********** SPAM test: SURBL, DKIM, SpamAssassin
'*  ********** Saving EML to DATA
'* Sub OnDeliveryStart(oMessage)
'* End Sub
'*  ********** Antivirus check, Global rules
'* Sub OnDeliverMessage(oMessage)
'* End Sub
'*  ********** Local rules, Message delivered to recipient(s)
'* Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'* End Sub
'* Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
'* End Sub
'* Sub OnBackupFailed(sReason)
'* End Sub
'* Sub OnBackupCompleted()
'* End Sub
'* Sub OnError(iSeverity, iCode, sSource, sDescription)
'* End Sub
'********** END        **********
