Having issues receiving email
coffeeman
Post by coffeeman » 2019-05-09 18:28
I am sure I have a configuration problem going on, but I can send email just fine. However, when I go to my exchange server that is on the same network, and try to send an email to the hMailServer domain, it fails.
I get a NDR.
I am sending out port 25, and trying to use IMAP port 143 as incoming.
I have the TCP/IP Ports configured 0.0.0.0 /25 - smtp, 110 for pop3 and 143 for Imap. I am not sure what I have wrong. Can someone please help? Thank you.
Re: Having issues receiving email
Post by jimimaseye » 2019-05-09 19:20
What does the ndr say?
coffeeman
Post by coffeeman » 2019-05-09 20:22
Here is the output:
2019-05-09   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - coxxxxxxxx.com                 Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
IP RANGES
IP: 10.10.0.100 - 10.10.0.100     Priority: 15     Name: coffeetest
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Domain0.com         Empty sender:       True  Batch recipients:   100
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-05-09.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-05-09.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2019-05-09 20:30
Have you checked or disabled the windows firewall?
coffeeman
Post by coffeeman » 2019-05-09 20:33
The NFR says:
<<<< 550 No Such User Here
550 5.1.1 <e@coffeetest.com> User unknown
I know that user is there because I see the accounts and I can send out as that user.
Post by jimimaseye » 2019-05-09 20:36
I suspect that is exchange replying to itself - that user doesn't exist on the exchange box. (That doesn't look like a hmailserver error code.)
coffeeman
Post by coffeeman » 2019-05-09 20:47
What code? I am not following. Why would exchange be doing that? Is there another way to test then? The test domain is not setup with an mx record so it is only internal.
Post by mattg » 2019-05-10 05:24
Here is a list of the hMailserver SMTP error responses
https://www.hmailserver.com/documentati ... sages_smtp
coffeeman wrote:
2019-05-09 20:33
Neither of these terms are on the inked list
This is CLEARLY not hMailserver responding to your exchange box.
This could be confimred by enabling all logging in hMailsevrer, repaeating the process to create the same situation, and checking the logs created by hmailserver that SHOULD NOT contain any record of a connection (because there isn't a connection)
