Send now, doesnt send now
cblaze22
Post by cblaze22 » 2019-05-05 02:47
Shouldnt the "send now" selection on something in the queue move it up the list and send it. I did this and the messages stay in the system for quite a while.
Re: Send now, doesnt send now
Post by mattg » 2019-05-05 03:40
They are actually sent straight away (or send next in the queue anyway) just that GUI doesn't update automatically
cblaze22
Post by cblaze22 » 2019-05-05 06:49
Ill take your word for it.
Is there anyway to use that function "send not" through scripting?
Post by mattg » 2019-05-05 09:06
yes, and I say that because the entire admin gui is written using the COM API
Anything that you can do in the admin gui, you can script
https://www.hmailserver.com/documentati ... iveryqueue
cblaze22
Post by cblaze22 » 2019-05-05 14:11
Ok work with me here. The below message is called before it goes in the queue correct?
OnAcceptMessage(oClient as hMailServer.Client, oMessage as hMailServer.Message)
If so can I check a header in this method and call the send now method you said I could. What would the correct syntax be ?
Post by mattg » 2019-05-06 03:23
Just done a quick test
Sent a mail to a non-existent address
OnAcceptMessage was fired when the message joined the queue
OnDeliveryStart is called for each delivery attempt
cblaze22
Post by cblaze22 » 2019-05-06 06:40
In your opinion then is it possible to run the method below, which is the "send now" logic within that method? I assume no because we dont have a MessageId? Is there no way to call .SAve on the message so we can get the messageId? I assume the code below does send the email right away, bypassing the queue.
 WaitCursor waitCursor = new WaitCursor();
            hMailServer.DeliveryQueue deliveryQueue = GetDeliveryQueue();
            foreach (ListViewItem item in listDeliveryQueue.SelectedItems)
                string messageID = (string)item.Tag;
                deliveryQueue.ResetDeliveryTime(Convert.ToInt32(messageID));
            deliveryQueue.StartDelivery();
            Marshal.ReleaseComObject(deliveryQueue);
Post by mattg » 2019-05-06 10:19
cblaze22 wrote:
2019-05-06 06:40
Did you test it..?
cblaze22
Post by cblaze22 » 2019-05-06 14:21
Well I would first need to check for headers for the important flag and go from there but shouldnt someone know how this method works or if .Save will save the message getting us an ID?
