adding virus scan signature
glue
Post by glue » 2019-05-01 10:43
new to hmailserver, how do i go about adding the virus scanned to sent and received emails
Re: adding virus scan signature
Post by mattg » 2019-05-01 10:52
Which Anti virus scanning software are you using?
glue
Post by glue » 2019-05-01 10:55
eset
Post by mattg » 2019-05-01 10:56
And how does ESET set message headers, or modify messages to say that mail is successfully scanned?
glue
Post by glue » 2019-05-01 11:04
as said new to this, not 100% sure
added
"C:\Program Files\ESET\ESET Security\ecls.exe" /log-file="C:\Program Files (x86)\hMailServer\Logs\nod32.log" /mailbox /unsafe /unwanted /preserve-time /clean-mode=strict "%FILE%"
and return value=50
to external virus scanner
as said by information found on forums
the log is working
ECLS Command-line scanner, version 12.1.34.0, (C) 1992-2019 ESET, spol. s r.o.
Module loader, version 1014 (20180123), build 1029
Module perseus, version 1551.1 (20190424), build 2018
Module scanner, version 19283 (20190501), build 41238
Module archiver, version 1286 (20190404), build 1295
Module advheur, version 1192 (20190204), build 1173
Module cleaner, version 1191 (20190410), build 1285
Command line: /log-file=C:\Program Files (x86)\hMailServer\Logs\nod32.log /mailbox /unsafe /unwanted /preserve-time /clean-mode=strict C:\Program Files (x86)\hMailServer\Data\{E1569BD5-9BF8-4CD9-ACFE-53B7E42148D2}.eml
Scan started at: Wed May 1 20:19:14 2019
Scan completed at: Wed May 1 20:19:14 2019
Scan time: 0 sec (0:00:00)
Total: files - 1, objects 1
Detected: files - 0, objects 0
Cleaned: files - 0, objects 0
Post by mattg » 2019-05-01 11:15
Perhaps you should check with ESET on how their product works if you are unsure
glue
Post by glue » 2019-05-01 21:41
thanks for your help
Post by mattg » 2019-05-01 22:45
Also, make sure you read the incompatible software here >> https://www.hmailserver.com/documentati ... quirements
This hasn't come up in many years, and suspect that IMON is no longer a part of ESET.
And after looking at this >> https://support.eset.com/kb3417/?locale ... cale=en_US
I can't see that they offer to write new mail headers or to change message content in any way
glue
Post by glue » 2019-05-02 07:37
yah, thanks for your help looking into it, its not a big issue just thinking peace of mind for some users
