cblaze22
- Normal user
Post
by cblaze22 » 2019-04-28 05:25
I setup a rule to delete anything going to noreply email address by testing if the message size > 0 and doing an action of delete on a rule on the account.
However, the queue still shows new items in it going to noreply? I would think they wouldnt hold up the queue in processing. We do about 1 million messages per day or more and have rejects which come back to our noreply and seem to stay there in the queue.
Content-Type: text/plain; charset="utf-8"
MIME-Version: 1.0
Return-Path: <>
Message-ID: <
DB8C4919-4A88-4CDF-8378-45CE922934EA@email.test.com>
Date: Sat, 27 Apr 2019 23:16:34 -0400
mailer-daemon@email.test.com
To:
noreply@test.com
Subject: Message undeliverable: 2019 Pittsburgh Jam Fest
X-hMailServer-LoopCount: 1
Sent: 27 Apr 2019 22:05:20 -0400
Subject: 2019 Pittsburgh Jam Fest
2152643050@comcastpcs.textmsg.com
Error Type: SMTP
Error Description: No mail servers appear to exists for the recipient's address.
Additional information: Please check that you have not misspelled the recipient's email address.
Tried 1 time(s)
hMailServer
- Moderator
Post
by mattg » 2019-04-28 06:19
Can you show your rule please
Is it an account level or global level rule?
cblaze22
- Normal user
Post
by cblaze22 » 2019-04-28 15:07
It is on the account level otherwise it would delete all emails.
General
Enabled
Criteria
Use And
Message Size Greater than 0
Actions
Delete e-mail
- Moderator
Post
by mattg » 2019-04-29 01:16
cblaze22 wrote: ↑2019-04-28 15:07
It is on the account level...
cblaze22 wrote: ↑2019-04-28 05:25
SO the message must be delivered to the account, before the account rule can delete it...that seems correct to me.
The email error that you show has the recipient as unknown. In that instance the message can't be delivered to an account, and so the account rule can't fire...
If you want to drop all messages that are going to ANY no-reply address (not just those on your server) then you need a global rule with conditions to find these messages.
cblaze22
- Normal user
Post
by cblaze22 » 2019-04-29 04:31
If I put the rule to drop messages to
noreply@test.com on the global level, will it then drop it?
Keep in mind the message says To:
noreply@test.com, which is an account within HMailServer, so it wont go anywhere anyway.
- Moderator
Post
by mattg » 2019-04-29 09:38
cblaze22 wrote: ↑2019-04-29 04:31
If you have delete message as an action of a global rule will that action happen? the answer is yes
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-05 02:45
Its still in my queue for processing. Does the rule not process until after it runs in the queue?
MIME-Version: 1.0
Return-Path: <>
Message-ID: <9CFA04F2-937F-4DD2-8D7C-979B88E01B0F@test.com>
Date: Sat, 4 May 2019 18:43:00 -0400
To: noreply@test.com
Subject: Message undeliverable: Caveman Classic
Sent: 4 May 2019 16:29:53 -0400
Subject: Caveman Classic
7243888948@txt.att.net
Error Type: SMTP
Remote server (166.216.152.132) issued an error.
hMailServer sent: RCPT TO:<7243888948@txt.att.net>
Remote server replied: 550 5.1.1 <7243888948@txt.att.net> recipient does not exist here.
hMailServer
- Moderator
Post
by mattg » 2019-05-05 03:42
Correct, for a rule to run on a message, hmailserver needs to process that message (by running it in the queue)
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-05 05:15
Well that sucks big time. I have like 1000 no reply messages just sitting in my queue because I cant delete them.
- Moderator
Post
by mattg » 2019-05-05 09:04
In the admin GUI you can 'clear queue' from the button at the top of the delivery queue page
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-05 14:09
That will clear all legit emails, like 39,000 of them.
- Moderator
Post
by mattg » 2019-05-06 02:01
You have 39 000 legitimate emails??
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-06 02:56
Yep....I run a tournament management service that sends game notifications so we have thousands going out a day
- Moderator
Post
by mattg » 2019-05-06 03:25
What are your delivery re-try settings?
Do you have the internet bandwidth to deliver tens of thousand of messages? Why are they building up in your queue?
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-06 04:51
0 retry. I mean I am on Azure with 2 cores and nothing else is used on this server except HMailServer. We just get so many notificadtions that come in I guess HMailServer cant keep up.
My Threading is
5
25
50
Highest
- Moderator
Post
by mattg » 2019-05-06 05:12
I'd set delivery threads to at least 100, possibly higher on that system
How much RAM is accessible on that system?
Can you get more cores? Two isn't very many for a machine that is that busy
How many messages per day?, I'm guessing many hundreds of thousands if you have 39K banked up
Asynchronous threads are used for AV and SpamAssassin and the like. Are you testing all messages for spam and AV?
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-06 06:29
I bumped it up to 100
7GB, currently only 3.5GB is being used.
I can get more cores and will probably do that before next weekend.
Probably over 100,000 per weekend day.
No need to test for Spam since we are sending the emails. Is there a way to turn that off so things go faster?
- Moderator
Post
by mattg » 2019-05-06 10:24
Run this and post the results
viewtopic.php?f=20&t=30914
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-06 14:33
Below are my results. I also donated to HMailServer a few days ago so we do appreciate you.
2019-05-06 Hmailserver: 5.6.4-B2283
DOMAINS
"Domain1.com" - emxxx.exxxxxxxxxxxxx.com Enabled: True
Enabled: False Max size: 0 Enabled: True
Max message size: 0 Header: Relaxed Plus addressing: False
Max size of accounts: 0 Body: Relaxed
Algorithm: SHA256 Greylisting: False
Private key: c:\4573822996847382.Domain2.com.pem.txt
Selector: 4573822996847382
"Domain2.com" - exxxxxxxxxxxxx.com Enabled: True
GLOBAL RULES
1, Delete No Reply Criteria: Use AND
To Equals noreply@Domain2.com
-----Actions-----
Delete
IP RANGES
IP: 127.0.0.1 - 127.0.0.1 Priority: 50 Name: My computer
Allow connections Other
SMTP: True Antispam : True !! 'Spam tests' not enabled !!
POP3: True Antivirus: True !! ANTIVIRUS NOT CONFIGURED !!
IMAP: True SSL/TLS: False
!! Warning: DEFAULT DOMAIN is SET !! - "Domain1.com"
AUTOBANNED Local Addresses:
No entries
AUTOBAN
Autoban Enabled: True Max invalid logon attempts: 3
Minutes Before Reset: 30 (0.50 hours, 0.02 days)
Minutes to Autoban: 600 (10.00 hours, 0.42 days)
INCOMING RELAYS
No entries
MIRRORING Disabled
PROTOCOLS
SMTP
No. Connections: 0 No Retries: 0 Mins: 0 Plain Text: False Bind:
Host: Domain1.com Empty sender: True Batch recipients: 25
Max Msg Size:200480 Relay:- Incorrect endings: True Use STARTTLS: True
Loop limit: 5
Recipient hosts: 15
Routes:
No routes defined.
POP3
No. Connections: 0
IMAP
IMAP Quota: True
IMAP Idle: True
IMAP ACL: True
Delim: "."
ANTISPAM
Spam Mark: 20 Use SPF: False Use Spamassassin: False
Add X-HmailServer-Spam: True Check HELO host: False
Add X-HmailServer-Reason: True Check MX records: False
Add X-HmailServer-Subject: True Verify DKIM: False
Subject Text: "[SPAM]"
Spam delete threshold: 5 Maximum message size: 1024
DNSBL ENTRIES:
No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
Greylisting: False
WHITELISTING
No entries
Block Attachments: False
SSL CERTIFICATES
No entries
SSL/TLS
SSL 3.0 : True
TLS 1.0 : True
TLS 1.1 : True
SslCipherList :
RC4-SHA - HIGH - !aNULL
!eNULL - !EXPORT - !DES
!3DES - !MD5 - !PSK;
TCPIP PORTS Connection Sec
0.0.0.0 / 110 / POP3 - None
0.0.0.0 / 143 / IMAP - None
0.0.0.0 / 587 / SMTP - None
!! No SMTP Port 25 defined. Direct external SMTP inbound not possible !!
LOGGING Logging Enabled: False
Paths:-
Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-05-06.log
Event: C:\Program Files (x86)\hMailServer\Logs\hmailserver_events.log - Last Event: 2019/05/06
SYSTEM TESTS
Database type: MSSQL
Backup directory C:\Users\cblaze22\Desktop is writable.
HMAILSERVER.INI
Database folder:
Type= MSSQL
Username= hmailserver
Port= 0
Server= 127.0.0.1
Internal= 0
- Moderator
Post
by mattg » 2019-05-07 02:04
So this machine doesn't accept any incoming mail, it only handles mail submitted via port 587. Correct?
what IP address(es) does the incoming mail get submitted from? I'm guessing this is from servers that you control.
Why do you have a default domain set?
Why do you have domains at all?
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-07 05:55
I control the servers that have permission to send to this server. It only sends out email via SMTP.
I use the domains for any loop issues, so emails will go to an external email by taking advantage of the forwarding.
- Moderator
Post
by mattg » 2019-05-07 10:48
cblaze22 wrote: ↑2019-05-07 05:55
Please give more detail about this concept...what are you hoping to achieve...and how
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-07 13:28
If I send an email to say
info@test.com from
noreply@test.com, it forwards to my gmail account. We do this so we can test with our own domain otherwise it stays in a loop in HMailServer and never makes it through.
Plus dont we need domains so we can use the DKIM?
- Moderator
Post
by mattg » 2019-05-08 12:59
Yes you do need a domain to use DKIM
By forwarding you are creating an extra message, effectively doubling the load. hMailserver has a loop count, so that messages aren't looped forever. This is a safety feature to stop the queue filling with dead messages
Why do you have a default domain set? Is this also for DKIM purposes?
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-08 13:46
The doubling isnt a big deal in that case since we send to ourselves rarely. If I want
noreply@test.com to go to
info@test.com, I have to have a valid email to get out of the loop like
test@gmail.com. I know there is a loop count, but the point is I need to get the email regardless, forwarding takes care of this, unless you know of a better way.
Where is the default domain at and why is that a problem?
- Moderator
Post
by mattg » 2019-05-08 14:08
Settings >> Advanced
having a default domain MAY create some bad DKIM signing, because hMailserver assumes that a FROM of 'coyote' is in fact FROM '
coyote@example.com' if example.com is the default domain.
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-09 02:21
Ill take your word for it. I removed it. Anything else you see needed in my report?
- Moderator
Post
by mattg » 2019-05-09 03:32
Only that I'd turn SSLv3.0 (at least) off - It is known to be broken
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-11 14:21
Will do, I also increased from 2 to 4 cores this weekend to see how the queue goes.
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-12 02:40
Good weekend, nothing in log at all. I think the cores helped. However I still get the original question issues where the email go into the queue for no reason. If I set some code in OnAcceptMessage to test for From:
mailer-daemon@email.test.com I believe I can drop it there correct and not have it go into the queue.
- Moderator
Post
by mattg » 2019-05-12 04:27
I reject messages in OnAcceptMessage but I don't delete them
Result.Value = 2
Unsure if delete will work or not
cblaze22
- Normal user
Post
by cblaze22 » 2019-05-17 20:58
So if I test for the mail-demon it will drop them if I do that in OnAcceptQueue and they wont show up in the queue?
- Senior user
Post
by SorenR » 2019-05-18 00:11
oMessages.DeleteByDBID is not an option until the message have arrived in the mailbox - after completing rule handling and the EventHandlers script. The alternative is to "do your stuff" and then send the email to a wastebasket or tag it with a header value and delete it by rule.
I did a test at the different levels to see what information was in the hm_messages table. Within the span of the EventHandlers script no AccountID not FolderID was observed thus no owner of the message was found. The implementation of the Messages object require either account object or account + folder object to be known.
Result.Value = 2 (or 1) will send an NDR with or without an explanation. You probably do not want to reply to a NDR with another NDR ...
