All ports blocked, is it possible?
bakunet
Post by bakunet » 2019-04-27 21:55
Hi everyone, I have a problem.
Since yesterday I am trying to use HMS on my machine. I installed, configured, all seems to be looking fine.
I try to use the mail server via client buit in C#. But seems to be my emails does not go out of my computer, so I started to investigate.
I fund a lot of topics saying, that blocked port 25 could be the problem.
Using cmd telnet at any random domain gives me 220. Seems to be fine.
I was surprised, when I was able to telnet port 25 on the DNS that should be routed to my machine.
Anyway, I kept investigating. The main problem for me right now is that when I test ANY incoming port on my IP, it shows me `blocked`.
I am using services like: https://www.canyouseeme.org/ , typing ports 25, 143, and many other random numbers.
My biggest question is, how it is possible, that all incoming ports are blocked? Is it possible, that my ISP blocked them all?
Thanks in advance for your help and feedback.
Re: All ports blocked, is it possible?
Post by mattg » 2019-04-28 03:11
It's more likely that your modem / router has blocked these ports for you automatically
Check that the necessary ports are forwarded through your modem / router
