You are only allowed to send from your own account
Kendo
Post by Kendo » 2019-03-27 01:06
Recently my mail server stopped allowing mail to be sent from my webforms on the same server. The logs show...
"You are only allowed to send from your own account"
All settings look ok.
Server, Computer and Internet are set the same. I rebooted hMailServer just in case, but it is still not allowing mail to be sent from local addresses to local addresses or external addresses.
Re: You are only allowed to send from your own account
Post by SorenR » 2019-03-27 01:16
Have you changed anything besides the Chinese SPAM rule thing?
Kendo
Post by Kendo » 2019-03-27 01:22
Not that I am aware of. It has been happening since before we added that new rule.
Post by mattg » 2019-03-27 01:24
Sounds like you have added one of these scripts as well
viewtopic.php?p=68117#p68117
Kendo
Post by Kendo » 2019-03-27 01:34
Nice catch. Yes I did add the 2nd script and that must be the cause. Have lost a lot of business since then.
But I don't understand... I thought that I was stopping mail being sent from the same address, like spammers do using From: you@domain.com To: you@domain.com
Anyways, I deleted the rule for now. Thanks!
Post by jimimaseye » 2019-03-27 01:46
For full advice and check up run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914. We will be able to advise what best to do.
Post by mattg » 2019-03-27 03:30
Kendo wrote:
2019-03-27 01:34
By default hMailserver allows users to AUTH with one account and send FROM another
Eg
AUTH with 'BartSimpson@example.com' and then send mail FROM 'president@whitehouse.com'
The second script stops that from happening.
To stop mail being FROM your domain to your domain, ensure that local to local requires AUTH in all relevant IP ranges (especially the internet range)
Post by jimimaseye » 2019-03-27 09:47
2019-03-27 03:30
Although sound advice, this wont necessarily help his problem, he needs to focus on the 'MY COMPUTER' range:
Kendo wrote:
2019-03-27 01:06
(this is why I suggested he runs the diag report and we can do an overall check for him)
Kendo
Post by Kendo » 2019-03-28 22:42
I deleted the script mentioned at viewtopic.php?p=68117#p68117 but now have spam sent from myaddess.example.com to myaddress@example.com again, even though I have SPF enabled.
I ran the diagnostic test and all it says is what my settings are...
2019-03-28   Hmailserver: 5.6.5-B2367
DOMAINS
   "Domain1.com" - adxxxxx.com                    Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - adxxxxx.com.au                 Enabled: True
        Greylisting:     False
   "Domain3.com" - arxxxxxxxxx.com                Enabled: True
        Greylisting:     False
   "Domain4.com" - arxxxxxxxxx.net                Enabled: True
        Greylisting:     False
   "Domain5.com" - brxxxx.net.au                  Enabled: False
   "Domain6.com" - coxxxxxx.net                   Enabled: True
        Greylisting:     False
   "Domain7.com" - joxxxxxxxxx.com.au             Enabled: True
        Greylisting:     False
IP RANGES
IP: 64.xxxxxxxxxx - 64.xxxxxxxxxxx     Priority: 30     Name: Server
     POP3:  False                              Antivirus:  False
     External To External - False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
                              Minutes Before Reset:           60  (1.00 hours, 0.04 days)
                              Minutes to Autoban:            120  (2.00 hours, 0.08 days)
There is a total of 15 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins: 60   Plain Text:         True  Bind: 64.71.130.99
                                               Max number commands: 100  Loop limit:           5
        Recipient hosts:     50
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 5    Use Spamassassin:   False
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 2
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Spam delete threshold: 5         Maximum message size: 1024
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-03-28.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-03-28.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -      .
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\inetpub\htdocs\temp is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Apparently I raised the question of SPF not working before at https://www.hmailserver.com/forum/viewt ... =7&t=30372 which recommended using a script mentioned above. While that solved this problem, it also blocked any mail sent to me by from sites on server.
None of my sites send myaddess.example.com to myaddress@example.com. Instead they are all someaddress@example.com to myaddress@example.com. So I need 2 things:
1. SPF working
2. script to block myaddess@example.com to myaddress@example.com
Post by SorenR » 2019-03-28 22:48
SPF will not save you....
Authentication on "Local To Local" and "Local To External" will...
As it is right now you might as well have a big sign saying "WELCOME to my server! The world is open from here."
Kendo
Post by Kendo » 2019-03-28 23:04
Ah, on Internet only?
Kendo
Post by Kendo » 2019-03-29 00:11
2019-03-27 03:30
Where are these set?
Post by SorenR » 2019-03-29 00:17
Kendo wrote:
2019-03-28 23:04
That would work...
How do your customers send mail normally? Webmail only?
Kendo
Post by Kendo » 2019-03-29 00:18
Without any SMTP Authentication settings, why doesn't SPF prevent non-authorised IP adresses as senders?
Kendo
Post by Kendo » 2019-03-29 00:20
2019-03-29 00:17
New clients use a webform on one of the websites. Some sites are on the same server and some on another (apache) server.
Established contacts email directly from their mail client.
Post by SorenR » 2019-03-29 00:29
Kendo wrote:
2019-03-29 00:20
2019-03-29 00:17
Right... Since you removed "Local-to-Local" and "Local-to-External" they can no longer send mail!
You should enable "Local-to-Local" and "Local-to-External" WITH authentication and "External-to-Local" WITHOUT authentication to restore service.
Post by SorenR » 2019-03-29 00:38
Erhm... I just had a closer look through your diagnostics...
What exactly is the role of hMailServer in your organisation?
The way I see it it is sort of "first in - never out"ish ... :?
Kendo
Post by Kendo » 2019-03-29 00:49
2019-03-29 00:38
1. To send mail from webforms on the same server.
2. To send mail from cms on the same server... from authors to subscribers.
3. To receive mail sent to the listed domains/accounts.
4. Received mail then gets resent to a separate server for POP pickup.
Post by SorenR » 2019-03-29 01:41
Kendo wrote:
2019-03-29 00:49
2019-03-29 00:38
4. Received mail then gets resent to a separate server for POP pickup. <=== !!
OK, that explains the missing IMAP and POP access, so I't mainly automation and filtering. :mrgreen:
Kendo
Post by Kendo » 2019-03-29 02:01
Without any SMTP Authentication settings, why doesn't SPF prevent non-authorised IP addresses as senders using local email addresses?
Post by jimimaseye » 2019-03-29 02:13
Possible soft fail? Misconfiguration? What is your spf record?
Kendo
Post by Kendo » 2019-03-29 02:29
2019-03-29 02:13
v=spf1 a mx ptr a:cp12.example.com ip4:64.71.130.99 ip4:64.71.130.100 ip4:64.71.130.101 ip4:64.71.130.102 ip4:64.71.130.103 ip4:74.200.85.166 ip4:64.202.189.1/16 ip4:116.250.207.34 ip4:116.250.255.1/16 ip4:116.250.254.1/16 include:apn.net.au -all
Post by jimimaseye » 2019-03-29 09:48
Kendo wrote:
2019-03-29 02:29
2019-03-29 02:13
Your SPF record allows your own mail server to send emails. Given you had internet ranges open, the spammer just need to connect to your box and then send the emails Local to Local (just as Soren described earlier). And your SPF record allows them.
So, tighten/implement authentication on your ip ranges (as previously discussed).
Kendo
Post by Kendo » 2019-03-29 10:37
2019-03-29 09:48
Of course it does. It is also listed as an allowed IP address. How else can websites hosted on it send mail outward?
Post by jimimaseye » 2019-03-29 15:12
I didn't say it was wrong. I was explaining why you were allowing spam through and that your spf is NOT the problem.
Kendo
Post by Kendo » 2019-04-12 23:00
In the settings for IP Ranges there are 3 options:
- Server
- My computer
- Internet
I assume that "Internet" means email sent via the internet using normal channel for SMTP, but what do the other 2 options mean specifically?
For example a spammer sending direct via my server... will appears as a local sender and be which option?
Post by SorenR » 2019-04-12 23:31
Kendo wrote:
2019-04-12 23:00
- Server
- My computer
- Internet
You can name the ranges any way you like. IP Ranges specify the permissions for any client/server in that particular IP range. Look at it like an inbound (to hMailServer) firewall.
Ranges can overlap and highest priority wins regardless of options.
For example, the AutoBan system will set a 1 IP address range with the offending IP address, all options off, put an expiration date on and set priority to 20. For ANY range below priority 20 with a matching IP address, the IP address will be IGNORED!
You can define your LAN range eg. priority 10, to require AUTH for SMTP, POP and IMAP and define a single IP address in the same IP range for your Backup automation server priority 11 to NOT require AUTH for SMTP if the software do not support it. Also you can allow or diallow POP/IMAP, allow or disallow sending mails to external recipients and so on.
The terms "Local" and "External" are not physical (like a firewall). "Locals" are YOUR hosted domains and "Externals" is everyone else. A user logging in from a different country with an account on your domain is still a "Local".
I hope that will clear things up a bit...
Usually pressing the "Default" button will set all IP Ranges to "Factory Default" and reasonable safe.
PS... There are a couple of pitfalls like; Assign your webmail server a priority > 20 if you do not want to shut it down due to some user forgetting his/hers password. ;-) Also relay servers like Backup-MX'es should be priority > 20 just in case and probably also your main AD/Admin client so you at least have one way in. 8)
Kendo
Post by Kendo » 2019-04-12 23:43
I understand the "local" and "external" email address difference and assume that the "Internet" range is for mail sent via SMTP to my server from outside the server, but what is the significance/difference between "Server, My Computer and Internet"?
Post by SorenR » 2019-04-13 00:10
Kendo wrote:
2019-04-12 23:43
"Server" ... Public (or pseudo-public LAN) IP address.
"My Computer" ... I assume this is localhost - to be used for hosting IIS and webmail - or webforms... Maybe...
"Internet" ... Is indeed - the rest of the IP world.
I presume "Server" and "My Computer" are there in case someone plants a BOT on the machine.
Kendo
Post by Kendo » 2019-04-13 01:32
And spammers sending mail via command prompt will be seen as Server or My Computer?
Post by mattg » 2019-04-13 01:38
Just to be clear
The default is 'My Computer' + 'Internet'
With my Computer being 127.0.0.1 to 127.0.0.1 with a priority of 15
Internet is 0.0.0.0 to 255.255.255.255 with a priority of 10
This can be achieved by pressing the 'default' button on the IP ranges page
If you have anything else listed there, you have added it.
Which one applies depends on the IP used in the connection, and the priority of that applicable IP range.
Higher priority number is a higher priority, ie 50 takes precedence over 20
Autobans are created automatically at priority 20
You need to see where the spammers are connecting from in the SMTP logs, and then use that IP address to work out which IP range applies.
A command prompt on the same machine as hMailserver is PROBABLY connecting from 127.0.0.1
If you have a spammer connecting from the machine that hMailserver is installed on, then you have a BIG problem
