who know the two numbers which before time and after protocal means
V587
Post by V587 » 2019-03-22 09:10
The Log like below ,I want to know 2136 and 6 means?
"SMTPD" 2136 6 "2019-03-22 03:15:35.853" "103.99.0.192" "SENT: 220 "
"SMTPD" 2128 6 "2019-03-22 03:15:36.025" "103.99.0.192" "RECEIVED: EHLO User"
"SMTPD" 2128 6 "2019-03-22 03:15:36.025" "103.99.0.192" "SENT: 250-CNGB00153[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
Re: who know the two numbers which before time and after protocal means
Post by jimimaseye » 2019-03-22 10:03
The 1st number is an internal identifier that is linked to individual processes that are taking place in code as it processes. It will mean nothing to you.
The 2nd number ("6") are unique 'sessions' that link for each email conversation that is taking place. This is the only number that is useful to you.
To see it in action post a section of log file in to https://log.damnation.org.uk/ and you will get a better understanding.
Post by SorenR » 2019-03-22 11:02
Actually, the first number is the Windows Thread ID from the code executing the specific log line(s).
Post by mattg » 2019-03-22 12:42
Well there is me learning something today
Post by SorenR » 2019-03-22 13:18
2019-03-22 12:42
I modified my 5.4.2 to include "obApp.Status.ThreadID" :mrgreen:
I use it for my LogWriter so I can crossmatch with the normal logging.
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.cpp hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.cpp
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.cpp	2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.cpp	2019-03-04 14:45:12.484375000 +0100
@@ -125,4 +125,20 @@
+STDMETHODIMP
+InterfaceStatus::get_ThreadID(long *pVal)
+   try
+      if (!m_pStatus)
+         return GetAccessDenied();
+      *pVal = m_pStatus->GetThreadID();
+      return S_OK;
+   catch (...)
+      return COMError::GenerateGenericMessage();
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.h hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.h
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/COM/InterfaceStatus.h	2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/COM/InterfaceStatus.h	2019-03-04 14:45:12.375000000 +0100
@@ -51,6 +51,7 @@
    STDMETHOD(get_RemovedViruses)(/*[out, retval]*/ long *pVal);
    STDMETHOD(get_RemovedSpamMessages)(/*[out, retval]*/ long *pVal);
    STDMETHOD(get_SessionCount)(eSessionType iType, long *pVal);
+   STDMETHOD(get_ThreadID)(/*[out, retval]*/ long *pVal);
 private:
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.cpp hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.cpp
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.cpp	2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.cpp	2019-03-04 14:45:12.625000000 +0100
@@ -158,4 +158,11 @@
       return SessionManager::Instance()->GetNumberOfConnections((SessionType) iSessionType);
+   int
+   ServerStatus::GetThreadID() const
+      DWORD dwThreadID = GetCurrentThreadId();
+      return dwThreadID;
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.h hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.h
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/Common/Util/ServerStatus.h	2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/Common/Util/ServerStatus.h	2019-03-04 14:45:12.562500000 +0100
@@ -36,6 +36,8 @@
       int GetNumberOfSessions(int iSessionType);
+      int GetThreadID() const;
    private:
       int m_iProcessedMessages;
diff -bur hmailserver-5.4.2-B1964/hmailserver/source/Server/hMailServer/hMailServer.idl hmailserver-5.4.2/hmailserver/source/Server/hMailServer/hMailServer.idl
--- hmailserver-5.4.2-B1964/hmailserver/source/Server/hMailServer/hMailServer.idl	2014-06-07 10:03:10.000000000 +0200
+++ hmailserver-5.4.2/hmailserver/source/Server/hMailServer/hMailServer.idl	2019-03-04 14:45:12.250000000 +0100
@@ -497,6 +497,7 @@
    [propget, id(4), helpstring("Gets the number of removed virues")] HRESULT RemovedViruses([out, retval] long *pVal);
    [propget, id(5), helpstring("Gets the number of detected spam messages")] HRESULT RemovedSpamMessages([out, retval] long *pVal);
    [propget, id(6), helpstring("Gets the current number of sessions")] HRESULT SessionCount([in] eSessionType iType, [out, retval] long *pVal);
+   [propget, id(7), helpstring("Gets the current thread number")] HRESULT ThreadID([out, retval] long *pVal);
