Sending to Alias returns 550 5.1.1
dlee5400
Post by dlee5400 » 2019-03-18 23:42
I noticed after my update to 5.6.7-B2425 that all of my domain's aliases have stop working. When I send an email from gmail to the hMailServer alias it bounces back with "550 5.1.1 <email@domain.com>: Recipient address rejected: User unknown in virtual mailbox table"
I have tested all of my aliases on various domains and all are not working. What am I missing?
Thanks,
David
Re: Sending to Alias returns 550 5.1.1
Post by jimimaseye » 2019-03-18 23:45
That doesn't look like a hmailserver rejection code - as far as i know hms doesn't issue 5.1.1 sub codes.
Yey to send one I and pay the resultant SMTPC log file entries showing the session issuing the rejection.
dlee5400
Post by dlee5400 » 2019-03-19 00:10
This is the complete message from gMail:
The response from the remote server was:
550 5.1.1 <support@domain.com>: Recipient address rejected: User unknown in virtual mailbox table
I looked in my logs and i don't see any interaction dealing with the 550 code or the email being sent.
Post by jimimaseye » 2019-03-19 00:20
Therefore as i suggested these emails are not going to your hmailserver. More likely a dns issue for your domain.
Anyway run this and post the results: https://www.hmailserver.com/forum/viewt ... 0&t=30914- let's check things.
dlee5400
Post by dlee5400 » 2019-03-19 00:35
2019-03-18   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - cexxxx.com                     Enabled: False
   "Domain2.com" - dexxxxx.com                    Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: dlee@Domain2.com
                   Max size of accounts:    0
        Greylisting: !! ENABLED BUT NOT ACTIVATED!!
   "Domain3.com" - epxxxxxxxxxxxxx.com            Enabled: False
      |- "Alias1.com" - epxxxxxxxxxxxxx.orx
      |- "Alias2.com" - epxxxxxxxxxxxxxxxx.orx
   "Domain4.com" - myxxxxxxxxxxxx.com             Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: closings@EXTERNAL.TLD
   "Domain5.com" - saxxxxxxxxx.com                Enabled: False
IP RANGES
IP: 162.207.248.252 - 162.207.248.252     Priority: 20     Name: DeCrouxOffice
IP: 71.164.175.2 - 71.164.175.2     Priority: 20     Name: FiOS - Home
IP: 99.21.80.208 - 99.21.80.208     Priority: 20     Name: LeeHome
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      6
                              Minutes Before Reset:           10  (0.17 hours, 0.01 days)
                              Minutes to Autoban:             15  (0.25 hours, 0.01 days)
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
Max Msg Size:     0  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  3       Use SPF:            True - 1    Use Spamassassin:   False
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 1
  Add X-HmailServer-Reason:   True    Check MX records:   True - 1
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 1
              Subject Text: "HMAILSERVER/ SPAMASSASSIN - [SPAM]"
  Spam delete threshold: 5         Maximum message size: 1024
DNSBL ENTRIES:
   No entries
SURBL ENTRIES:
   No entries
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              *[@t]sbcglobal[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]yahoo[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]gmail[dot]com
              0.0.0.0            to    255.255.255.255              mymobilecloser[@t]live[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]servicelinkfnf[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]quickendocs[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]alamotitle[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]freedomvoice[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]live[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]outlook[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]hotmail[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]notice[dot]nationalnotary[dot]org
              0.0.0.0            to    255.255.255.255              *[@t]nationalnotary[dot]org
              0.0.0.0            to    255.255.255.255              *[@t]oldrepublictitle[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]firstam[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]hexter-fair[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]khov[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]carefreetitle[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]reuniontitle[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]millslawoffice[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]farris-lawgroup[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]tstartitle[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]smartertitle[dot]pro
              0.0.0.0            to    255.255.255.255              *[@t]amazon[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]titlesource[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]fostechsolutions[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]eplus[dot]com
              0.0.0.0            to    255.255.255.255              dawnbuff[@t]sbcglobal[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]mxtoolbox[dot]com
              0.0.0.0            to    255.255.255.255              EthanZLee[@t]outlook[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]*[dot]*amazon*[dot]com
              0.0.0.0            to    255.255.255.255              sales[@t]rssbus[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]godaddy[dot]com
              0.0.0.0            to    255.255.255.255              BettyJoPierce[@t]Comcast[dot]net
              0.0.0.0            to    255.255.255.255              kendra[@t]closing-svcs[dot]com
              0.0.0.0            to    255.255.255.255              team[@t]fldivorcecourse[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]sears[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]*[dot]sears[dot]com
              0.0.0.0            to    255.255.255.255              *[dot]microsoft[dot]com
              0.0.0.0            to    255.255.255.255              *[dot]*[dot]ebay[dot]com
              0.0.0.0            to    255.255.255.255              sbnotary[@t]bellsouth[dot]net
              0.0.0.0            to    255.255.255.255              ben[@t]swiftsetup[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]lasys[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]lifemedid[dot]com
              0.0.0.0            to    255.255.255.255              kmartinez000[@t]centurytel[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]edcoxlaw[dot]com
              0.0.0.0            to    255.255.255.255              *[dot]orangehook[dot]com
              0.0.0.0            to    255.255.255.255              *[dot]outlook[dot]com
              0.0.0.0            to    255.255.255.255              [@t]salamanderlive[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]nuvelholdings[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]centurylink[dot]net
              0.0.0.0            to    255.255.255.255              *[@t]reomontana[dot]org
              0.0.0.0            to    255.255.255.255              *[@t]aubreyfranklin[dot]com
              0.0.0.0            to    255.255.255.255              mswozniak[@t]sbcglobal[dot]net
              0.0.0.0            to    255.255.255.255              dederichardson[@t]verizon[dot]net
              0.0.0.0            to    255.255.255.255              Darlataylor[@t]comcast[dot]net
              0.0.0.0            to    255.255.255.255              boernenotary[@t]reagan[dot]com
              0.0.0.0            to    255.255.255.255              julieschumer[@t]comcast[dot]net
              0.0.0.0            to    255.255.255.255              llbenz88[@t]aol[dot]com
              0.0.0.0            to    255.255.255.255              climmielaney[@t]sbcglobal[dot]net
              0.0.0.0            to    255.255.255.255              tsalvo[@t]mchsi[dot]com
              0.0.0.0            to    255.255.255.255              closings[@t]rimobilenotary[dot]com
              0.0.0.0            to    255.255.255.255              john[dot]cooper[@t]snmc[dot]com
              0.0.0.0            to    255.255.255.255              *[@t]giftnix[dot]com
  Block Attachments: False
SSL CERTIFICATES
   DeCroux
       Certificate: C:\Users\Administrator\Documents\Requested Certs\DeCroux\motwx8i4owq7okc7zoaepylrsbrx00y0\gd_bundle-g2-g1.crt
       Private key: C:\Users\Administrator\Documents\Requested Certs\DeCroux\mail.Domain2.com.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 465   / SMTP   -   None
    !! No SMTP Port 25 defined. Direct external SMTP inbound not possible !!
  Paths:-
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-03-18.log
SYSTEM TESTS
Database type: MSSQL
Backup directory C:\Users\Administrator\Documents\hMailBackup is writable.
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=
Port=              0
Server=            WIN-330CA5U63H3
Internal=          0
Post by jimimaseye » 2019-03-19 00:42
dlee5400 wrote:
2019-03-19 00:10
Err.....
No logging, no logs.
Also :
you only have domain 2 and domain 4 enabled (and neither of them have aliases I them. )
dlee5400
Post by dlee5400 » 2019-03-19 00:44
I turn the logs on when I am trouble shooting. After I tried to send to the alias I turned the logs back off.
Post by jimimaseye » 2019-03-19 00:45
See edit
dlee5400
Post by dlee5400 » 2019-03-19 00:48
I do see an autoband each time i send from gmail. Let me try to white list gmail
Post by jimimaseye » 2019-03-19 00:53
No point. It won't make any difference.
1, white listing only refers to spam checking (not mailbox or connections)
2, the mail isn't reaching your box in the first place and
3, you already have
*[@t]gmail[dot]com
dlee5400
Post by dlee5400 » 2019-03-19 01:26
I thought this posted but domain2 and 4 are the two I need working. And they both have aliases listed but in your tool I don't see the aliases. (did that post?)
Post by jimimaseye » 2019-03-19 01:37
dlee5400 wrote:
2019-03-19 01:26
Show screen shot of the aliases being associated to domain 2 and 4. (The script isn't wrong usually).
dlee5400
Post by dlee5400 » 2019-03-19 02:04
dlee5400
Post by dlee5400 » 2019-03-19 02:11
would the return header tell me who is giving that error to gmail or outlook.com? I looked in those return email headers but don't see anything from my server listed. So how is it that my server isn't send the rejection? Or listing in the logs that it is having a conversation with gmail and rejecting the request?
Post by mattg » 2019-03-19 02:18
Those are account aliases, not domain 'names'
The script picks up domain 'names'.
Those aliases should be treated exactly the same as normal accounts on those domains.
again, that error message isn't a hMailserver error message
Are you sending from your gmail account directly to the alias?
dlee5400
Post by dlee5400 » 2019-03-19 02:20
yes
Post by mattg » 2019-03-19 03:33
enable all logging
send to a 'normal account' on your hmailserver from a gmail account
ALSO send to an 'alias account' (same domain) on your hmailserver from a gmail account
Wait until you get an error in gmail, or at least 90 seconds, and then post ALL logs created
Post by jimimaseye » 2019-03-19 09:52
dlee5400 wrote:
2019-03-19 02:04
Not only are those account aliases and not Domain alias/names (as Mattg has already pointed out), they are against domain 1 and domain 3 which, we have already identified, are disabled. What's the point. (Remember you were trying to suggest that my script was incorrect and me asking for proof of there being domain aliases).
Your report and responses are just inconsistent and have not yet proven there to be a problem with hmailserver that can only be explained as a misconfiguration of DNS or misunderstanding on your own part on what you are doing.
Are you sure your initial problem is :
When I send an email from gmail to the hMailServer....
and not the other way round?
Post by mattg » 2019-03-19 10:31
2019-03-19 09:52
I don't think that is correct
The account aliases are under domains that start with D and M, which from the diagnostic report are domains 2 and 4
Also, in the initial post the OP does say
dlee5400 wrote:
2019-03-18 23:42
...my domain's aliases have stop working.
Which is NOT Domain aliases (or Domain Names) as they are called in hMailserver.
I think there has just been a misunderstanding.
Domains 1 & 3 in the diagnostics do have Domain Names (Domain Aliases in the diagnostic report), but these domains aren't active as you point out.
Lets do this...
2019-03-19 03:33
enable all logging
Post by jimimaseye » 2019-03-19 11:26
2019-03-19 10:31
2019-03-19 09:52
Hmmmm. Need to test. I thought the script listed the domains in the order they appear in the domain list.
Post by mattg » 2019-03-19 11:55
Always alphabetical I think, not in the order created (which is the same for me in the admin GUI)
ALSO I suspect that the screen shot just shows from the second domain
dlee5400
Post by dlee5400 » 2019-03-19 13:39
Hi All, back at this again. @jimimaseye I am certainly not suggesting your script is wrong. Sorry that came across that way, I looked in hMailServer this morning and saw the tab "NAMES" under the domain and now understand about domain aliases. When I used the term I thought hMailServer had only one references to aliases. Yes these are account aliases not domain aliases. Secondly, there are 5 domains with only two enabled, 2 - D...x.com and 4 m...r.com according to your script, and yes I cut off the others upon screen snipping.
I will run the test as requested and post the outcome here today.
Thank you all for helping.
David
Post by jimimaseye » 2019-03-19 14:39
2019-03-19 11:55
Ah good. I always thought they appeared in the same order as the gui. Thanks for confirming.
Post by jimimaseye » 2019-03-19 14:41
dlee5400 wrote:
2019-03-19 13:39
No worries. (I was quietly confident anyway). :wink:
dlee5400
Post by dlee5400 » 2019-03-19 15:11
How do i put the logs in this system? I am getting :
Your message contains 337122 characters.
The maximum number of allowed characters is 60000.
when i copy and paste it, also it doesn't accept .txt files when I try to do an attachment
Post by jimimaseye » 2019-03-19 15:19
Attach as a zip file.
You only need application and SMTP logging. Your logs will then also be a lot smaller.
dlee5400
Post by dlee5400 » 2019-03-19 15:20
Ok, sent email from my gmail account to c..s@m...r.com (domain 4 on script) and to alias m..g@m...r.com (domain 4 on script): here is what the logs captured.
rst-hmail-logs.zip
(17.95 KiB) Downloaded 22 times
Post by jimimaseye » 2019-03-19 15:38
SMTPD" 2852 119 "2019-03-19 07:41:03.348" "108.60.195.213" "SENT: 250 OK"
"SMTPD" 2880 119 "2019-03-19 07:41:03.410" "108.60.195.213" "RECEIVED: RCPT TO:<c...s@m...r.com>"
"SMTPD" 2880 119 "2019-03-19 07:41:03.410" "108.60.195.213" "SENT: 250 OK"
"SMTPD" 2888 119 "2019-03-19 07:41:03.473" "108.60.195.213" "RECEIVED: DATA"
"SMTPD" 2888 119 "2019-03-19 07:41:03.473" "108.60.195.213" "SENT: 354 OK, send."
"DEBUG" 2884 "2019-03-19 07:41:03.738" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 2632 "2019-03-19 07:41:03.738" "Executing task AsynchronousTask in work queue Asynchronous task queue" "DEBUG" 2632 "2019-03-19 07:41:03.738" "DKIM: Message passed validation."
"DEBUG" 2632 "2019-03-19 07:41:03.738" "Spam test: SpamTestDKIM, Score: 0"
"DEBUG" 2632 "2019-03-19 07:41:03.738" "Total spam score: 0"
"DEBUG" 2632 "2019-03-19 07:41:03.738" "Saving message: {50950A67-CD3D-464F-8D6D-6BA978197F23}.eml"
"DEBUG" 2632 "2019-03-19 07:41:03.754" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 2632 119 "2019-03-19 07:41:03.754" "108.60.195.213" "SENT: 250 Queued (0.265 seconds)"
"DEBUG" 2644 "2019-03-19 07:41:03.754" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Delivering message..."
"APPLICATION" 2768 "2019-03-19 07:41:03.754" "SMTPDeliverer - Message 589077: Delivering message from x1903-1qrbfgwu0booib021otbq4st0d130b1acxn3hayfbj3eq@rspf.mxthunder.net to c...s@m...r.com. File: C:\Program Files (x86)\hMailServer\Data\{50950A67-CD3D-464F-8D6D-6BA978197F23}.eml"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Applying rules"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Performing local delivery" "DEBUG" 2768 "2019-03-19 07:41:03.754" "Applying rules"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Saving message: {50950A67-CD3D-464F-8D6D-6BA978197F23}.eml"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Reading messages from database." "
"DEBUG" 2768 "2019-03-19 07:41:03.754" "AWStats::LogDeliverySuccess"
"DEBUG" 2768 "2019-03-19 07:41:03.754" "Local delivery completed"
"APPLICATION" 2768 "2019-03-19 07:41:03.754" "SMTPDeliverer - Message 589077: Message delivery thread completed.
Delivered.
dlee5400
Post by dlee5400 » 2019-03-19 15:42
Correct, the accounts deliver fine, its the account aliases that bounce back. (I guess the question now is do I understand the purpose of an account alias?) I thought those allowed me to send to an alias vs setting up an account for said email address.
Thanks,
David
Post by jimimaseye » 2019-03-19 17:05
Sending an email in to an address that is set as an account alias effectively just does a forwarding to whatever address you have set in the account alias.
Sending an email in to a domain name alias address will result in it begging delivered locally in to the inbox of the main domain.
Maybe you have an account alias forwarding to an email address that is, for example, TO:myhomeaddress@gmail.com . However this may well get bounced if the original inbound external email was from gmail as your hms server is NOT a permitted sender of gmail emails (it would be attempting to send an email From: external@gmail.com To: myhomeaddress@gmail.com).
tunis
Post by tunis » 2019-03-19 18:09
How do you receive mail?
Have you a front end server that sends the error:
Then the aliases must exist on that server to or it must use catch-all.
HMS 5.6.8 B2437.17 on Windows Server 2019 Core VM.
HMS 5.6.8 B2451.21 on Windows Server 2016 Core VM.
dlee5400
Post by dlee5400 » 2019-03-19 19:31
This server is only routing the two domains. The gmail account is only for testing outside of my network due to internal routing by the hMailServer. The account alias actually routes from an account such as marketing@domain.com to my dlee@domain.com.
As to SMTP 25 I use other ports to receive emails. Is it a requirement to have 25 opened?
Thanks,
David
dlee5400
Post by dlee5400 » 2019-03-19 21:02
Hi @ tunis, I opened port 25 and got the same results as before. So I'm satisfied that its not a port issue.
dlee5400
Post by dlee5400 » 2019-03-19 22:04
Ok all this is my walk of shame. I use a service that filters domain level spam out before it hits my server. I usually can add a user to my accounts etc. with out it interfering in the process. BUT (head looking at ground) they upgrade the service to catch these types of activities (adding a new email account). Thus they where blocking the email at their level. I just have to login to their service and add to my approved list and all is well.
Sorry for the energy waisted running this down.
And thanks for the help you all provide to folks like me!!!
David
Post by jimimaseye » 2019-03-20 01:27
There you go. As expected, in the first reply, this wasn't a hms rejection.
Good job and glad you've figured it out. (I bet you won't fall in to this trap again. :wink: )
Thanks for the update .
Post by katip » 2019-03-20 18:41
@David,
now that all is fine again, i'd suggest you revise your whitelisting policy.
if what is seen is not for testing only, you have whitelisted about half of the world :D
